ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Posted: Fri Feb 28, 2014 4:01 pm Post subject: Setting bump stops for ground clearance |
I'm about to fab my bump stops and I'm wondering what people consider a safe ground clearance. As you can see I can can go pretty low. The oil plug is the lowest point at 1-1/2". Obviously this is too low.
Lemme know what you think is a good distance.
_________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
jsturtlebuggy Samba Member
Posted: Fri Feb 28, 2014 4:40 pm Post subject: |
Just set the stop where it at (completely bottom out and no chance for suspension to travel more) and have a good aluminum skid plate.
Over the years I seen many off road race cars that actually had negative ground clearance with suspension fully bottom out.
You do want to have a least a 1in between anything on engine or trans and skid plate. Use aluminum and minimum thickness of 3/16" thick. 1/4" or thicker is better. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
KrAzY-BaJa Samba Member
Joined: May 22, 2008 Posts: 1409 Location: Sacramento CA.
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Sat Mar 01, 2014 6:13 am Post subject: |
If its a sand car, it can be close to 0. Mine has 1". If its a desert or woods car you probably want a little more. |
ltbaney Samba Member
Joined: September 26, 2013 Posts: 20 Location: huntington beach ca.
Posted: Sat Mar 01, 2014 10:04 pm Post subject: |
KrAzY-BaJa wrote: |
I have like 2-4" at full bump from the ground front / rear |
X2 for this and run a skid plate no thinner than 3/16 aluminum. |
Posted: Mon Mar 03, 2014 6:17 am Post subject: |
thanks for the suggestions.
It's kinda strange how I ended up doing it. My bags were laying on the arms at full droop so I went up till they cleared. In hind sight, I did this with no air in them so I really don't think it'll matter. lol
Ended up turning out to be about 4" off ground which is fine.
I've always ran skid plates but with the pan on this new motor I'll have to make sure it's better than the street sign plates I threw together before. lol _________________ Brian H.
