'58 PGSG project
sub-hatchtim
sub-hatchtim is offline
PostPosted: Tue Mar 13, 2018 2:26 pm    Post subject: Re: '58 PGSG project Reply with quote
What's your Vin number
My phone/sg is a February of 58 too
58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S
Travis Woodard
Travis Woodard is offline
PostPosted: Fri Mar 23, 2018 5:01 am    Post subject: Re: '58 PGSG project Reply with quote
Bus is looking great!
In 1958 did they still use the fat base mirror arms? I know 55 through 57 did.
56 PGSG OG paint Wilson Avenue church
59 mango
69 bay deluxe bay
66 beetle
Peter_N
Peter_N is offline
PostPosted: Fri Mar 23, 2018 7:58 am    Post subject: Re: '58 PGSG project Reply with quote
My pg/sg is a February of 58 too
Nice! Not too keen on sharing my Vin on public forums though, sorry
Mine was build on the 5th of February. How about yours?
Thanks!
Yeah, I'm quite sure it was still the original base on there.
I'm also planning to install a passenger side mirror, so I'll need to find/fab a fatbase for that.
My 1958 PGSG project topic
Travis Woodard
PostPosted: Fri Mar 23, 2018 8:25 am    Post subject: Re: '58 PGSG project Reply with quote
My PGSG is a Feb 56 but I’m with you I’m not sharing my vin.
59 mango
69 bay deluxe bay
66 beetle
Peter_N
Peter_N is offline
PostPosted: Mon Apr 23, 2018 6:59 am    Post subject: Re: '58 PGSG project Reply with quote
Some small updates I would like to share.
I had troubles to find a fat base mirror arm, let alone the base itself, so I decided to fabricate one.
I found an axle collar/drill stop in my junk, which is actually the same outer diameter and height.
I attached it to a drill with a bolt so I could spin it (redneck lathe Laughing ) and clamped a file in a vice.
With only a few passes on the file followed by 240 grit sand paper this was the result Very Happy
It fits loosely on a WW repro arm, so maybe I'll add a plastic bushing. First I have to get the passenger hinge pin out...
Last weekend I started on placing tar boards over the engine compartment.
To be able to cruise in the weekend with the family, I should at least try to get rid of the worst noise Laughing
I ordered 2.5mm thick 'Vibraflex' mats and cut them into strips.
They're self adhesive and easily pliable, especially when working in the sun Cool
It already took the sharp edges from the engine/ gearbox noise and it looks great imho!
The minimum order was 5 m2 so I'll also put it on the side panels, bulkhead and roof.
D-train
D-train is offline
PostPosted: Mon Apr 23, 2018 10:19 pm    Post subject: Re: '58 PGSG project Reply with quote
Well done!!!! Great innovation with the fat base!
shiny paint doesnt make it worth any more
Okie Adam
Okie Adam is offline
PostPosted: Tue Apr 24, 2018 4:28 am    Post subject: Re: '58 PGSG project Reply with quote
That mirror base is genius! Well done!
Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
mandraks
mandraks is offline
PostPosted: Tue Apr 24, 2018 7:42 am    Post subject: Re: '58 PGSG project Reply with quote
not sure what your plans are for the interior, but he good old westy rear mattress works awesome for noise reduction. or a kids bed mattress? You still have a ton of room for luggage on top. I also like putting a small piece of carpeting under the mattress to keep it from squeaking and sliding. Also protects the mattress cover.
regards
Uli
Peter_N
Peter_N is offline
PostPosted: Tue Apr 24, 2018 8:06 am    Post subject: Re: '58 PGSG project Reply with quote
Thanks!
Yes, somewhere in the far future I'll put a rock and roll bed in there with the matress on top of the engine bay.
Actually putting anything sound absorbing in the rear like wood, carpet or curtains will likely help a lot!
oldbusboy
oldbusboy is offline
PostPosted: Sun Nov 18, 2018 11:38 am    Post subject: Re: '58 PGSG project Reply with quote
Looking really awesome!
Look forward to seeing the rest blended.
Trevor
1968 porsche
Peter_N
Peter_N is offline
PostPosted: Wed Nov 21, 2018 7:49 am    Post subject: Re: '58 PGSG project Reply with quote
Thanks Trevor!
Oh yes I'm also looking forward to that very much!
I got the old lady running again lately. I bought a very fresh 36hp industrial engine core and transferred all the tins and parts from my other engine.
Although autumn has started and she will go in hibernation soon, but still took a few test runs.
Yesterday evening I replaced most of of the broken hub cap clips on my rims.
The tools I used (and the rivet holder in a vice)
Used a ratched strap to make sure the clip is hold tightly to the rim while hammering.
I zinc primered the clips and used a small dap of black sealant on the mating surface of the rivet to prevent moisture trapping in there.
Then it took a few decent blows with the pointy and blunt chisel to spread and flatten out the rivet again.
Before
After. Much better!
western auto
western auto is offline
PostPosted: Wed Nov 21, 2018 9:37 am    Post subject: Re: '58 PGSG project Reply with quote
I do my clips with tire mounted, wheel face down , supporting one side with a 4x4 and setting the ww tool directly on the cement opposite the side supported by 4x4, can clip 5 rims in 15 mins that way Wink
bally
bally is offline
PostPosted: Wed Nov 21, 2018 1:15 pm    Post subject: Re: '58 PGSG project Reply with quote
Great update; it's coming along very nicely 😊👍
Peter_N
Peter_N is offline
PostPosted: Thu Mar 07, 2019 2:06 pm    Post subject: Re: '58 PGSG project Reply with quote
I thought it would be nice to update this thread again. During the last months we had a very mild winter here in the Netherlands. Despite that there's a lot of salt on the roads and it's best to keep vintage cars of the streets.
Therfore I used the time wisely Laughing by restoring the front window sills while leaving the front doors in the hands of a pro.
I didn't like the curve of the repair sill where it meets the front skin (it was folded instead of pressed into shape), so I kept the original and only replaced the inner ledge.
Repair panel cut to fit
The driver side is already finished. I'll share some pictures when the pass. side is done too.
As said I went to a professional for welding up the front door bottoms.
Starting point...
The door skin appeared to be in good shape, but there were some holes in the end. He made a simple template for a repair panel
Putting it into shape
One welded, one to go
While waiting for the doors to be finished, I started on painting the cab.
Initially I planned on not painting the part which is not primed. Original paint was still strong in this area, but in the end I couldn’t get it blended nicely.
Next is putting the door seals in. Anyone has recommendations for glue?
Best regards and thanks for watching,
Peter
Burlyhammer
Burlyhammer is offline
PostPosted: Fri Mar 08, 2019 9:58 am    Post subject: Re: '58 PGSG project Reply with quote
Very nice work! The windshield repair came out nicely, and the door looks good, too! s that epoxy primer that you are using? I use 3M weatherstrip adhesive for door seals. It seems to work well. Good luck with your project.
Thanks,
Dave
de oli
de oli is offline
PostPosted: Tue Mar 12, 2019 12:52 am    Post subject: Re: '58 PGSG project Reply with quote
hey peter,
i´m an owner of a 1957 pgsg bus too.
it´s great to see your bus transforming.
big respect for your work
have a nice day
de
oli
1957 Typ 221 Bus Palmgrün Sandgrün PGSG
1959 Typ 1 Bug Kieselgrau
Peter_N
Peter_N is offline
PostPosted: Tue Mar 12, 2019 2:27 am    Post subject: Re: '58 PGSG project Reply with quote
Thanks,
Dave
Hi Dave,
Yes, It's a single stage filling primer I use.
Thanks for the tip on the wheatherstrip adhesive, I'll look into it.
Peter_N
Peter_N is offline
PostPosted: Tue Mar 26, 2019 4:46 am    Post subject: Re: '58 PGSG project Reply with quote
Front window sills are welded! Finally Cool
It took me a bit longer than anticipated, but what else is new when welding
Some pictures:
I tried not to mess with the subtle curvature in the A-pillar skin too much, so kept the cutout as small as possible
I welded the repair piece in place and bended it more into shape using a screwdriver from below. I had to lay on some extra material so I could file it into shape later.
Ground down and zinc primered!
Btw, the cloth you see hanging in my window is a $10 fire blanket. It's works great in catching sparks without catching fire
Some more rot
Repair piece in place
Ground down, fixed those damn pinholes and done!
Awaiting paint (and a bit of filler Laughing )
bally
bally is offline
PostPosted: Tue Mar 26, 2019 2:46 pm    Post subject: Re: '58 PGSG project Reply with quote
Nice work, nice update and thanks for the fireblanket tip!
Dave
Peter_N
Peter_N is offline
PostPosted: Fri Mar 29, 2019 5:50 am    Post subject: Re: '58 PGSG project Reply with quote
Thanks Dave!
Small update today, but it makes a huge difference for me.
I bought a very nice condition front floormat ~5 years ago. Seller told me it came from a fire department and belonged to a low milage bus.
I'm loving it..
Another box ticked Cool
Page 5 of 6
