johnfraser Samba Member
Joined: January 26, 2009 Posts: 492 Location: Isle of Wight
Posted: Tue Feb 25, 2014 1:34 am Post subject: Brake line install |
Can anyone please try and explain to me how to fit new brake lines in my 64 bug-It didn't have any when i bought it so I have nothing to follow.
I'm stuck on where to feed it through the centre of the car, and what to do with the metal clips which fit onto the rear axle and at the front by the beam. I have 6 of those so not sure where the other two go-or the grommets.
Any help would be great, I believe I have what I need, the already mentionned parts, the lines obviously and the T junction.
Thanks |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Tue Feb 25, 2014 5:20 am Post subject: |
_________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Tue Feb 25, 2014 5:30 am Post subject: |
Thanks very much for the diagram, haven't seen that before.
Just for to figure out how to feed that brake cable through with all those crazy curves in now!!? Anyone got any tips! |
Joey Samba Member
Posted: Tue Feb 25, 2014 6:23 am Post subject: |
There are guide tubes inside the tunnel for the clutch cable, accelerator cable E-brake cables, heater cables and choke cable ('61 and earlier). Just feed the correct cable through the correct guide tube and it'll exit the chassis at the correct spot. _________________ Joey
Posted: Tue Feb 25, 2014 6:27 am Post subject: |
Are the brake lines included in that?
Thanks |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Tue Feb 25, 2014 6:33 am Post subject: |
The brake line runs against the center hump on the inside of the car on the driver side. Look at the purple line. It is best to put a new brake line in if you car is that disassembled.
Posted: Tue Feb 25, 2014 6:40 am Post subject: |
Oh right yes sorry I see that now, that's for the help.
Last question.....what are the grommets for, how many do you need and where do they go?
Thanks again |
Posted: Tue Feb 25, 2014 6:52 am Post subject: |
pwmcguire wrote: |
And just as a side question, I'm currently fitting my tie rods-why is your long one extended on the passenger side? It looks like its in two parts |
vdubmyk Samba Member
Joined: October 24, 2008 Posts: 508 Location: Corona, CA
Posted: Tue Feb 25, 2014 7:13 am Post subject: |
johnfraser wrote: |
Thanks again |
The grommets go everywhere the brake lines runs through a hole. It helps prevent metal chafing as that will eventually cause a hole in the line.
http://www.wolfsburgwest.com/wolfsburg_new/brakes/bug_brake/bug_brakes.cfm
The grommets are all the same #45 on the diagram, I believe it takes 3 of them, two in front and one in the rear of the car. _________________ 64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker! |
Posted: Tue Feb 25, 2014 9:53 am Post subject: |
Thanks alot! |
Posted: Tue Feb 25, 2014 10:26 am Post subject: |
Sorry one last thing, how do the metal clips work? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Feb 25, 2014 10:33 am Post subject: |
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1001262
This what you are asking about? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Feb 25, 2014 10:41 am Post subject: |
Hi no I meant the two part metal clips that are on the rear axel, and also by the front axel. I think there might also be another two but not sure . |
Posted: Tue Feb 25, 2014 10:47 am Post subject: |
They just push on where the hard line and rubber line join at the bracket _________________ Rick
tasb wrote: |
sb001 wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Tue Feb 25, 2014 10:52 am Post subject: |
To deal with the multiple bends and the difficulty of fitting the main line in an assembled car, some use two sections joined with a coupler located near the back seat kick panels. |
Posted: Tue Feb 25, 2014 11:03 am Post subject: |
johnfraser wrote: |
pwmcguire wrote: |
It Is a vw oem tie rod from 1966. It has since been changed. |
Posted: Tue Feb 25, 2014 11:13 am Post subject: |
Here is a better picture with descriptions
Posted: Tue Feb 25, 2014 11:52 am Post subject: |
Thanks everyone. This forum is the the tits, I don't know what id do without it!!!! Thanks again. |
Posted: Tue Feb 25, 2014 12:41 pm Post subject: |
KTPhil wrote: |
not a good idea in my book, it is not that hard to fit the line in with body on with out cutting it. keep it in one continuous piece JMHO _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Sat Mar 01, 2014 10:47 am Post subject: |
hi
can anyone please tell me where abouts the t junction at the back of the car bolts to? there seems to be a hole on it to do so but i cant find where to bolt it to
also..hand brake cables, when they come through the back of the car near the gearbox, where is it supposed to feed through until it gets to the brakes? ive done mine and it just seems loose, id like it to run through something or do something with it to look a bit neater if nothing else
thanks |
