hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Sat Feb 22, 2014 5:05 pm Post subject: |
That cabinet looks great! Just to be clear... it is secured in place by the mounting brackets that normally hold the jump seat, right? If so, I want a storage only version!
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Sat Feb 22, 2014 5:47 pm Post subject: |
Nope. That was the original plan, but the cabinet turned out too close to the seat belt housing. It's bolted to the floor. What's another few holes?
Jeff |
Posted: Sat Feb 22, 2014 6:50 pm Post subject: |
jimeg wrote: |
Do you have any pic's of your motor mount set up? |
I will, I'm in the middle of another diesel conversion and haven't had chance to put my van on a hoist. I have 3 hoists and they're full every day of he week. I need to make some me time
Jeff |
jimeg Samba Member
Posted: Sat Feb 22, 2014 7:54 pm Post subject: |
Jeff's Old Volks Home wrote: |
jimeg wrote: |
Jeff |
Great. Thanks, Jeff. Really enjoying your build thread! You've re-inspired me to dust off the AAZ I have sitting on the engine stand in my shop - if I can survive the resurrection of the other 75% of the van. Slow and steady she goes. _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490 |
SCP_Austin Samba Member
Joined: November 04, 2009 Posts: 366 Location: Tacoma, WA
Posted: Sat Feb 22, 2014 8:36 pm Post subject: |
Was the cabinet one-off or are there plans out there? That is exactly what me and the lady are looking for behind the drivers seat...
I am handy...and love it! _________________ #leftlanelife |
bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Sun Feb 23, 2014 3:51 am Post subject: ultimate |
The plans were mostly in Jeff's head and then on a piece of graph paper.
He had the measurements required for the space and a picture in his mind. The rest I made up as I went!
I have made quite a bit of stuff over the years with an emphasis on decorative tea boxes and jewellery boxes. In the end this was just a box. Your have multiple choices for joinery and I chose dado and overlap edges for the most part. Glued and screwed for strength then all that covered with laminate.
Brian _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Sun Feb 23, 2014 5:25 am Post subject: |
Nice build. The combination of syncro, weekender, pop top and Turbo diesel is Perfect _________________ 1991 VW Multivan syncro 1,9 TD |
Posted: Sun Feb 23, 2014 5:44 am Post subject: |
OddN wrote: |
Nice build. The combination of syncro, weekender, pop top and Turbo diesel is Perfect |
Thanks! It's the van VW didn't make... My dream van for sure.
Jeff |
OddN Samba Member
Posted: Sun Feb 23, 2014 7:55 am Post subject: |
OddN wrote: |
Jeff |
Yes I know Mine too... My syncro 16" Multivan pop top AAZ is a homebrew combination of my favourite parts. Its even Tizian red. _________________ 1991 VW Multivan syncro 1,9 TD |
Posted: Sun Mar 02, 2014 11:13 am Post subject: |
So I've added some pictures of my motor mounts. I've done 20 or so diesel conversions and I've been having good success with the KEP plate/ flywheel and clutch. I start with 2wd bars, regardless if it's a syncro or not. I fabricate my own custom mounts to join the block to the mounts. So far, they've been great, no vibrations, or mount failures. They're over built, from an engineering point of view complete over kill.
_________________ www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab |
jimeg Samba Member
Posted: Sun Mar 02, 2014 11:50 am Post subject: |
I do almost exactly what he does in his video. Except, the laser beam is about half the distance to the centre of input/output flanges. I bolt the front of the transmission in the factory location using Wurth rivet nuts. I hang the the engine from the rear with a threaded rod/hook fixture I made years ago, adjust the the height up or down/left to right as need and measure up and build the mounts. It allows me the freedom to install whatever turbo I choose, I'm limited to what clears the motor support brackets. So far so good.
Just recently I became an Overland parts dealer and have started using their bell housing and mount set up. I have 2 on the go right now, I'll report back if I'll keep going that route or move back to the KEP kit.
Jeff _________________ www.jeffsoldvolkshome.com
2002 Smyth Ute TDi
Zeitgeist 13 Samba Member
Posted: Sun Mar 02, 2014 3:01 pm Post subject: |
Those mounting arms are USDA Grade A Beef--nice! It looks like we might be able to use the arms I built for jimeg's 15 degree 1.8L on his AAZ, so that's still looks like an option. I like the idea of running a steel oil pan that you can easily drop if needed. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun Mar 02, 2014 6:36 pm Post subject: |
Zeitgeist 13 wrote: |
Those mounting arms are USDA Grade A Beef--nice! It looks like we might be able to use the arms I built for jimeg's 15 degree 1.8L on his AAZ, so that's still looks like an option. I like the idea of running a steel oil pan that you can easily drop if needed. |
Instead of what other kind of pan on a 15 degree? Will the AEB 1.8t pan bolt on an AAZ? Hmmm...
2002 Smyth Ute TDi
Posted: Sun Mar 02, 2014 8:22 pm Post subject: |
Nah, the steel pan reference was in regards to the difference between 15 degree and 50 degree installs. The 1.8 engine is just an RV code from a Mk2 Golf/Jetta _________________ Casey--
y u rune klassik? |
Posted: Mon Mar 03, 2014 4:16 am Post subject: |
Got it... It's definitely more user friendly to have a steel pan. I was looking for another oil drain option for the AHU and AAZ with the VNT turbo, so I might look into it anyway. I think the AEB pan will fit.
Jeff. _________________ www.jeffsoldvolkshome.com
2002 Smyth Ute TDi
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2673 Location: East Nassau, NY
Posted: Mon Mar 03, 2014 4:39 am Post subject: |
The AEB will fit, you will want the oil pump pickup tube also. |
Posted: Mon Mar 03, 2014 4:51 am Post subject: |
xoo00oox wrote: |
I was fairly sure...Thanks for the confirmation.
2002 Smyth Ute TDi
Posted: Mon Mar 03, 2014 4:55 am Post subject: |
Awesome van you're building here. I've seen some of your work at transporterfest. I like. |
Posted: Mon Mar 03, 2014 5:53 am Post subject: |
xoo00oox wrote: |
Thanks, I like to show up with something new each year, but this year it'll be this van I'm sure...
2002 Smyth Ute TDi
