freeze Samba Member
Posted: Wed Feb 12, 2014 12:13 pm Post subject: 2002 Eurovan Sliding Door - broken? |
I have a 2002 Eurovan Weekender. I noticed that the sliding door was not locking with the remote. I manually locked the door and it worked, but when I tested the door to make sure it was locked, the lever kinda went in and then got stuck. The door then would not unlock with the key, it was just stuck locked with the handle lever depressed. So I stuck a butter knife into the handle and gently pried it open. Then I could unlock the door and it worked fine. It still will not lock with the remote, only manually, and it jams any time you try to open it with the door locked.
When I try to lock with the remote, it goes about halfway down, then appears to be blocked by something. When I lock with the key, it goes down fine.
Thanks for any help on this! |
Xtremjeepn Samba Member
Joined: October 21, 2012 Posts: 1539 Location: Colorado
Posted: Wed Feb 12, 2014 12:59 pm Post subject: |
I'm pretty sure there are 2 push rods that control the door lock. One from the "button" and one from the remote door actuator. Sounds like one of yours is loose, bent, stuck. Happens sometimes on all sorts of cars for various reasons.
Pop the door panel off and take a look!
Might want to make your location a bit more specific than "United States" Then we might be able to offer better advice on things like this. Could it be rusty from being in the NE? Or maybe a water issue from being in the PNW or a broken plastic rod connector due to the extreme cold in the middle of the country? Amazing how location can help diagnose something as simple as this. And maybe someone close knows how to fix it or has the right part! |
freeze Samba Member
Posted: Wed Feb 12, 2014 10:54 pm Post subject: |
I updated my location. Thanks for the tips. I will take a look. |
Posted: Wed Feb 12, 2014 11:33 pm Post subject: |
May also want to ask this question on the yahoo group "ev_update". Lots more Eurovan activity there and several members in the Seattle area!
Good luck. |
Suthern Samba Member
Posted: Sun Mar 27, 2016 5:24 am Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Old thread but having this exact issue this morning and wondering what you discovered? |
Jonwid Samba Member
Joined: August 18, 2013 Posts: 163 Location: Long Beach
Posted: Sun Mar 27, 2016 7:00 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Suthern wrote: |
Now also experiencing this on the 03 EV GLS sliding door. Pretty sure we broke a spring or two after all these years.
Will let you know what I find.
Anyone have the door panel removal steps???
(Always something on ol' Greta.) |
Posted: Mon Mar 28, 2016 11:23 am Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Bentley shows removal of lower sliding door trim panel as pretty straight forward operation. Looks like three screws - one on center stop then two more on top of panel - about 1/4 of the way back then all the way in the back. Then pry off.
I was reading yesterday that there are rubber bits that are factory glue on - sometimes the adhesive fails and the panel can be a challenge to reinstall. One post included the approach of adding screws to refasten the panel. Should be interesting...
Here is a good post I found too:
http://www.thesamba.com/vw/forum/viewtopic.php?t=630745 |
Posted: Mon Mar 28, 2016 12:22 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
So - I went to go get a look at this with the thought of shooting some Lithium grease into down the manual locking hole and seeing if that rid me of the issue (which seemed like binding of some sort) prior to pulling panels.
I can't say for certain what 'fixed' it but I can tell you that after lubing everything I could get to I had mad no progress.
I was fiddling with the panel as it was just a touch loose (maybe a quarter inch) in the upper front corner. I pressed it in the upper corner and then down the top. Felt a couple of positive clicks and it now seems fully seated. Now the door locks is engaging as it should.
So - maybe trying to press your panel firmly on and see if that fixes things for you. If not maybe spray some lube around. I went down the manual lock, interior and exterior door handle and latching mechanism at back of door. Will keep thread posted in hopes my 'fix' is long term. |
Jonwid Samba Member
Posted: Mon Mar 28, 2016 5:53 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Yeah, it turns out that the inner panel cover was actually causing the locking mechanism issues which was basically binding the lock mechanism.
I, too, noticed that the panel was not seated flush to the frame and appeared to be loose at the top left edge, just below the inside door release handle.
I found only two screws holding the door panel in place, both about mid-level. One in front and one on the back edge.
I went to lift up the panel and immediately I heard a bunch of plastic pieces fall off to the floor. Turns out that all of the plastic mounting plate tabs that grab onto the plastic pin retainers had come off of their factory glued positions on the back side of the door panel. Yup. All of them.
So the only thing holding the door panel in place was just the two screws and the top metal latches on the window sill!
I guess that 13 years of sliding door closure had eventually taken its toll on those glue joints holding the door panel in place.
I experienced a similar issue with the plastic tab mounts coming loose on the rear hatch gate inner panel when I had a lock mechanism issue there also that I needed to repair. To fix that panel, I just used some JB Weld on top of the original glue blobs, which happen to make a nice template for placing the plastic tabs back in exact position. Almost two years later and no issues with that panel repair.
So, I'm going to just do the same thing on the slider panel repair: stick the plastic mounting tabs back into place onto the panel with some JB Weld and then re-hang the panel.
The locking mechanism works perfectly fine with the panel off, by the way. Ill definitely put a little lube on the mechanism while it's accessible though. |
Posted: Tue Mar 29, 2016 5:42 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Yep - lose panel definitely binds the locking mechanism on the sliding door. Funny how such a small movement in the panel - 1/8" to 1/4" AWAY from the door in the top left corner (next to the manual lock) impacts this.
My panel keeps peeling away and I keep pressing it back. I don't really want this to become the norm for securing the van and would love a less invasive fix than panel removal (based on what I've read you end up with a bunch of hard to adhere rubber bits and blah.) Not that it can't be done, just have enough other things to do right now.
So - I've been thinking of either:
Industrial strength velcro (but concerned with thickness - I might get everything set up and not have clearance behind the panel to do more than hold it 'out of place' thereby binding the lock.)
Pinning it with very small screw but lots of risk if I do this blind.
Anyone have a good picture of panel off sliding door they could share? Bentley drawing turns to blur when zoom zoom. |
Jonwid Samba Member
Posted: Wed Mar 30, 2016 1:54 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Suthern wrote: |
I'll take some pics of the door and panel and my repair process this afternoon.
Really it's not all that complicated to just take off the panel and re-glue on all the plastic tabs that hold the panel to the left leg locking pins. |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1267 Location: Bethlehem, PA
Posted: Wed Mar 30, 2016 2:04 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
What I found that works great for gluing those tabs back on is windshield adhesive. You can glue just about anything with it and it cures pretty quick. It only holds in most of the glass in your EV and just about every car today. |
Posted: Fri Apr 01, 2016 12:26 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Jonwid wrote: |
Thanks for offering that - hope your repair is swift and lasting! |
Posted: Fri Apr 01, 2016 12:29 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
jjvincent wrote: |
Encouraging to hear you've had success with windshield adhesive. I've come across a couple of posts - one guy said he couldn't make anything stick another said he did it with JB Weld.
How about 3M 08693?
http://www.amazon.com/3M-08693-Urethane-Windshield...d+adhesive |
Posted: Sat Apr 02, 2016 6:18 am Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Suthern wrote: |
jjvincent wrote: |
How about 3M 08693?
That will work. Just wear gloves because that stuff sticks to everything and takes a while to get off of your hands. |
Jonwid Samba Member
Posted: Tue Apr 05, 2016 7:52 am Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Here are some pics of the door panel off and the tabs and pins.
JB weld held on to most of the glue spots the first time. But I did have a couple tabs pop off from the original glue spot. The JB clung to the back of the plastic tab, but completely separated from the old glue blob backing.
This lengthened the repair time because I had to reglue with more JB on those same tabs twice. Third time was the charm. Plus, putting the panel back in is somewhat frustrating. You have to start with the top sill metal brackets and get those tucked in just right, then carefully work your way around the door. All from inside the cabin with the door opened a crack to get everything positioned. You may need to remove the middle seat/bench for better maneuvering.
I recommend popping out all the plastic pins very carefully and definitely use a nice plastic trim panel removal pry bar tool so you don't damage the pins. Harbor Freight sells these panel removal tools in a cheap but good set in the automotive section.
Put all of the pins into the plastic tabs when you are ready to re install the panel. Then after the top sill is hung and secured under the metal spring clips, carefully work your way around the panel guiding the push pins into the hole and press firmly until they click back in place.
Although leaving the original glue blobs in place makes a Great template for the plastic plates, what I might recommend is scraping off the inner portion of the glue blob down to the cardboard backing of the door panel. That would offer better adhesion for the JB Weld. As I mentioned JB holds the back of the plastic tab just fine, but it can still mysteriously detach from the surface of the old glue blob on occasion.
So far, the panel is holding nicely, and it's not causing any interference with the door lock or the latch. So problem licked for now. |
Posted: Wed Apr 06, 2016 5:31 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
Good job - sounds like it was a bit fidly which is consistent with other people's experience.
I may give the automotive windshield adhesive a try - have used JB Weld with success in other places and sure I could do the same as you have.
Am I missing something on the pics - can't see any, maybe need a link? |
DRNewcomb Samba Member
Joined: February 21, 2013 Posts: 34 Location: Mississippi
Posted: Thu Jun 09, 2016 7:18 am Post subject: Re: 2002 Eurovan Sliding Door - broken? |
I have recently experienced an issue with my sliding rear door not closing properly. I removed the trim panel and discovered that age and heat had broken the glue bonds holding the the black plastic clips to the panel. This allowed the panel to become loose, which somehow interfered with the door's function. I'm looking for suggestions on what sort of glue to use to reattach the clips. |
dixoncj Samba Member
Joined: June 17, 2004 Posts: 1083 Location: Charleston, SC
Jonwid Samba Member
Posted: Fri Jun 10, 2016 8:39 pm Post subject: Re: 2002 Eurovan Sliding Door - broken? |
We were having issues with the slider not locking on the 03 GLS. I took off the whole inside door skin and reglued all the plastic tabs. Ultimately, that didn't help solve the non-locking problem.
What finally helped the non-locking problem was this: 2 screws placed just so into the door to hold the panels tight to the metal door frame. Locking problem completely solved, and it doesn't look too bad!
