plysaker Samba Member
Joined: August 20, 2007 Posts: 95 Location: EmeraldCity
Posted: Fri Jun 26, 2015 2:55 pm Post subject: |
Let me know if I can come help, I started a new job and haven't been on much. Jim is good on tickets, if a little bit overloaded. _________________ "Darth Blue" 1985 ASI Bostig Reemo-falia! More than the Sum of His Parts, Which are many. Curently on the rack, getting a new heart. From Ford.
"Snowball" White 1967 Franken-Fastback, a survivor's story. At least 3 cars donated to the project. |
Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1135 Location: S.E. Connetitcut
Posted: Thu Oct 15, 2015 6:10 pm Post subject: |
86 Syncro Weekender
When routing the main wiring harness from the cabin does the harness go on the inside or outside the shock tower. Also do the fuel pump wire get cut or coiled , my wire is about 3 feet long (meant for a 2wd),also the terminals are wrong, which is no problem other than it wastes more time.
I spend more time on the computer than working on the van |
insyncro Banned
Posted: Thu Oct 15, 2015 9:09 pm Post subject: |
Bassyaks wrote: |
86 Syncro Weekender
You really need to get your terminology correct.
Vanagons don't have rear shock towers....you are looking at a spring perch.
Read the manual and watched the videos, all answers are right there. |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4065 Location: East Kootenay, British Columbia
Posted: Fri Oct 16, 2015 8:49 am Post subject: |
Bassyaks wrote: |
86 Syncro Weekender
Please keep your questions in one place.
Like I said in the other post, just coil the extra wire if you are not going to cut. If you cut make sure the connection is perfect.
Not sure what you mean about the terminals being wrong. Mine made a beautiful, sealed connection to the stock fuel pump.
Take the time to READ the manual before you do any work and then again while you work.
Watch the videos. Yes, some of the videos are from earlier versions but they still apply. When you read the manual the difference between the vids and the new system is obvious.
You can PM me if you get really stuck, but please try to figure it out first. _________________ Currently:
jbnova Samba Member
Joined: August 20, 2010 Posts: 118 Location: Ellensburg, WA
Posted: Fri Oct 16, 2015 11:17 am Post subject: |
There are two variations on the fuel pump terminals. I bought a new fuel pump for my install and had to cut off the connectors on the Bostig fuel pump wire and replace with the "ring" style connectors as the new pump has posts instead of spades.
As for the "inside vs. outside" of spring perch question, I can relate to your confusion. In the video at 13:10, Brady or Jim refer to running the main harness wire "behind" the spring perch. The way he is pointing, I kinda of thought he might have meant on the "outside" of the perch. After giving it more thought, I was able to figure out the correct answer based on common sense. The problem for me, was that "common sense" seemed to frequently escape my mind during the process. I certainly could have put many more questions out to the internet, but just stepping back from the problem for a minute would often reveal the answer. I would sometimes get frustrated with the amount of "interpretation" required in the Bostig manual, but in the end, that interpretation really helped me better understand the overall system and empowered me to have more confidence in my own decisions. _________________ 1986 Westfalia Weekender
2wd; Bostig RG3
GoWesty (H&R) 1.5" Lift Springs + 0.5" pad in rear.
Bilstein Shocks
16" Mefros, Cooper Discoverer AT3 (215-70-16) |
insyncro Banned
Posted: Fri Oct 16, 2015 11:25 am Post subject: |
Conversion harnesses are to run in place of the WBX or stock harness, when the owner wants the works under the rear seat.
It makes the most sense to run the Bostig one this way due to its length and where they have branches off the main harness.
Do not bend the new harness into very tight corners, it was not made to do that and wires in general prefer straight shots.
If you have Bostig specific questions, please create a ticket with Jim and have a log of your work.
This will greatly help down the road...IF...you ever have issues. |
Posted: Fri Oct 16, 2015 11:27 am Post subject: |
Thanks, Which is the "Going " thread on the Bostig stuff. That's the problem it's scattered all over the place, when I said I watched all of the videos, I watched them 2or 3 times including a few Bostig band videos .
Judo Jeff seems to have the newest stuff posted along with his aggravations. |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Fri Oct 16, 2015 12:16 pm Post subject: |
I hope my name is not being spoken in vain!
Most of my aggravations with a conversion had little to do with Bostig, mostly with my own ineptitude, and inability to see things up close. Try attaching things you can't see, using only "feel".
Bostig did a great job with the instructions, but because there are so many variations, you need a little "Kentucky windage" when you assemble things.
I have no background with Windows and that was my biggest PITA. Not Bostig's fault, others rescued me, though.
My second install has been a breeze, the learning curve is very flat..... _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
