Thedavevw Samba Member
Joined: June 03, 2021 Posts: 5 Location: South East England
Posted: Thu Jun 10, 2021 5:45 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
The green ecu pipe is the only pipe I couldn't really check for leaks because of how it runs with the loom, other than it not connected is there anything specific I'm looking for with the map? Any way to test it etc? If I can't see an issue is it a new ecu or can that part be replaced?
Thank you |
Antonio Trejo VW Parts Dealer
Joined: December 17, 2003 Posts: 937 Location: Mexico City
Posted: Thu Jun 10, 2021 1:25 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
hopkin wrote: |
Thedavevw wrote: |
Hi everyone, I have a 97 mexi bug and need a new ignition transformer, can I use a standard round coil that the non fi bugs use? I'm not that familiar with coils so not sure if they do the same job |
This is the one you should use, they were commonly used on the water-cooled cars so they are readily available.
I ordered a cheap one and it only lasted a year or so, I recommend ordering a better quality one |
Genuine VW e-coil, 10 years in service in my 1994 Sedan.
_________________ Parts VW
"From Volkswagen of Mexico factory..."
Genuine VW Sedan parts
Genuine VW Ultima Edition parts
Genuine VW Type 2 watercooled parts |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Thu Jun 10, 2021 11:43 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Thedavevw wrote: |
Thank you |
So, you check for vacuum leaks as you would do with e.g. a distributor advance capsule:
disconnect the hose at the manifold side and suck on the unplugged end trying to stick your tongue to the hose to see if it holds vacuum. If it does, you have no further tests to do.
if it doesn't hold vacuum, repeat test at each connection (engine compartment & ECU box under the back seat)
All the hoses including the rubber one inside the ECU can be replaced, if the MAP nipple (inside the ECU) is broken you can try epoxying it, but if the sensor diaphragm is broken or the sensor itself is bad you'll need a new one, it is not normally considered a user-serviceable part but if you can do electronics board repairs you can try finding a replacement and soldering it yourself. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Fri Jun 11, 2021 8:20 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
Thedavevw wrote: |
Thank you |
All the hoses including the rubber one inside the ECU can be replaced, if the MAP nipple (inside the ECU) is broken you can try epoxying it, but if the sensor diaphragm is broken or the sensor itself is bad you'll need a new one, it is not normally considered a user-serviceable part but if you can do electronics board repairs you can try finding a replacement and soldering it yourself. |
Ok did not think of trying that, anyway it holds vacuum fine so that's ok as far as I can tell. Currently working on getting the exhaust off so I can get to the o2 sensor to replace that but somehow lost every 13mm spanner I own so giving up for the day lol |
Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 264 Location: Orlando, FL United States
Posted: Thu Jun 24, 2021 10:36 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Now on National Beetle Day do we have technically 4 days May 5th for the Liberation of Pueblo from the French... Invention Day June 22nd and Last build Day July 30 th... and to push in the Herbie family 31st for Buddy Hackett...??? just asking? _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
GArBa Samba Member
Posted: Fri Jun 25, 2021 12:42 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
link doesn't work? _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
Posted: Fri Jun 25, 2021 5:59 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
GArBa wrote: |
link doesn't work? |
bummer sorry it was copied from another page
try this
https://www.volkswagen-classic-parts.de/ _________________ 2001 Ultima Clasico Edicion Mexibeetle
GArBa Samba Member
Posted: Sun Jun 27, 2021 10:31 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
ah ok it's the usual one. Thank you _________________ cars:
'97 type 1 1600i
'22 type C1 T-Cross
moped:
nagerjaeger Samba Member
Posted: Tue Jul 20, 2021 1:08 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Feeling cool hanging out with my older siblings. I'm in red.
Posted: Wed Jul 21, 2021 11:08 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
ok super brains looking for a sub for a Tomoco T15592 injector only one available is from Mexico....Anybody know off a suitable replacement stateside? _________________ 2001 Ultima Clasico Edicion Mexibeetle
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Wed Jul 21, 2021 7:51 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Sotobaggins wrote: |
ok super brains looking for a sub for a Tomoco T15592 injector only one available is from Mexico....Anybody know off a suitable replacement stateside? |
Is that for a Mexican Beetle, VW number is BAA906031. Maybe the same as 037906031 (Golf)?, maybe worth some research.
They look like the same physical dimensions:
BAA906031:
037906031:
Here's some info that I found, may or may not help:
http://www.205gti.com/bosch/inject.htm _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 813 Location: San Juan Islands
Posted: Fri Jul 23, 2021 10:36 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I have a 2003 Sedan that I bought new and only use occasionally. Reason is the gearing is very low.
Been poking around for the different FF Swing Axle tranny's and thinking this is the way to go.
Anyone installed one of the 3.88 R&P units?
Mofoco has a gear combo I like:
1st gear: 380
2nd gear: 206
3rd gear: 132
4th gear: 0.82
Ring and pinion (final drive ratio): 4.12
I would think the high torque of the 1600i would pull the taller gears more than fine.
Would love to take my Bug on longer trips. Simply not an option with the stock gear ratios.
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Mon Jul 26, 2021 8:19 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Thanks to Hopkins I found that DEFUS https://www.df-fuelinjector.com/ has the best price on injectors if needed
"The following is the price
Injector OEM BAA906031 each pcs is $10. $40 for 4 pcs,ship to United States the cost is $ 30. DHL,transportation time about 5-7 days" _________________ 2001 Ultima Clasico Edicion Mexibeetle
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Tue Aug 03, 2021 9:26 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
The 4:23 ratio is low, but where I'm at, the highways have a lot of hills.
I ran a taller tire for a while, the car wouldn't maintain highway speeds.
Went back to a standard height tire, I can maintain highway speeds now.
So at this point I will let it run high RPM's, when I update the motor I will change the gear ratio to 4:12, 1776 or 1835 will work good for my area.
Root_Werks wrote: |
1st gear: 380
2nd gear: 206
3rd gear: 132
4th gear: 0.82
-Dan |
Scott SD Samba Member
Joined: June 22, 2010 Posts: 153 Location: San Diego, CA
Posted: Tue Aug 10, 2021 8:57 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
My advice from building and breaking more than a few transmissions. 4.12 is great, 3.88 is stronger. A 4.12 with a stock 0.89 is probably the best combo for city/hwy. But, you can use either. All of the late 70s cars had a 3.88 with a 0.93 4th. Coming from the Mexi box, it would be more noticeable in 1st gear. For the 1st gear, do not use a 3.80. It is an early mainshaft and weak. The later 3.78 is much stronger.
I built a 3.88 Box with a stock gear stack in a '67 that would cruise on the freeway effortlessly, but it had a nice 1776 w/44 Webers.
For my Mexi I plan to swap to a late 3.88 box with a few upgrades.
Root_Werks wrote: |
1st gear: 380
2nd gear: 206
3rd gear: 132
4th gear: 0.82
-Dan |
hopkin Samba Member
Posted: Tue Aug 10, 2021 7:21 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
The Mexican Beetles that were imported to Europe (in the mid '90s) had some minor wiring modifications done for the lighting. Specifically the installation of the rear fog light and City lights (and removal of the parking lights).
There was a discussion on this topic early on this thread. Based on that discussion and tracing the wiring on my car I decided to create a schematic of those mods using the Mexican Beetle wiring schematics (found on www,1600i.de) as a template.
I finally got around to finishing them this week, here is the result:
(I created these in Adobe Illustrator, pdf's are available if anyone wants them, drop me a PM).
Note that different importers may have done something different. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Sat Aug 14, 2021 12:56 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hopkins is there a chance of you posting wire diagram for non immobilizer and possible non fuel injected ....just curious... _________________ 2001 Ultima Clasico Edicion Mexibeetle
hopkin Samba Member
Posted: Sat Aug 14, 2021 7:35 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hopkins is there a chance of you posting wire diagram for non immobilizer and possible non fuel injected ....just curious... |
Sorry, I don't have those, only the post '93 (fuel injected) that I found on www.1600i.de. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
