chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Thu Feb 06, 2014 9:30 am Post subject: conversion to FI - the *other* stuff |
i want FI! i'm sick of my progressive and want that "start right up" reliability. after disassembling several FI engines through the years i'm pretty sure i have all the parts that go on or around the engine, but i know there are several things i need that i probably didn't know to grab at the time. from looking at past threds it looks like:
- air cleaner stand
- brain mounting
- gas pedal and linkage
- fuel pump?
- gas tank?
what else? _________________ '74 transporter panel
'91 vanagon carat NAHT |
merlinj79 Samba Member
Posted: Thu Feb 06, 2014 9:43 am Post subject: |
Fuel Pressure Regulator
Firewall Relays
Firewall Resistor Bank _________________ Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff |
SGKent Samba Member
Posted: Thu Feb 06, 2014 9:48 am Post subject: |
we can walk you thru it if you have the time to find parts for each step if you have none.
Start by pulling the engine, and if you don't have an FI tank, drain the old tank and find a good used one. New ones are about $400 shipped.
Set the engine aside. Clean the used tank and swap it with the carb one in your bus now. FI tanks have an inlet and an outlet. Don't forget the two screws under the firewall.
While you are getting the tank, keep an eye out for an ECU mount and an air cleaner mount. You'll want to weld the air cleaner mount in while the gas tank is out. Post when these things are done and we'll go to the next step. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5778 Location: Los Alamos, New Mexico
Posted: Thu Feb 06, 2014 10:07 am Post subject: |
I'm going to be watching this thread, as I have two FI projects planned.
1) (The easy one.) Get my '79 Transporter back to FI and off the single carb that someone put on there.
2) Convert the '75 Pickup to FI. This is a bit harder, since it was not FI to begin with, and so will require the same modifications for mounting the ECU that the OP has. And, sadly, some PO actually cut out the air filter mount, so that will have to get redone.
With respect to #2, the pickup has a 1.8-L CB-class engine in it (with a nice recent top-end rebuild). Will this difference in displacement mean any modifications to an FI system that may have come from a 2.0-L system, or will it work just as well? (I do not want to put a '75 FI system on it, unless that is truly necessary).
I have had it with carburetors.
To the OP: Does this proposed FI modification apply to your '74 bus? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Thu Feb 06, 2014 10:10 am Post subject: |
SGKent wrote: |
You'll want to weld the air cleaner mount in while the gas tank is out. |
One needs to be careful to get the angle of the mount correct. This is a rather nasty looking rig, but here are the angles.
SGKent Samba Member
Posted: Thu Feb 06, 2014 10:26 am Post subject: |
John - If I had a 1975 I would use the later 2.0 FI. Worst case is you let Colin adjust the mixture. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
chachi Samba Member
Posted: Thu Feb 06, 2014 10:57 am Post subject: |
jtauxe wrote: |
To the OP: Does this proposed FI modification apply to your '74 bus? |
yep!
there's a '76 here in portland being parted that i'm going to see if i can get most of these parts off of. i have the regulator, but the relays and the resistor network i'd like to know more about. _________________ '74 transporter panel
chachi Samba Member
Posted: Thu Feb 06, 2014 10:59 am Post subject: |
Wildthings wrote: |
SGKent wrote: |
One needs to be careful to get the angle of the mount correct. |
why is this so critical? _________________ '74 transporter panel
Posted: Thu Feb 06, 2014 11:10 am Post subject: |
chachi wrote: |
Wildthings wrote: |
SGKent wrote: |
why is this so critical? |
The "S" isn't particularly forgiving of misalignment, plus there is not a lot of extra room to accommodate errors. |
chachi Samba Member
Posted: Thu Feb 06, 2014 11:18 am Post subject: |
one install i was looking at (rustbus or rustybus or something similar) seemed like he tack welded and then bolted his stand on. i feel like, from looking at your pictures, that to get a stand out one would have to saw the the thing out. would you then have to saw a hole in your own bus to get the new piece at the right angle? i don't know that i would be willing to go that far. _________________ '74 transporter panel
