fastfil Samba Member
Joined: November 25, 2006 Posts: 356 Location: Sunshine Coast, AUS
Posted: Sun Feb 16, 2014 2:58 am Post subject: |
The lustre of machined aluminium always makes surface imperfections look worse than they are. Digital cameras highlight it even more. _________________ "...swingaxle...transaxle...same diff." |
flyfisher111 Samba Member
Joined: January 21, 2014 Posts: 39 Location: Level Green
Posted: Sun Feb 16, 2014 7:38 am Post subject: |
I'm confused who is drinking the beer? I been a machinist (not auto) for 30 years. What I see is disgusting. Its not carelessness or a mistake, it borders on criminal. For crying out loud they didn't even bother to deburr the holes. I would take them up on the offer to repair what they have done. If you don't have the areas where the cylinders seat on the same plane you could have a leaking or a warped head. Man that grinds my gears, sorry! |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Feb 16, 2014 7:46 am Post subject: |
I am kind of wondering if all the little ridges will make dozens of hot spots into combustion chamber ... I personally would not have accepted the parts.....
croSSeduP Samba Member
Joined: June 13, 2004 Posts: 1106 Location: Western Washington State
Posted: Sun Feb 16, 2014 11:47 am Post subject: |
Dale M. wrote: |
Dale |
I didn't say anything earlier, but that's buggin' me too. I think I'd have both chambers flycut now the exact same depth, and have the other head checked to make sure the depth/cc's are the same. _________________ Please check my '67 sedan project progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=502253&highlight= |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sun Feb 16, 2014 11:32 pm Post subject: |
I'm not bragging, but I might be able to produce something that ugly in my garage... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Mon Feb 17, 2014 8:39 am Post subject: |
Dr OnHolliday wrote: |
I'm not bragging, but I might be able to produce something that ugly in my garage... |
Fine I will bragg, I can produce a better job in my garage , I do mine on my mill and its easy to get some chatter but that's ridiculous , my last set chatterd just a little but not like that ... if that's a machine shop job , its shitty... |
Blue69Baja Samba Member
Joined: September 04, 2008 Posts: 1065 Location: Fair Oaks
Posted: Mon Feb 17, 2014 11:32 am Post subject: |
Getting rid of the step does require a shim.. I know some folks use a copper shim here and then the shim between the block and Cyl to keep Compression ratios correct... At least that's my understanding.
Having that very thing done on my 1915 right now. Fly cut the block and heads...at Vallero's.
I concur that the workmanship on those heads is beyond awful... Nice that the shop stepped up to the plate and offered to correct the issue. Problem is, did he also do a valve job for you? OHHHHH man!
Jim _________________ 69 Baja with a 1914...
72 Super 100% orig...W/ factory air... 56,000mi
Even the spare is original.. |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Mon Feb 17, 2014 12:08 pm Post subject: |
Let's put this post to bed already. Good grief.
I lapped all the cylinders, (something I do for all builds anyway) and double checked for equal cylinder depth. They were all spot on, no need to do flycut any further.
I've already disassembled the heads to check & clean the valve components, (again something that I do before every build) and the valves all seat fine, tested with rubbing alcohol for leaks.
As well, I will debur any ridges in the compression chamber that were left from the flycutting, no big deal.
No, I'm not pleased with the machining job and it should not have left the shop like that, but the vendor offered to make good on things. After further investigation I discovered it was nothing catastrophic that couldn't be sorted and lapping the cylinders proved the surface wasn't as bad as the photo indicated, which measurements confirmed.
I wouldn't think to install any part straight out of the box, and this is a good example of why you check/measure and ask questions and use some critical thinking when unsure about something. In this case things weren't as bad as they first appeared. No need to overthink this. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Feb 17, 2014 1:53 pm Post subject: |
Sorted! |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Mon Feb 17, 2014 1:59 pm Post subject: |
I agree Mark, but we're just having a bit of fun with it. I'm glad you didn't name the Vendor, as they stepped up to the plate, and it sounds you are more than capable of tidying the job up yourself. If you polish the chambers don't mention it here, or this thread will never end!
P.S. I'm the one drinking the beer, not much else to do as I haven't got a new job yet so I can't spend any money on car parts. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Mon Feb 17, 2014 2:49 pm Post subject: |
Quokka42 wrote: |
P.S. I'm the one drinking the beer, not much else to do as I haven't got a new job yet so I can't spend any money on car parts. |
You could if you quit drinking beer and saved that money for car parts.
Posted: Mon Feb 17, 2014 4:55 pm Post subject: |
Sacrilege!
Besides, hanging around the bar asking people for money for car parts would be a very slow process... and I'd probably run out of bars, too. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
nsracing Samba Member
Posted: Fri Feb 21, 2014 2:42 pm Post subject: |
Chatter marks! MUst be a newbie "machinist" let loose at the Bridgeport.
The quill speed is way too fast, too much tool overhang.
If you don't have a Wohlhaupter boring/facing head, then you need to at least do it w/ a Criterion head. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
