Root_Werks Samba Member
Joined: December 31, 2007 Posts: 813 Location: San Juan Islands
Posted: Thu Dec 22, 2022 12:14 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
radstude wrote: |
Root_Werks wrote: |
OR:
Can the Mexican Bug heads be swapped out for better heads already flycut with larger valves etc.?
Knowing I'd probably need to drill/tap for CHT.
Would be nice to get another few HP while it's out. |
I'm not sure about machining of the heads, the cylinders should fit the case fine. You can build the engine as big as a 1914cc, 1835cc is a better stopping point for the fuel injection. When I was checking into building a bigger engine, the crankshaft was the issue. Mexican 1600i is a cast crankshaft, not as strong as a forged crankshaft. 5000 RPM's is the max for a cast crankshaft, Forged crankshaft is 7000 to 8000 RPM. It would be better to start from the crankshaft, then build from there. I just know how I drive my bug, I DRIVE IT. |
Good points, I might just have a 1776 built that still has Hydro lifters and cam that works with the stock FI. I could do CW crank, smoother engine. It's like a can of worms!
_________________ When I set my timing, why do I flush, then take a pee? |
coolbugfan Samba Member
Posted: Sun Dec 25, 2022 8:00 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
HI Sambas,
You've all given me a lot of help since I got my 1600i.
thank you & happy holidays |
Posted: Tue Dec 27, 2022 5:22 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I agree, thanks to all who help out on The Samba. Most appreciated. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Tue Dec 27, 2022 8:41 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Nice to have a little time off and tinker on my Bug.
Anyone know if the ign switch can be swapped out for an MK1 or MK2 can be swapped to enable the accessory function?
If remember correctly, key in would allow radio use (didn't need to rotate key) _________________ When I set my timing, why do I flush, then take a pee? |
Sotobaggins Samba Member
Joined: February 23, 2016 Posts: 264 Location: Orlando, FL United States
Posted: Wed Dec 28, 2022 4:22 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Root_Werks wrote: |
I was lucky to have mine replaced with a generic Porsche 911 switch which works better that the after market VW one _________________ 2001 Ultima Clasico Edicion Mexibeetle
2003 Black GTI 1.8T |
Posted: Thu Dec 29, 2022 11:12 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Valve timing
Hi Sambas,
I've been hearing an occasional "phuut" sound at high revs and it was recommended that I check the valves on my 1600i. I do not know when they were last checked/adjusted.
Now, I've seen the youtube videos on adjusting the solid valves on older Bugs, but I've never done it with HYDRAULIC values.
So, what are the valve clearances for a 1600i?
What is the adjusting procedure for hydraulic valves? I'll need the 'for Dummies' step by step version. I do have a feeler gauge.
Much thanks! |
Bruce Samba Member
Posted: Thu Dec 29, 2022 2:53 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
You don't adjust them.
The lash is automatically taken out when the lifter is pumped up. If there's wear, it is compensated for. The range they can compensate for is about a mm either way. If you think you are outside that range, your cam and/or lifters are shot, so adjusting won't help.
I've never checked the lash on my Mexi. In fact, the only reason I removed one side's valve cover is because it was leaking. The other has never been off. _________________
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Thu Dec 29, 2022 8:06 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Just adjust to 0.0 lash, then adjust 1 turn in. Unless you have a loose rocker arm, or it’s noisy, just leave it alone. _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
Posted: Mon Jan 02, 2023 10:22 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hi Sambas,
I've got conflicting info on the valves. HOWEVER, I took the car out for a drive yesterday. It ran nicely. I noticed I wasn't letting it get to the high revs that caused the backfire. I hit 20km/h is first as I changed up and all was good.
So, just leave it? I wasn't sure what else could cause the backfire. The coil is new. I didn't think we 'time' the FI cars. That's why I asked about the valves.
Thanks |
Posted: Mon Jan 02, 2023 6:08 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I would leave it, as others have said, hydro lifters shouldn't need to be touched.
As for the backfiring, not sure what to make of that. Maybe a sticky valve for a few miles? My 1600i doesn't like to sit more than about a week. I have one lifter that bleeds off quickly and takes forever to pump back up. So I try to drive the Bug weekly at least. _________________ When I set my timing, why do I flush, then take a pee? |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2480 Location: Ottawa, Ontario
Posted: Mon Jan 02, 2023 7:34 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
hopkin wrote: |
Each year a house in our area is decorated with a movie theme, 2 years ago it was Christmas Vacation, last year was Home Alone, this year is Elf.
Here is this year's display.
(The owner encourages anyone who enjoys his display to donate to the local Children's Hospital [CHEO]). |
Just an update, the house display raised over $25,000 for CHEO over Christmas/new Years, over $140,000 since 2020.
https://ottawa.ctvnews.ca/stittsville-family-raise...-1.6214981 _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
Posted: Mon Jan 02, 2023 8:42 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Root_Werks wrote: |
As for the backfiring, not sure what to make of that. Maybe a sticky valve for a few miles? My 1600i doesn't like to sit more than about a week. I have one lifter that bleeds off quickly and takes forever to pump back up. So I try to drive the Bug weekly at least. |
Thanks, Root Werks. The Bug had been sitting unused for a good three weeks when this happened. I only started it to keep the battery charged and things lubricated. Unfortunately, we have been having "non-Bug" weather. |
Posted: Tue Jan 03, 2023 7:22 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
hopkin wrote: |
hopkin wrote: |
https://ottawa.ctvnews.ca/stittsville-family-raise...-1.6214981 |
WOW! Great way to raise funds! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
Posted: Tue Jan 03, 2023 9:29 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
coolbugfan wrote: |
Root_Werks wrote: |
Yup, that's my issue as well. Mostly don't mind driving the Bug in the rain, but we've been getting some snow. Means a bunch of gunk on the roads. After almost 20 years now, my 2003 Bug has only 13K miles on it. Still looks and smells like a new car.
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
pharos Samba Member
Posted: Fri Jan 06, 2023 6:39 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I bought 34 PICT-3 carburetor for Mexican engines. I found that they blocked the Vacuum port which should be connected to the SVDA!!!
Is that OK?!!
In Paruzzi company said "Paruzzi 4425 34 PICT-3 for Mexican engines
This carburetor is designed for the latest generation Mexican engines that were equipped with a vacuum system. This is a high quality reproduction that is often preferred to Paruzzi 2142 where the vacuum system is removed."
Check the link: https://www.paruzzi.com/uk/volkswagen/engine/carburetor-air-filter-inlet-manifold/4425/
_________________ http://www.facebook.com/groups/vwbug/ |
Posted: Fri Jan 06, 2023 6:30 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
pharos wrote: |
Is that OK?!!
This carburetor is designed for the latest generation Mexican engines that were equipped with a vacuum system. This is a high-quality reproduction that is often preferred to Paruzzi 2142 where the vacuum system is removed."
I also bought one of these from a Mexican parts website and it is the recommended carb for the cars...so no stress also this is what the webpage says about this carb:(translated from Spanish)
Engine Carburetor with Voltmax Altimetric System for VW Sedan 1600, Combi 1600, Brasilia, Safari, Ant
It is an iconic part of a car, always related to the power of the car, it is part of the general culture, but few people really know what it is for. To better understand what a carburetor is, let's use an analogy: If the car were a person, and gasoline were food, then the engine would be the stomach where that food (Gasoline) would be digested, right? Well then the carburetor becomes: The mouth. Yes, the carburetor is what the vocho and any other car that runs on gasoline use to eat gasoline and air, how does it do it? It has a small deposit or tank integrated where they store a portion of fuel, that is, the cheeks, going back to the comparisons, from there they enter the engine through a circle that opens and closes to the rhythm of the accelerator pedal and looks nothing more than curious, they call that part "Throat", gasoline and oxygen reach the engine and digestion begins, or combustion already returning to the automotive context. The hoses that the carburetor has are for supplying gasoline and it has another small hose that connects with the distributor, only air circulates here, air that moves the pulse transmitter and sets the work rate of the spark plugs depending on how much gasoline is being used. requiring to move. It only has one electrical component, the electromagnetic valve, which is the primitive version of the valve. The hoses that the carburetor has are for supplying gasoline and it has another small hose that connects with the distributor, only air circulates here, air that moves the pulse transmitter and sets the work rate of the spark plugs depending on how much gasoline is being used. requiring to move. It only has one electrical component, the electromagnetic valve, which is the primitive version of the valve. The hoses that the carburetor has are for supplying gasoline and it has another small hose that connects with the distributor, only air circulates here, air that moves the pulse transmitter and sets the work rate of the spark plugs depending on how much gasoline is being used. requiring to move. It only has one electrical component, the electromagnetic valve, which is the primitive version of the valve. slow motion, it lights up when we stop opening the throat, this little valve, allows air to pass while we wait at a traffic light or something like that, so that the carburetor doesn't choke; Since dirty air cannot get into the engine, a filter is needed that will stop the dirt and only let clean air through. Now that you know what this intricate artifact is for, you can take better care of it; Carburetors can last as long as the car as long as you maintain it once a year by changing gaskets and giving it a good scrubbing to prevent carbon buildup, when 3-4 years go by it is recommended to do a full nozzle replacement, gaskets and valves, which are small but important elements that regulate the amount and frequency of fuel and air flow inside the carburetor, For that, there are carburetor spare parts, but if a long time has passed, after opening and closing the carburetor so many times, it will start to leak, add to this that the levers and diaphragms will already be very worn, which will cause air leaks. and loss of power. If your vocho has its time, and you had never paid attention to the mouth of the car, you should seriously think about replacing this important component.
The altimetric system was an addition that was incorporated in the last years of the carburetors, this due to the pressure exerted by the new environmental laws. It consists of the carburetor knowing how much oxygen it has for combustion, if it is at a level close to the sea, there will be more air to burn, therefore it uses less gasoline to burn, if on the contrary it is very high, there will be less air and So you have to make up for it with more gasoline. Unfortunately, Mexicans from the capital are more than 2,000 m above sea level, and therein lies the answer to why your car uses up a lot of gasoline, because we live at a height where there is much less air than there would be at the same height as beaches.
Requires advanced engine knowledge to install.
To put it to work, you just have to mount it, put some gasoline in its tank and make starts until it is completely filled, and the airbags are eliminated, after that it will be able to work without problems.
The altimetric system is to save a little fuel according to the sea level where the vehicle is located.
Only applies to 1.6L or 1600 cubic centimeter engines. It is also in the Sedan 1600. 1992 model.
Does not apply to vocho 1200 or 1500 models.
Does not apply to Atlantic and Caribe Motor 1600, since they require a thermostat activated by water.
Does not apply to Golf or Jetta.
Does not apply to 1.8L 2 Throat engines.
Check the condition of the hoses, distributor, and spark plugs when restoring power to the car through the carburetor.
The upper throat to place the air filter is 5.3 cm. _________________ 2001 Ultima Clasico Edicion Mexibeetle
Posted: Wed Jan 25, 2023 11:41 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Pulled the engine to update to 1679!
Using thick wall 88's and AA larger valve heads.
Very excited to get a couple more HP while still retaining FI and hydro lifters.
Posted: Wed Jan 25, 2023 2:51 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Root_Werks wrote: |
Can't wait to see more! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
Posted: Thu Jan 26, 2023 9:34 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Heads on last night, overall impressed with AA heads and P/C's. Head castings are nice, passages between cooling fins are mostly clear. I spent maybe 5-10 minutes a head cleaning up some fins.
It's now a 1679, hoping it works!
