1973 VW Thing build in Canada
Page: Previous  1, 2, 3, 4
Ron Domeck
Ron Domeck is offline
PostPosted: Thu Nov 27, 2014 8:27 am    Post subject: Reply with quote
We have all the parts sandblasted then spray with PPG DP Epoxy primer. If we are building a 100 percent show car the parts are then sprayed with a PPG primer/surfacer so they car be sanded to remove any imperfections and painted with a single stage black with a flattener to the correct gloss level. On your own with Por 15. Powdercoat is OK but whatever shape the parts are in will still be there. I have had to remove a lot of flaking powder because of poor prep. I guess "How nice do you want it".
VWest77
VWest77 is offline
PostPosted: Thu Nov 27, 2014 10:24 pm    Post subject: Reply with quote
I'm going for a pan off restoration, with the intention of driving this car daily... So doesn't necessarily have to be "show quality".
I can easily have all the parts sand blasted. I could have them sprayed with single stage paint, or whatever is best. Just looking for a long lasting durable finish.
So with that in mind, what product would you suggest to use on the pans and suspension pieces?
1973 Thing 1600 T181
1963 Double Cab
VWest77
VWest77 is offline
PostPosted: Wed Feb 04, 2015 5:53 am    Post subject: Reply with quote
Brought the pan to be welded. (A couple cracks to deal with, and jack points).
After that, off to be sandblasted/powdercoated or painted (still undecided).
Then the building starts.
1963 Double Cab
VWest77
VWest77 is offline
PostPosted: Tue Mar 10, 2015 8:30 am    Post subject: Reply with quote
Lately I have been taking the suspension apart and getting ready for blasting and powdercoating.
Noticed some wear on one of the trailing arms:
Looks like the inner bushing might have had some issues.
1963 Double Cab
VWest77
VWest77 is offline
PostPosted: Thu Jun 11, 2015 6:31 am    Post subject: Reply with quote
So I have all of the pieces back from the powder coaters now.
I'm going to go get the new ball joints pressed in... But was wondering if I should paint the inside of the control arm beforehand... Or does it matter?
1963 Double Cab
63ziggy
63ziggy is offline
PostPosted: Thu Jun 11, 2015 12:29 pm    Post subject: Reply with quote
I would not paint inside of control arms where balljoints press in. These tight tolerances. paint will interfere with full press. never seen any painted.
as far as beam end of arms, these will be coated in grease. no need
you will be fine with what you have done with arms.
View user's profile Send private message Send e-mail AIM Address Instagram Gallery Classifieds Feedback
VWest77
VWest77 is offline
PostPosted: Tue Oct 16, 2018 8:58 pm    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Well... after a few years break... I’m back to building.
I just got the pan back from the powdercoaters.
I can’t seem to find any info on this...
The inside of the rear torsion housing was blasted clean... and then plugged during powder coating.
Should I coat the inside with anything?
1963 Double Cab
el_safari
el_safari is offline
PostPosted: Wed Oct 17, 2018 2:41 am    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Hi
I would put some grease Cool
La terre n'est qu'un seul pays
VWest77
VWest77 is offline
PostPosted: Thu Oct 18, 2018 7:50 am    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Alright!
Took the balljoints to be pressed in.
First shop I took it to had problems... they were trying to seat the ball joint... put the control arm in a vise and must have been hitting the ball joint with something.
I then took them to a machinist... who got the job done in no time.
The first shop scrapped up the control arm... and also pushed in the top of the balljoint...
Think this might be an issue?
Good ball joint:
Messed up ball joint:
Also... any more thoughts on the rear torsion housing? Should I treat it with anything? Paint? Grease?
1963 Double Cab
VWest77
VWest77 is offline
PostPosted: Thu Oct 18, 2018 9:15 pm    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Installed the torsion leafs/control arms and beam to the pan today.
1963 Double Cab
VWest77
VWest77 is offline
PostPosted: Fri Oct 26, 2018 7:31 am    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Still wondering if I should grease the inside or paint or just leave it as is?
1963 Double Cab
OKType3Tim Premium Member
OKType3Tim is offline
PostPosted: Wed Apr 03, 2019 6:29 am    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Get a can of "GIBBS" and spray it down real good.
https://www.amazon.com/Gibbs-Brand-Lubricant-2-12o...amp;sr=8-1
'69 Squareback restoration
'69 Fastback restoration
'66 Type34
VWest77
VWest77 is offline
PostPosted: Tue Apr 16, 2019 10:16 am    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
Moving on to purchasing gaskets and seals...
Also looking at wiring options.
I can’t seem to find any information about the possibility of extending a beetle harness...
All of the Thing specific options are in the USA and after exchange rate and shipping... it gets really expensive.
Has anyone used a ghia or beetle harness with success?
If I were to go that route... which one should I use?
1963 Double Cab
ernieballbass
ernieballbass is offline
PostPosted: Mon May 13, 2019 1:44 pm    Post subject: Re: 1973 VW Thing build in Canada Reply with quote
I'm planning using to use rebel wire for my build. I've heard nothing but good things about their products.
I believe someone here on the Thing forum used them too. You may have to extend a couple of wires though.
http://rebelwire.com/rebel-wire-products.php?cat=Wire%20Kits
What I lack in brains, I make up for with good intentions.
Page 4 of 4
