60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Mar 01, 2014 11:14 am Post subject: |
Here's a late model pic(from the gallery here) brake line routing hi lighted in red
No the cables are not in anything from tunnel to backing plate, just the sheath they wound cable is enclosed in. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
johnfraser Samba Member
Joined: January 26, 2009 Posts: 492 Location: Isle of Wight
Posted: Sun Apr 06, 2014 5:54 am Post subject: |
is the brake line too close to the hand brake cable here?
definately touching but dont know if it matters
the brake line connection is pretty close to where the hand brake cable comes out and i dont want to put too much of a bend in it
thanks |
rusty60 Samba Member
Joined: September 15, 2013 Posts: 126 Location: camano island
Posted: Sun Apr 06, 2014 10:41 am Post subject: |
Just finished new lines a few weeks ago.
Posted: Sat Apr 26, 2014 8:51 am Post subject: |
quick question...
where to do the low pressure hoses from the resevoir to the master cylinder run? do they go through where the tank sits? cant see any other holes for them but surely the tank will foul on them this way.... |
SparksLP Samba Member
Posted: Tue Jan 31, 2023 6:49 pm Post subject: Re: Brake line install |
Gonna revive this one, good info so far! Is it possible to replace the entire metal line without separating the body and pan? I assume so, but wanted to get verification. I'm going to completely replace my lines front to back, is there a master list of everything I'd need for a 1966 Beetle? _________________ Tom
1966 VW Beetle Sunroof Sedan |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9753 Location: Oregon
Posted: Tue Jan 31, 2023 7:00 pm Post subject: Re: Brake line install |
SparksLP wrote: |
Gonna revive this one, good info so far! Is it possible to replace the entire metal line without separating the body and pan? I assume so, but wanted to get verification. I'm going to completely replace my lines front to back, is there a master list of everything I'd need for a 1966 Beetle? |
There are brake hardline replacement kits available from most of the usual VW parts suppliers online.
My buddy Don replaced all of his on his 66, without removing the body from the chassis.
The toughest one to get in, was the cross over line from the drivers side to passenger side rear. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Feb 04, 2023 10:16 am Post subject: Re: Brake line install |
Good to know, thanks! _________________ Tom
Posted: Sun Jul 02, 2023 6:36 pm Post subject: Re: Brake line install |
Hmmm. My car doesn't have any of the clips that hold the brake line against the tunnel. What can I do to keep it from moving around inside the car? _________________ Tom
Mr. Mike Samba Member
Joined: January 30, 2015 Posts: 513 Location: Shoreline, WA
Posted: Sun Jul 02, 2023 6:41 pm Post subject: Re: Brake line install |
Take a look in the classifieds. Here's some for a buck each. _________________ 1964 Sedan 6 volt |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9948 Location: Huntington Beach, CA
Posted: Sun Jul 02, 2023 7:02 pm Post subject: Re: Brake line install |
SparksLP wrote: |
Hmmm. My car doesn't have any of the clips that hold the brake line against the tunnel. What can I do to keep it from moving around inside the car? |
You will need to weld in steel tabs or screw some in. Be careful, if using screws, to not hit anything in the tunnel! Look through the shifter opening to see what is in the way.
If welding, be sure to not melt anything! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
Posted: Sun Jul 02, 2023 7:46 pm Post subject: Re: Brake line install |
No way to weld anything, so I'll have to find some sort of tab to screw in (or JB Weld?). Stupid thought, could I just use a hot glue gun or something similar as a temporary fix until I can have tabs welded in? _________________ Tom
EVfun Samba Member
Posted: Sun Jul 02, 2023 11:27 pm Post subject: Re: Brake line install |
I bent some clips out of sheet metal to hold the line against the corner of the tunnel and floor. I attached them to the floor, each with a single 1/8 inch stainless steel pop rivet. I didn't want to drill holes in the tunnel so I moved the attach point out just a little so it wasn't going through the lip the floor attaches too. I think I had one behind the pedal cluster, one in front of the seat frame, and the last one behind the seat frame. _________________
Wildthings wrote: |
Posted: Mon Jul 03, 2023 6:30 am Post subject: Re: Brake line install |
EVfun wrote: |
I bent some clips out of sheet metal to hold the line against the corner of the tunnel and floor. I attached them to the floor, each with a single 1/8 inch stainless steel pop rivet. I didn't want to drill holes in the tunnel so I moved the attach point out just a little so it wasn't going through the lip the floor attaches too. I think I had one behind the pedal cluster, one in front of the seat frame, and the last one behind the seat frame. |
^^^ This is what I would do in the case of no weld machine available.
Except, I wouldn't bother with the forward clip ahead of the pedal cluster.
There is, IMO, plenty of brake line support from the through passage of the nap hat. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu Jul 06, 2023 6:24 pm Post subject: Re: Brake line install |
EVfun wrote: |
There is, IMO, plenty of brake line support from the through passage of the nap hat. |
This is a good idea. Any concerns with the seat rails/things I should look out for? _________________ Tom
