VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Feb 08, 2014 7:03 am Post subject: |
I do my best to avoid driving in the snow/ice here in NC.
If I must... its usually in my Isuzu Pup Diesel loaded down with ballast in the bed.
For some reason.. There are too many "Redne..." hold it. . ... people.. that just have to go out a "ride" in the snow..
Those are the real hazards.... not so much the actual weather and road conditions.
Of course....we dont really get a lot of snow... but here in the South.. an inch will cripple the roads for a good day... then its 60 degrees the next..
(Nothing like Jersey)
As for driving in the snow in the old Vw... Yeah I used to ... If I had a road worthy beater I still would.... The Vw's I now have on the road... I have too much invested to sacrifice to the brine, salt, sand and ...those "other" people on the roads in the snow.. If was an emergency Id take em' out.. They are better than some 4wd's. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2078 Location: Bulli Klinik, Colorado Springs
Posted: Sat Feb 08, 2014 7:55 am Post subject: |
Opening the vent windows a bit will increase the heat circulation. This is usually mentioned in the owners manual.
I run 5-30 in my Bus during the winter. You can really tell the difference, especially at start up.
I've been running these for a few years:
About 20 bucks at Autozone or Walmart. Really cuts the chill on the back side. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sun Feb 09, 2014 6:58 am Post subject: |
drscope wrote: |
crukab wrote: |
DRY Sand in gallon Milk jugs- gets me out of slippery spots, I dry it in a metal pan on the wood stove- frozen wet sand does not help much... |
Kitty liter works just as well as sand and you can{b] buy it{/b} in gallon jugs. Don't have to dry it. |
I'm waaaay to cheap to buy something when I can get the sand free, plus I have a wood stove going from November until April, put one of my many SS hotel pans on the stove, push the sand around a little a few times, pour it in a jug w/ a funnel, done. I have 4-6 on hand, it lasts years if you don't need it.
Enough about sand...
Since I park outside, I will use a oil pan heater, but only if it's going to be -10 or worse... A good battery is the best winter help you can get. New wipers each winter are a good idea too.
Cold in Vermont :
_________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
DrKamikazi Samba Member
Joined: March 03, 2013 Posts: 316 Location: Across North America
Posted: Sun Feb 09, 2014 11:32 am Post subject: |
this is awesome I was just thinking about this last night! I was wondering if anyone has any tips on keeping your windshield clear, I find that if the snow is wet or if its a winter mix I can scrape it off and clear the windshield, but then as Im driving down the road it just refreezes and I have to stop every so often and scrap again on the side of the road. Obviously if thats what I have to do to keep a safe visibility I will but a way to avoid this would be awesome! |
bobna54oval Samba Member
Joined: November 06, 2006 Posts: 52 Location: Missoula MT
Posted: Sun Feb 09, 2014 1:25 pm Post subject: |
It was mentioned before, but it bears hearing it again. Don't use your handbrake when its cold, especially if you are parking the car for an extended period of time, like overnight or for the day at work. If there is snow, water, slush, etc. inside the brake drums, and it does get in there, it will freeze and the car does not move any more. I found this out the hard way, more than once. Its a hard habit to get out of, pulling on the brake when you park. _________________ Bob
54 oval "Mean Mistreater" |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Mon Feb 10, 2014 8:23 am Post subject: |
Bulli Klinik wrote: |
About 20 bucks at Autozone or Walmart. Really cuts the chill on the back side. |
While the freezing point of water is 32, mine's 60!!!
Some years ago my wife got me a couple of heating "seat-overs" similar to that^^^. However, they have you sitting higher on the bus, too high for my taste. Also, after using it for some time they tend to lose their form. So, on the Plump Truck which I have vanAgone seats, I tore the seat-over apart, removed the upholstery on the seat, installed the heating element unto the seat, then re-installed the upholstery back on it. With a cig-lighter installed next to the heater control knob, I plug it in and it's "inst-A-warm"!
Need to do the same for the Dormy. _________________ Some people are so busy being clever they don't have time enough to be wise. |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
GA_Boy Samba Member
Joined: October 10, 2006 Posts: 1405 Location: Jefferson, GA
Posted: Wed Feb 12, 2014 3:10 pm Post subject: |
Metro Atlanta is just about paralyzed. I took my VW out to see how it did on 1" of ice and snow. It made it around the block just fine and would only spin tire when I accelerated too much for conditions. Wife said I was Playing. I said I was making sure we could travel in an emergency.
Taken this morning.
Marvin
Ian Samba Moderator
Posted: Wed Nov 12, 2014 5:35 pm Post subject: |
Big bump (vortex style) for anyone else experiencing the arctic blast.
I just invested in studded snow tires, huzzah! _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Nov 13, 2014 8:34 am Post subject: |
You do need studded tires for the winter in the 303! My Dad had 4 studded tires to put on my Mom's Oldsmobile & 4 more for his pickup every winter in Missoula, MT. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Brian Samba Moderator
Posted: Thu Nov 13, 2014 12:19 pm Post subject: |
Winter is rough where I'm at. I think yesterday the lows were 55F _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
