Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Fri Feb 14, 2014 7:12 pm Post subject: Cylinder/Head mating surface issue |
I just received a pair of new heads opened up for 94mm and no step.
Am I just drunk, or is that right side going to cause me grief with sealing the cylinders?
The other cylinder and head are fine, but this one isn't just visibly rough, but to the touch as well
I'm not bashing the vendor as they've been really good to deal with, and I'm waiting to hear back from them to see what to do next to resolve this. I just want to know what would cause that?
turbobob Samba Member
Posted: Fri Feb 14, 2014 7:20 pm Post subject: |
Let them correct the problem before you hang them out to dry, but that's all wrong. It's got nothing to do with you being drunk _________________ Robert Young
ForcedPerformance.net |
Mark Samba Member
Posted: Fri Feb 14, 2014 7:27 pm Post subject: |
I agree, mistakes happen and I am not laying blame or naming names. I have no reason to believe it was anything other than an honest slip up. Just wanted to make sure this was an actual issue, thanks. |
75smith Samba Member
Posted: Fri Feb 14, 2014 9:08 pm Post subject: |
either they cut with a worn tool, or they tried taking too much at one time, too fast _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Fri Feb 14, 2014 10:28 pm Post subject: |
It's called chatter. Caused by non-rigid mounting of head or cutter, blunt tool, too sharp tool, too wide or deep a cut, lack of lubricant, bad chosen rpm for harmonics, worn spindle bearings......and probably a combination of more than one.
Just lap your jugs into your heads with a fine grinding paste until you get a nice shiny band. _________________ "...swingaxle...transaxle...same diff." |
vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Fri Feb 14, 2014 10:31 pm Post subject: |
Send it back to them and they should clean it up, it will only take 5 minutes _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
jason Samba Member
Posted: Fri Feb 14, 2014 10:57 pm Post subject: |
I can't believe they sent them like that. Must have been dark or the QC guy was gone. |
AlteWagen Troll
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7213 Location: Videbaek Denmark
Posted: Fri Feb 14, 2014 11:59 pm Post subject: |
fastfil wrote: |
Aggre.
But they should never have sent that one out. I too suggest that you let them correct the problem. they will need bothe heads to shim them the same amout so they are even.
It - can - be corrected the way Fastfill´s describing. But its not the way to do it on new part IMHO.
T |
Mark Samba Member
Posted: Sat Feb 15, 2014 12:51 am Post subject: |
Lots of input here. Yeah, lapping would be ok for slight imperfections, and this is not one of those instances.
Like I said, no need to slag anyone. I'm sure the vendor will make good on this and it will get sorted. I only wanted to know what could have caused that in the first place. Go about your business, nothing else to see here |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Feb 15, 2014 9:15 am Post subject: |
75smith wrote: |
either they cut with a worn tool, or they tried taking too much at one time, too fast |
Ditto... Markings are from cutting tool "chatter"....
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sat Feb 15, 2014 4:35 pm Post subject: |
Oh, come on! Easy to do - a few too many pints at lunch and need to get the job done before you can have a toilet break...
I certainly wouldn't try to lap that out. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sat Feb 15, 2014 6:10 pm Post subject: |
It's easy to make a mistake and ruin parts you are machining, but it's hard to understand why that would not get caught prior to shipping it out. _________________ Robert Young
Posted: Sat Feb 15, 2014 6:57 pm Post subject: |
Do you know how bad your vision can get if you drink half a dozen pints of beer quickly? _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Mark Samba Member
Posted: Sat Feb 15, 2014 8:00 pm Post subject: |
Turns out that s#*! WILL buff out.
I decided to try lapping it, (why not, had the lapping compound handy) and it looks like that did the trick.
The vendor did offer to correct it or cover the machining cost to have it fixed locally, but I'm happy with how this turned out. Now about those beers...
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Feb 15, 2014 9:16 pm Post subject: |
britegreenVWSB wrote: |
Quokka42 wrote: |
Do you know how bad your vision can get if you drink half a dozen pints of beer quickly? |
Sorry, I can't see well enough to hear what you said! |
Posted: Sat Feb 15, 2014 10:24 pm Post subject: |
SBD wrote: |
Quokka42 wrote: |
Hooo boy. I love this site.
_________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sun Feb 16, 2014 2:45 am Post subject: |
Mark wrote: |
Don't forget to lap the other bore to EXACTLY the same depth or you will have a loose cylinder |
