llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Tue Apr 25, 2017 10:10 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
the Utahn wrote: |
davevickery wrote: |
OK. The manufacturer gets to set it's own min/max, so they are just being more conservative than most other brands that allow up to a 7" rim. The hunt continues I guess. |
It's the only tire of that size that I have found that will not spec a 7" rim - very strange. Half of me wants to just order and run it - I'm pretty sure I'll never have a problem. But I don't like cheaping out on tires, and I haul my family around in this... |
If they say that and you go ahead and purchase you would probably be fine, but it will for sure void any warranty.
I was in your area for Spring Break- Capitol Reef. So beautiful and not so crowded. Do you think am 85 Westy with no lift kit would make it out to Cathedral Valley? We definitely want to return.
rhbooz Samba Member
Joined: April 25, 2017 Posts: 1 Location: Connecticut
Posted: Tue Apr 25, 2017 12:42 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
My 1991 Vanagon Camper GL has one of the last sets of 205s that were sold here in the US. I want to keep the look of the original aluminum wheels. Will the 195s work or do I need to go the whole new wheel/new tire size route? I bought the car new and am a bit of a purist so just making the change from 205s is traumatic.
THANKS (especially if this is a stupid question).
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Tue Apr 25, 2017 4:46 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
rhbooz wrote: |
I posted these tires below that have all the specs and stiff sidewalls which is super rare in a 205/70-14 size. And a nice semi-aggressive all season tread and C load 100 rating. But you can still find 195R14 sizes which are very similar in size and specs (slightly taller and narrower).
Tires are not guaranteed forever, they usually say 7 years, but anything over 10 years old may be pushing your luck, moreso in hot climates. The date code will be on the side of your tire like 3609 is 36 week of 2009.
Westaru Samba Member
Posted: Tue Apr 25, 2017 6:16 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
llilibel03 wrote: |
the Utahn wrote: |
If they say that and you go ahead and purchase you would probably be fine be it will for sure void any warranty.
I was in your area for Spring Break- Capitol Reef. So beautiful and not so crowded. Do you think am 85 Westy with no lift kit would make it out to Cathedral Valley? We definitely want to return. |
I keep thinking it would be fine - with that size of tire and tread width vs the rim. The fact that they don't approve may have something to do with the construction of the tire, or it may have more to do with the common sized rims in Europe.
Sending you a PM. _________________ 1984 'Westaru' Vanagon Westfalia EJ22
@UtahWestfalia on IG |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Paulbeard Samba Member
Posted: Thu Apr 27, 2017 6:13 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
Huh. Wish I had seen this ten minutes ago. Les Schwab will do a set of 4 Hankook RA18s for $560, all in ($104/each, plus installation/mounting/etc.). I'll call tomorrow and see if they can order these. All their online options are way too puny, loadwise (even they are suggested for the Vanagon camper). _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Fri Apr 28, 2017 9:07 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
Just used Google search to find low price on Vredestein 195/65/r16 (C rated) and this site popped up with them... simpletire.com, like $115 +11/tire to ship. Looking down at the bottom of their web site, I noticed they have a section that has comparable tires... I don't know about anyone else, but doesn't $35/tire sound too good to be true? (add shipping tho)
https://simpletire.com/zeetex-195-65r16-z32174-tires _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Apr 28, 2017 2:36 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
Looks like there is an interesting tyre over in the UK, a winter version by Pirelli called Carrier Winter tm. No idea on price, but they have as close to a stock diameter as I've seen. I might be off on my math tho.
https://www.pirelli.com/tyres/en-gb/car/find-your-tyres/products-sheet/carrier-winter#/overview
Look under the Size Range under 16", you'll see 195/60R16 99T
Way way off for me, both in terms of that I can't purchase them locally, and that, in general Pirelli are already way out of my price range.
They are super sweet looking tho.
The Summer version look OK too, just called Carrier tm.
https://www.pirelli.com/tyres/en-gb/car/find-your-tyres/products-sheet/carrier#/size-range
195/60R16C 99H
I calculate these at a diameter of 25.2 inches. I think most sources quote a 25.3" stock diameter. Some quote 25.5" _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Sat Apr 29, 2017 10:07 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
How about these Pirelli's? Scorpion ATR 96T 205/70 r15, all terrain, and not terribly expensive. I'm assuming the "T" is for truck as in the listing they say light truck tire. Without the 9% derating it should be OK.
https://www.tirerack.com/tires/tires.jsp?tireMake=...TR5SCORATR
Mark Lewalski Samba Member
Joined: June 19, 2010 Posts: 406 Location: Safety Harbor, FL (Tampa Bay)
Posted: Sat Apr 29, 2017 10:13 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
While the information may be somewhere in this topic, I couldn't find it...
- I've got an 87 Weekender with a 2.1WBX.
- Have a set of CLK 7.5x16 rims to put on maybe by the end of this year.
- Live in Florida so I need good dry and great wet performance.
- Mostly paved driving although may go dirt/gravel roads at campgrounds.
- I like the aggressive look of A/T tires but realize they are probably overkill.
- I will be getting GW No Lift progressive springs as part of the upgrade (which I believe will give added clearance since I'm not a camper).
I'm interested in either the:
Grabber AT2 in 215/65r16
or the
Nokian eNTYRE (or 2.0) in 225/60r16
Spacers probably needed for both choices I would think.
Anyone have any experience with either tire in this size and my van setup?
Thanks,
Mark _________________ '89 Vanagon GL Wolfsburg "Bluestar" (given to and owned by my son now)
'87 Vanagon Weekender
'74 Thing |
kamzcab86 Samba Moderator
Posted: Sat Apr 29, 2017 10:28 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
The T in 96T is the speed rating. The 205/70R15 is an SL, or standard load, which means reducing 9%, according to the rules*. The LT235/75R15 on the other hand, is a designated light truck tire size, which does not need to be reduced.
*Which should be changed, IMO for tires built specifically for trucks and SUVs. _________________ ~Kamz
2016 Golf GTI S
HackAl Samba Member
Joined: March 12, 2016 Posts: 338 Location: Bergen County, NJ
Posted: Sat May 13, 2017 6:58 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
So I ordered GW 16" rims which are due any day now.
I had an Amazon Gift Card and free shipping so I'm leaning towards these:
https://www.amazon.com/gp/product/B0100OCAW6/ref=o...PDKIKX0DER
Nokian eNTYRE All-Season Radial Tire - 215/60R16 99V
A reviewer on Amazon used them on his/her Vanagon and seems to like them. However, I did not see these specific tires listed here: http://oldbluesblog.com/files/VanagonTireSpecs.pdf
Thoughts or suggestions? I won't be using in snow.
Thanks.
Al _________________ 91 Westy.
Ever consider temporarily trading your van? Join the list. |
HackAl Samba Member
HackAl Samba Member
Posted: Sun May 14, 2017 6:20 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
I think they would be fine. A commercial tire with a c or d load would be more stable in crosswinds and are tougher offroad but they cost twice as much. I had a similar Nokian tire, made by Cooper in Ohio, and they are very good and the price is good. The load rating is fine at 99. You door sticker shows a smaller 97 rated tire so these are totally fine.
The.GW 16 wheels are wide so a 215 tire is probably a good match and that tire isn't too tall. As you can see there aren't that many choices when you actually start to look. |
HackAl Samba Member
Posted: Sun May 14, 2017 7:01 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
Great. I just ordered them.
I had learned that they'd work with 16" rims anywhere between 6-7.5.
Dave,- you've been a big help to me since I'm joined. I'm very grateful.
(And yes, lack of choices surprised me a little.) _________________ 91 Westy.
Jamo7 Samba Member
Joined: September 25, 2014 Posts: 124 Location: Seattle
Posted: Mon May 15, 2017 8:32 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
Good morning.
Even though I have BFG TA/KO's in 195/75R14, I can't seem to get 195R14s out of my mind as my engine seems up to the task and I'd like to reduce RPMs ever so slightly.
I happened upon this list of commercial tires on tires-easy.com and thought I'd share it with you all:
https://www.tires-easy.com/tires/195-Blank-14?filtering=,price,categoryPath,Commercial
Two of the eight listed tires are already on Kam's wonderful pdf, and many are twins in terms of tread. All of the listed commercial tires are stated to be 106/104 load index.
I was surprised to see so many 14 inch options.
Have a good one,
James _________________ '84 Westy 2.1 wbx |
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Wed May 17, 2017 8:49 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
Mark Lewalski -
I dont have the same van or setup as you (I have a westy with 17" rims) but I did install the Nokian Entyres 2.0.
I have no qualms with the Nokian 2.0's, they are my "non winter" tires and I have put 3-5k mi on them.
But to be honest, I feel like they are a set of tires. My comparison point was the original 14"rims w/ Blizzaks installed. Which I also felt were fine tires.
So probably not a lot of help but if I were to do it again would I get the Nokain eNyre 2.0's? Yeah. Nokians are reputable, the load rating is great, and they fit my 17" rims (the 17" rim w/ proper load rating is the limiting factor for tires for me....for i have the stock WBX so i dont want to change wheel diameter).
Hope it helps
Mark Lewalski wrote: |
or the
Nokian eNTYRE (or 2.0) in 225/60r16 |
_________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Wed May 17, 2017 6:24 pm Post subject: Re: What TIRES fit? The ultimate tire thread! |
For what it's worth, I found cheap 8 ply D load range 14" tires that would fit the early Vanagon.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
project68 Samba Member
Joined: July 22, 2007 Posts: 43 Location: British Columbia, Canada
Posted: Thu May 18, 2017 2:20 am Post subject: Re: What TIRES fit? The ultimate tire thread! |
Tracked down some BFG KO2's in a 215/65/16. Was a bit of a chore to find a set through one supplier for ease warranty. But I've got them on the Doka and they look good, might have been able to fit something a little bigger but not sure.
