Root_Werks Samba Member
Joined: December 31, 2007 Posts: 790 Location: San Juan Islands
Posted: Fri May 05, 2023 2:23 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
luscive wrote: |
Alright, unrelated to my open air dilemma, I have another issue with the fuel injection. So every time i turn the car on, the motor doesn’t idle, it goes “vrOOM, vrOOM, vrOOM” almost like it has a cam in it or something (it doesn’t) and if i give it any sort of throttle the RPMs just jump to the sky. I’m thinking it’s clogged injectors or maybe like an idle control module or something like that. It’s a 1600cc with fuel injection and A/C. Any ideas? |
It sounds like a pretty large vacuum leak. Could be a failed idle control valve. Would carefully check everything for possible air leaks. Don't know if you unplugged the IAC if it fails closed, could be an easy test. _________________ When I set my timing, why do I flush, then take a pee? |
radstude Samba Member
Joined: January 29, 2005 Posts: 396 Location: Lynchburg Va.
Posted: Sat May 06, 2023 9:13 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
luscive wrote: |
I’ve taken them apart & cleaned them. They get oily and sticky inside. Carb cleaner works. _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
bandi Samba Member
Joined: August 24, 2005 Posts: 1063 Location: Campbellford, Ontario, Canada
Posted: Sun May 07, 2023 7:30 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Root_Werks wrote: |
Installed a set of Empi Zero offest drop spindles this week. These are true zero offset spindles, believe only for ball joint disc brakes. Turned out great, much better than pulling the fuel tank, entire front beam etc. No thanks. 3 hours and this was done, still need to get it aligned.
Really like the stance and ground clearance. Perfect for a driver.
That looks fantastic! _________________ '60 Canadian Standard, '64 Bug, another '64 Bug, '66 Bug, '69 Sunroof Bug, '69 GT3 Bug, '71 Super, '72 Super, '73 Canadian Custom, '74 Love Bug, '83 Mexi Bug, '85 Cabrio, '94 Mexi Bug, '99 New Beetle, '02 New Beetle Turbo S, '03 New Beetle VR6. And some Fieros. |
airkewld0scar Samba Member
Posted: Wed May 10, 2023 11:57 am Post subject: Brake kits for 1998 Mexican sedan disk/drums |
Hello all,
I’m in need to redo my brakes, disk up front and drums in the rear. I’d like to just get a conversion kit (for sure for the rear, but may just redo the front if it’s worth it) but I haven’t been lucky in finding places that specifically say their kits work with Mexican beetles.
I was wondering if someone that has done conversion kits could share sites or part numbers they have used.
Thanks _________________ 1991 Foxbody GT (past)
2003 Mach1 (past)
2002 GTI 337 (past)
2007 GTI (past)
2015 GTI (past)
1998 Mexican Sedan (current) |
Posted: Fri May 12, 2023 9:16 am Post subject: Re: Brake kits for 1998 Mexican sedan disk/drums |
airkewld0scar wrote: |
Hello all,
Thanks |
I wouldn't convert anything. Most rear disc brake kits aren't very good, a street Bug doesn't need that much braking in the rear.
The Mexi-Bug disc brakes are WAY better than most kits you'll find. There is a proper seperate hub the disc hat sits on. Pads are common, you can get calipers rebuilt etc. Most of the "kits" you can install will be taking a step backwards in my opinion.
Reach out to Antonio, he can get almost any Mexi-Bug part you need. _________________ When I set my timing, why do I flush, then take a pee? |
hopkin Samba Member
Joined: June 25, 2012 Posts: 2469 Location: Ottawa, Ontario
Posted: Fri May 12, 2023 10:11 am Post subject: Re: Brake kits for 1998 Mexican sedan disk/drums |
Root_Werks wrote: |
Reach out to Antonio, he can get almost any Mexi-Bug part you need. |
x2, the rotors you can get from Antonio, but the calipers and pads are the same as the 'Ghia' type. I replaced my calipers a few years ago with a set from cip1.
Here is a picture of the original and new one side by side:
_________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
1991 Honda Civic (Original Owner)
1996 'Open Air' Mexican Beetle (current)
2015 Golf (current)
2017 Dune Edition (daughter's car) |
luscive Samba Member
Posted: Thu May 18, 2023 7:17 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Hello all, just a little update on my idling issue. It’s fixed! Simple as cleaning the mass airflow sensor and viola! Cars running great and gets really good mileage now that it’s being driven, and I’ve driven it some pretty great distances with no issues. Loving this car, and my temporary open air top back window fix is doing great as well. Flex seal works some wonders man, been able to put the top down and back up multiple times. Gonna take some good pics and upload them here soon. _________________ 2015 GMC Sierra 2500HD (Past)
2018 Honda Civic Sport (Current)
1996 Chevrolet Camaro Z/28 SS (Current)
1998 Mexican Beetle "Open Air" (Sold)
2003 Mexican Beetle Sedan (Dad's) |
Posted: Fri May 19, 2023 8:57 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
luscive wrote: |
Hello all, just a little update on my idling issue. It’s fixed! Simple as cleaning the mass airflow sensor and viola! Cars running great and gets really good mileage now that it’s being driven, and I’ve driven it some pretty great distances with no issues. Loving this car, and my temporary open air top back window fix is doing great as well. Flex seal works some wonders man, been able to put the top down and back up multiple times. Gonna take some good pics and upload them here soon. |
Yay! Yes, please post some pictures. Glad you got the idle fixed. _________________ When I set my timing, why do I flush, then take a pee? |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17273 Location: Left coast, Canada
Posted: Tue May 23, 2023 11:53 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
luscive wrote: |
Simple as cleaning the mass airflow sensor .... |
Since your car doesn't have a mass air flow sensor, what did you clean? _________________
hopkin Samba Member
Posted: Tue May 23, 2023 6:36 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Bruce wrote: |
luscive wrote: |
Since your car doesn't have a mass air flow sensor, what did you clean? |
I'm thinking he meant the intake temperature sensor. I replaced mine a few years ago, as the connector was bent. (It still works so I kept the old one as a spare).
https://www.paruzzi.com/uk/volkswagen/engine/injection-system/4105/ _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
hopkin Samba Member
Posted: Sun Jun 04, 2023 6:31 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
It's been a while since I posted some fun pics, and as the Samba theme of the day is winter pics I thought I'd post a few from last winter. Yes, I take the car out in the winter from time to time. It's gets a rinse when I get home.
Enjoy!
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Mon Jun 05, 2023 10:00 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Nice winter pics! I take my Bug out in the snow at times as well. It drives very well in the white stuff. _________________ When I set my timing, why do I flush, then take a pee? |
coolbugfan Samba Member
Posted: Mon Jun 12, 2023 8:54 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Unfortunately, I’ve had some VERY bad luck with my 1995 Mexi-Beetle. The engine needs to come out for some serious TLC.
Now, back in the day, folks were taking about 15-20 minutes to take out a little 36 hp 1200. I know ours are more complicated. What is a reasonable amount of time a mechanic would take to remove a 1600i engine? 2hrs? 3? Installation similar or longer? Just talking approximately.
Thanks.
PS Love the snow pics. I try to stay out of the rain, let alone the snow! |
hopkin Samba Member
Posted: Tue Jun 13, 2023 3:37 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
coolbugfan wrote: |
Thanks.
If you have experience removing the engine in an older car, you should be able to remove the engine in an hour or so (maybe less if you have the right jack to lower it, or a hoist). It's a bit finicky, I suggest removing the cat/muffler and the injectors (and rails) before removing, but it can be done leaving them. Removing the fan belt can give you a little extra wiggle room as well. Also some of the rear tin. Don't forget to remove the ground strap connected to the engine lid, ask me how I know.
Reverse to install. It seems like there is a little less space around the engine which makes it harder to line up. But it have appeared that way (to me) as I didn't really have the best jack each time I removed my engine. _________________ 1971 Super Beetle (past)
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Tue Jun 13, 2023 6:28 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
1 1/2 Hrs, if it goes smoothly. If you have trouble getting the exhaust off, ? _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
Posted: Tue Jun 13, 2023 9:28 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
I've pulled my engine 3 times for tranny swaps. Last time was surprisingly quick for me (45 minutes).
As others have mentioned:
Remove fan belt
Remove fuel rails from intake, let them flop around
Don't forget the little ground strap on the decklid hinge
I leave the exhaust on, gives me something to grab onto. It's tighter than an older carb'd Bug, but easier than a later L-Jet Bug. _________________ When I set my timing, why do I flush, then take a pee? |
hopkin Samba Member
Posted: Fri Jun 16, 2023 6:51 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
For those who didn't see on my facebook page, I rolled 200,000 kms on my car a couple days ago. I added a second 100,000 km pin (re-pop's) and have a third one should I reach 300,000 km. I have driven 130,000 kms of the 200,000 kms.
Car is still running good, engine rebuild is in the foreseeable future but not yet planned.
1974 SunBug (past)
1972 914 (past)
2015 Golf (current)
Posted: Fri Jun 16, 2023 7:30 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
hopkin wrote: |
Congratulations in order!
For someone who put his car in hibernation for the winter, you do put a lot of mile on your Bug. _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
Gerrelt Samba Member
Joined: December 22, 2004 Posts: 682 Location: The Netherlands
Posted: Tue Jun 20, 2023 11:19 am Post subject: Re: Official Mexican / Brazilian Beetles - All years |
Congratulations! _________________ homepage
_________________ |
Posted: Tue Jun 20, 2023 2:38 pm Post subject: Re: Official Mexican / Brazilian Beetles - All years |
@hopkin
That's awesome, congrats! I need to drive my Bug more. _________________ When I set my timing, why do I flush, then take a pee? |
