kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Thu Feb 06, 2014 7:37 pm Post subject: Warning: Bogus Late Bay Brake Shoes |
I was just checking out some new brake shoes I received recently, and tried putting together an assembly on a new backing plate. It was a massive struggle to get things together - far more so than is usually the case. I found that the holes in the shoes that hold the ends of the large return spring are spaced much too far apart. The attached photo shows a normal installation, with the red arrows showing the normal space between the spring ends and the outer edge of the web. In my case, that space is ZERO and the spring is actually jammed up against the bottom of the shoe proper.
The bad shoes are TCM #421. They are supposedly for use on 73-79 busses, equiv. VW part #211 609 537N. They were sold to me by Wolfsburg West.
I also might add, the metal thickness of the shoe base on these is an extremely chintzy 2.1 mm, and the central web is 3.0 mm, far thinner than any of my other VW shoes.
EDIT: Removed unwarranted mention of other vendors.
MORE EDIT: Also the holes in the web for the lower return spring are about half the normal size.
MORE MORE EDIT: Ron Bengry of WW has graciously authorized the return of these shoes, although not strictly obligated to do so, as described further on. He also
said he has personaly installed a set of these shoes with no problems noted, so it is not clear that these defects are present in current stock (my shoes seem to have
a mfg date from 2011). _________________ '67 bug: seized by the authorities
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Thu Feb 06, 2014 7:51 pm Post subject: |
And you're welcome for the pic. God damn that's pretty. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
germansupplyscott Samba Member
Posted: Thu Feb 06, 2014 8:35 pm Post subject: |
S421 is the generic number for the shoes, so there could be many vendors and manufacturers using that number to cross-reference a set of brake shoes. all bus brake shoes for '74-'79 are technically also S421. fwiw i haven't seen any shoes with the issue you're referring to.
also FYI on the photo above the spring washer looks to be in the wrong place or missing. the washer goes between the head of the brake lever pin and the lever. _________________ SL |
Desertbusman Samba Member
Posted: Thu Feb 06, 2014 8:41 pm Post subject: |
Let us know what Wolfsburg West says when you let them know about the problem. Is TCM the brand that was on the box? _________________ 71 Superbug
71 Westy |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Thu Feb 06, 2014 9:20 pm Post subject: |
I've had some frustration getting shoes for my early bay lately. First I ordered PEX/Pagid and they sent Ideal made in China shoes from their supplier. I later ordered front shoes that were supposed to be Enduro made in US, but these too came as Ideal, made in China. BusDepot apologized and gave me an RMA no questions asked, but seems like quality shoes are getting harder to source. I ended up using them. We'll see how they hold up. https://www.thesamba.com/vw/gallery/pix/1168681.jpg _________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
Posted: Thu Feb 06, 2014 9:33 pm Post subject: |
Desertbusman wrote: |
Let us know what Wolfsburg West says when you let them know about the problem. Is TCM the brand that was on the box? |
Yes, "TCM" was the only identifier on the (normal-looking) box, along
with "Brake Lining Shoe Ass'y", "Brake Shoes", a sticker with "421" on it, and a Wolfsburg West sticker. Each shoe itself also had the inscription "TCM 421/2011 01 10".
As far as WW goes, it is long past the 30 days their terms allow for returns, and also I seem to have misplaced my copy of the invoice, so it looks like this one's on me. I will nevertheless email them about the problem merchandise. If they decide to do anything above and beyond their obligations, I will surely post about it here. _________________ '67 bug: seized by the authorities
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Thu Feb 06, 2014 9:56 pm Post subject: brake assembly |
Also:
Bottom return spring is on backwards and, hub should NOT be painted
either. _________________ V.W.owner since 1967 |
Posted: Thu Feb 06, 2014 10:06 pm Post subject: |
I looked in the Bentley and yes, it looks like the bottom return spring is on backwards. What effect does that have on anything? Zero. Next time I have the drums off to clean and adjust the rear brakes I'll swap it around for you. As for the hub, absolutely nothing wrong with painting it and the paint also helps keep down the rust that likes to form in between the hub and drum and slowly combine the two metals into one. _________________ First Trip in the RustyBus:
borninabus wrote: |
notchboy wrote: |
EverettB wrote: |
RunningRough Samba Member
Posted: Fri Feb 07, 2014 6:39 am Post subject: |
For what its worth, I just recently ordered two cylinders, rear shoes and a spring kit from Bus Depot. Everything seemed to fit up fine. All nice and new looking back there now. I have no idea about the quality of the parts. I didn't even see a manufacturers name on the brake shoe packaging.
I can say the parts looked good and fit good.
Actually, now that I think of it. There was one issue.......the pins for the anti-rattle springs were too short. I just wire wheeled my old pins. _________________ 1970 Westfalia
Passenger Interior
Dual port Type 1
Solex 34 PICT-3
Flame Thrower Dist, Vacuum Advance
1982 Vanagon Diesel L
Diesel engine replaced with 1984 VW Golf engine |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Fri Feb 07, 2014 7:48 am Post subject: |
I just installed a set of Chinese brake shoes on my '78. I didn't notice the hole spacing but I did notice the cracks in the brake lining. Chinese junk. I'm sick of it, but there's no escaping anymore. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
SGKent Samba Member
Posted: Fri Feb 07, 2014 8:44 am Post subject: |
We've been lucky to find two Pagid sets on fleabay. They don't come up often. RockAuto has some Bendix relined sets, and some Raybestos old stock sets, not many left. To be frank, quality shoes for buses are getting harder to find. Scott at German Supply sells one brand that works well if he still has some. I would get the Chinese crap off the bus and ask for a refund. This issue started back about 2005 if you read the old threads so this is nothing new. If you want to get 100% braking, use the highest quality you can find, and make a call to the vendor before ordering to make sure they aren't substituting. Lots of these places don't stock the part, they order from a wholesaler and many times even they are not told the source has changed. Meaning that say WW or BD has ordered Pagid shoes for 20 years from Wholesaler A. One day a customer complains that he ordered Pagid but got an off brand. WW or BD calls the wholesaler and finds that Pagid is no longer available. They call around and no one has it so they find a line like Enduro and start selling those. One day the same happens and they find that some cheap Chinese shoes are being used now and that the Enduro are no longer available. So call before you order - ALWAYS. Or get them from Scott, he works on VW buses too so he keeps stock on hand of many of these things. Or fleabay if you get lucky etc. Try to stay with ATE, Bendix, Pagid, Raybestos etc. on these old buses if you can find them. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Feb 07, 2014 9:40 am Post subject: |
crappy parts are everywhere and this isn't about supplier "A" or "B" really, but the difference between some suppliers and others is that they actually look at the parts when they're put into inventory and also when they're packed and shipped. as vendors get larger it's harder and harder to maintain this kind of quality control, before you catch the issue many people may already be affected. brake shoes have gone way down in quality, like everything else, but there's no logical explanation why the carrier (the metal part) of a brake shoe would be wrong, these are industry standard specifications and should be very close to the same no matter who manufactures the shoes.
i think what's happening here is some manufacturer is taking a shortcut and using a carrier that isn't actually for an S421 shoe but is 'close enough'. shameful really that 'close enough' thinkers are deciding for us what quality of parts we receive. some of the brake shoes we have are made in china and they're actually quite good, but we do look at them and in many cases install them before we make them available for sale. we have some other shoes made in scandinavia that are not as good as the chinese ones.
a clear illustration of the decline of brake parts is here in an ad for some NOS genuine brake pads, there is a massive difference between readily available current supply pads and what used to be available from the VW dealer. you can easily see how much better the manufacture and finishing is on the genuine shoe versus a generic economy shoe. of course for genuine you always had to pay more, so this has driven quality parts out of the marketplace.
http://www.thesamba.com/vw/classifieds/detail.php?id=1594531 _________________ SL
Last edited by germansupplyscott on Fri Feb 07, 2014 9:50 am; edited 3 times in total |
MrBreeze Samba Hitman
Joined: October 06, 2002 Posts: 5541 Location: Lawn Guyland, Noo Yawk
Posted: Fri Feb 07, 2014 9:45 am Post subject: |
"Close enough" works for a dashboard screw, not brake parts. Lordy. I notice it everywhere, nothing fits right or is up to standards in a lot of businesses now. _________________ -=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
Waves2day Samba Member
Joined: October 15, 2008 Posts: 408 Location: Bay Area, CA
Posted: Fri Feb 07, 2014 8:03 pm Post subject: brake assembly |
I have never argued with an employee of the DMV
Brake spring installation answer
If you theorize the return spring losing its effect when the primary lining wears then you will know why it is supposed to be installed the way it is in the repair manual.
It will NOT interfere or have a chance of falling out in front of the linings.
As for painting hubs, Drums or lugnut area it's been proven that this will not only produce a poor torque spec on the other fitting parts but is also dangerous.
Paint will move (chip) when applied unevenly and cause runout to change
The proper way to do this is to wire brush the hub and apply a thin coat
of multi-purpose grease on the contact surface. Before installing either the brake drum or brake rotor. _________________ V.W.owner since 1967 |
Posted: Fri Feb 07, 2014 8:26 pm Post subject: Re: brake assembly |
old DKP driver wrote: |
I have never argued with an employee of the DMV |
Many have tried, few have succeeded.
Thanks for the info on the brake spring. Like I said, next time I have the drum off I'll swap it around and put it in the right way. Everything is in storage until Spring anyway and I always go over the brakes when I pull them out for the season. At least I'll never make that mistake again. I'd have to look back at the pics, but that was probably the way it was when I took it apart which is why it went back together that way. Everytime I do rear brakes now I'll think of you when I'm putting that spring back in.
Paint will move (chip) when applied unevenly and cause runout to change |
I'd love to see something to back up your claim. Paint on a hub isn't going to chip when it's between the hub and drum. There's nothing there TO chip it. I'll snap a pic when I pull the drums in the spring, guarantee they look exactly like they did in that pic. I always clean and paint when I do the rears on a Bus for the first time and in over 100K cumulative miles driven I've never had a brake issue or any paint chipped off of the hub. _________________ First Trip in the RustyBus:
borninabus wrote: |
notchboy wrote: |
EverettB wrote: |
Posted: Fri Feb 07, 2014 10:40 pm Post subject: |
Memory isn't the greatest but it seems as if the spring installed correctly pulls the shoes in the right direction and tension against the bumps on the backing plate. With the spring reversed it doesn't. _________________ 71 Superbug
71 Westy |
Posted: Wed Feb 12, 2014 1:56 pm Post subject: |
Well now, this is truly disgusting ...
I just received another set of brake shoes for 73-79 bus, sent by Beck/Arnley Worldparts Inc, #0811489, ordered from rockauto.com, and they
are defective in exactly the same way as my TCM shoes. Even worse, because the linings are noticeably thinner. Made in China, of course.
There is no way these shoes I'm getting are correct, the big return spring is under so much tension it won't sit straight in the shoe holes (keeps trying
to "unwind"). Genuine VW return springs, too.
Again, it would be swell if someone could post a photo/template/whatever of a known-to-be-good late bus brake shoe, maybe we can get these
manufacturers/dealers straightened out.
I have another set of shoes on the way, different brand, also ordered from rockauto.com. We'll see pretty soon ...
If we can't get proper brake shoes, then we'll all have to park our busses permanently, ya know ... _________________ '67 bug: seized by the authorities
