chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Thu Mar 06, 2014 8:19 am Post subject: glue the seals? |
i've had some new seals i got in a PO parts box for a long time and finally thought i might try one yesterday. i started with the back hatch seal and when i went to pull out the original, i found it was lightly glued in. i went ahead and just pressed the new one in, but it got me wondering if anyone ever glues their seals in. if so, what do you use? _________________ '74 transporter panel
'91 vanagon carat NAHT |
busdaddy Samba Member
Posted: Thu Mar 06, 2014 8:34 am Post subject: |
3M weatherstrip adhesive. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu Mar 06, 2014 9:00 am Post subject: |
Contact cement is the bomb. Apply to both surfaces and let it tack up, then adhere the seal. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Mar 06, 2014 9:12 am Post subject: |
Mine were fresh and just pushed in but old ones were just tacked on the corners and came out in 5 mins with no scraping or cleaning.
Depends on the fit. There were wolf's and had NO fit issues but if one need a little stretch round the corners I would go with the 3m and do both surfaces, but assemble wet so you could adjust a little, because if assembled dry where you first put them thats were they stay with out damage- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Thu Mar 06, 2014 2:21 pm Post subject: |
First tailgate seal I had I glued in all round. Was impossible to remove and got shredded when removed for painting.
Second soft,quality rubber one I glued only at top left and top right corners where it is exposed to the air.
. Keeps the rain from going under the seal at that point , all the remaining seal tucks nicely into the channel without glue. |
Posted: Thu Mar 06, 2014 2:27 pm Post subject: |
Posted: Thu Mar 06, 2014 3:31 pm Post subject: |
My buddy borninabus told me that the doors can stick to the seals and pull them out sometimes, so I glued them at least some to prevent that from happening. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
chachi Samba Member
Posted: Thu Mar 06, 2014 7:09 pm Post subject: |
i have no idea of the provenance of these seals, but this one fit well once i figured out the orientation. still there was a corner that just didn't tuck; i can see a little glue not being a bad thing. _________________ '74 transporter panel
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Fri Mar 07, 2014 8:25 am Post subject: |
"Gasgacinch" Is the closest to factory that you are gonna find. All others are very permanent. And you can use it on your valve cover gaskets. |
