Rockers replacement supply and fit problems
kiwighia68
kiwighia68 is offline
PostPosted: Tue Mar 04, 2014 3:54 pm    Post subject: Rockers replacement supply and fit problems Reply with quote
I need help with replacement parts for the rockers for my '68 RHD coupe. I'm not qualified to manufacture my own and the metal guy who is helping me with the bodywork is very expensive. KGP&R has rockers and kick panels in their brochure (Sect. 5 at pages 29 and 26) but apparently nothing specific for the '68 model in stock.
So what are my choices?
I prefer the pre-welded model (Part 801-045P69 74 and 801-046P69 74) if it will fit but may have to settle for the inner and outer rocker parts as separate items (Items 6, 7, 7a and 8 on page 29) and in either case will then have to buy the "Floor to tender (foot well) supports separately. My question: Will these options work for a '68 model, with or without adjustments? Has anyone done this on a '68?
The alternative is to go to House of Ghia for the parts. They have Items KQ-801-045 and KQ-801-046 ("Entire side member 72" long") which I understand to be the whole unit (each side) including the foot well supports. My questions: Am I right in my interpretation of the brochure? (I'm waiting for an answer from HOG.) Does anyone have experience in fitting these "Entire side member" units in a '68 - or any other year?
(Is there anything significant in the fact that KGP&R and HOG have similar item numbers for these items?)
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
djkeev
djkeev is offline
PostPosted: Tue Mar 04, 2014 4:59 pm    Post subject: Reply with quote
While I don't have any answers....... My mind is clicking...... How much will it cost to ship tin 1/2 way around the World?!?!
I'm going a different way, I am using the exterior rocker panel but using 2x3 channel, angle iron and flat stock building a very strong and durable rocker panel / heater pipe assembly.
You can also make your own rocker panel metal. Any tin knocker worth his salt should be able to create such a simple piece.
Inspiration for doing it yourself or having your guy make what he needs!....
http://www.thesamba.com/vw/forum/viewtopic.php?t=572951
My rocker design.... Scroll down.....
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60
Dave
Ghia
Vanagon
Beetle
kiwighia68
PostPosted: Tue Mar 04, 2014 5:32 pm    Post subject: Reply with quote
Dave
Hi Dave, I remember seeing both the threads. Your posts are always illuminating and your work exemplary but reminding me of my shortcomings. My metal guy charges $80 and hour, and told me that I would be better off importing the components from the western side of the USA.
I had Metalwork as a subject at school up to age 16. We used to make fun of the teacher, and man, do I regret that now. I should have listened and learned. RIP Mr van Deventer.
Chris M
djkeev
djkeev is offline
PostPosted: Tue Mar 04, 2014 5:36 pm    Post subject: Reply with quote
I usually have a few Kiwi and Aussie workers here for the Summer Months, (June July August)..... I'll slip some tin in their baggage before they head home!
I'm sure that They won't notice!
Dave
Ghia
Vanagon
Beetle
c21darrel
c21darrel is offline
PostPosted: Tue Mar 04, 2014 6:41 pm    Post subject: Reply with quote
I dont have a KGPR guide handy to reference your part numbers and dont know your original heater outlet setup. There was a change during 1968. Early 68 had heater vents up front in the "dogleg" piece like earlier models. Late 68 was the beginning of the heat outlets under the middle of the door.
GhiaBuild
1967 DC build
kiwighia68
PostPosted: Tue Mar 04, 2014 7:43 pm    Post subject: Reply with quote
Yes, I have those heater outlets. My car was built in May/June 1969 at the end of the '68 model run. Does that mean the rocker-related items KGP&R and HOG advertise will fit my car?
TheFop
TheFop is offline
PostPosted: Tue Mar 04, 2014 7:56 pm    Post subject: Reply with quote
Time for that beer I think, I'm just going through similar ponderings and on the verge of ordering some big panels. Kia ora and welcome home.
djkeev
djkeev is offline
PostPosted: Tue Mar 04, 2014 8:46 pm    Post subject: Reply with quote
Did you read HOG's note about heater channels?
"All repro heat channel sheetmetal is patterned after the 69-74 heat channels. They will fit the 56-68 model years, but will require some modification."
Personal opinion........
For anything Ghia....... HOG is choice number 1. Just like for anything convertible, chucksconvertible is choice number 1.
Go with the proven best .......... or go home.
Dave
Ghia
Vanagon
Beetle
kiwighia68
PostPosted: Tue Mar 04, 2014 8:49 pm    Post subject: Reply with quote
Dave
Thanks Dave, I did see that, but after 40+ years in the legal profession (don't hold that against me!) I had to wonder about the scope of the word "some".
kiwighia68
PostPosted: Tue Mar 04, 2014 8:53 pm    Post subject: Reply with quote
I'm jetlagged and fuzzy, but the wife agreed we could have dinner at the pub tonight. I think I'll be okay tomorrow - nothing a couple of Guinness and a good night's sleep can't fix.
My chassis arrived back at my house today and I've been eyeing the extent of the work I'm going to have to do. I'll post photos later.
I was unable to find a second wiring loom, but I think a good deal of my original stuff is re-usable. I may have some wires ex that 68 Bay Bus for you. Talk later. The pub awaits.
djkeev
djkeev is offline
PostPosted: Tue Mar 04, 2014 8:56 pm    Post subject: Reply with quote
Unless you can locate and purchase the rare as hen's teeth NOS heater channel....... You've no other choice.
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Wed Mar 05, 2014 6:05 am    Post subject: Reply with quote
The issues would be two hold....
Heater outlet location.... No problem, cut and paste, the split and oval Beetle crowd has been doing this for years!
More significantly if you are a purist is the shape of the inner door sill channel. The newer ones are much more square with the old ones being more rounded.
Dave
Ghia
Vanagon
Beetle
NOVA Airhead
NOVA Airhead is offline
PostPosted: Wed Mar 05, 2014 8:45 am    Post subject: Reply with quote
Dave
I am not sure I would agree with the statement on HOG. Its a challenge ordering something from them - even more so now that the site is being rebuilt, which has been going on for at least a couple of months now.
I can understand why its being rebuilt because the old site was pretty poor.
KGP&R is easy to deal with and their shipping is very fast. HOG and KGP&R are different in their own ways and have strengths and weaknesses. At this point I would not say one is better than the other. However right now I would have to give the edge to KGP&R. Pricing, inventory and ordering information is all on line. If you see a price lower let them know and they will match it.
With respect to the heater channels. Even for the 69 and newer cars expect to make some tweaks to them. These cars are hand built so you won't likely see a perfect fit.
Ghia Owner Emeritus
KGCoupe
KGCoupe is offline
PostPosted: Wed Mar 05, 2014 9:08 am    Post subject: Reply with quote
If I'm understanding all of this correctly, then the repro heat channel that is referred to as "69-74" is in fact the style that you are looking for.
If your late 1968 model year Ghia was manufactured with the later style heater outlet, then no modification should be necessary (at least with regard to heater outlet placement Wink ).
It would be nice if VW/Karmann had implemented all changes cleanly at the model year breaks.
However it was often it was necessary/convenient/cost effective to make changes in the middle of a model year, so you can't always just go by model year when you are looking for replacement parts.
Generally speaking and assuming that all pieces are of equal high quality, I would think that a larger and more complete repair panel (such as the "Entire side member 72" long" section that you mentioned being available) would translate into labor cost savings when compared to using several smaller sections that must be linked together upon installation.
If nothing else, it would save the painstaking process of insuring that each piece is properly aligned with the adjacent pieces prior to final welding.
c21darrel
PostPosted: Wed Mar 05, 2014 1:23 pm    Post subject: Reply with quote
There are other sources for the heater channels than HOG, KGPR...
All the repop heater channels are the "late" style.
Concur with "Nova" re challenges ordering/searching... except I think HOG's website has been in rebuild mode for years not months...alot like Gersons.
http://www.thesamba.com/vw/classifieds/search.php?...arting+out
GhiaBuild
1967 DC build
cracker666
cracker666 is offline
PostPosted: Wed Mar 05, 2014 1:30 pm    Post subject: Reply with quote
I bought the correct version for my 60/61. Not the later style.
These cost about £89 each side from www.karmannghia.de
I taught myself to weld and the heater channels came in three parts per side.
I wouldn't bother getting the later side as it just don't look right, the curve is too high.
The problem I have is I have to redesign and graft in the sharks fin on the front vents.
But hey that's not a problem, it's only metal.
Do yourself a favour get a mig welder and you would be supprised how much you will save doing it yourself, I am and I love it.
Postage was 20euro to the uk.
Price was correct about 4years ago.
Andre@KGPR/Airhead
Andre@KGPR/Airhead is offline
PostPosted: Wed Mar 05, 2014 3:25 pm    Post subject: Reply with quote
Dave
We'll still be here when you need us, Dave. Wink
djkeev
djkeev is offline
PostPosted: Wed Mar 05, 2014 3:32 pm    Post subject: Reply with quote
Dave
Ha! Good to know!
I'm already a customer....... I'm not totally faithful...... I can be wooed!
A pretty photo ..... A good part...... An excellent bargain...... Ka ching! Smile
Lets talk headlight buckets....... Wink
Dave
Ghia
Vanagon
Beetle
c21darrel
PostPosted: Wed Mar 05, 2014 3:35 pm    Post subject: Reply with quote
Did you say headlight bucket?
http://www.thesamba.com/vw/classifieds/detail.php?id=1546778
GhiaBuild
1967 DC build
Andre@KGPR/Airhead
PostPosted: Wed Mar 05, 2014 3:51 pm    Post subject: Reply with quote
Dave
Ha! Good to know!
Dave
Haha-- no hard feelings at all, man. I'm a Mike @ HOG fan myself. Thanks for the laugh!
