flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Sat Mar 08, 2014 10:00 pm Post subject: Pinstriping paint question |
I am planning on having some pinstriping done to my '67 Standard Bus. I want to more or less copy what the factory did to some early busses. Plus a few little tasteful extras here and there.
My question is did the factory use the same paint for the stripes as was painted on the body? Or was it a special pinstriping paint?
I would think that perhaps it is the same paint code, but not as reduced as much as the paint that is sprayed on.
input from someone who has some experience with this would be greatly appreciated. I want to have a bit of knowledge about this before I suggest it to my painter.
Thanks, Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Sun Mar 09, 2014 5:53 am Post subject: |
Usually just a high quality single stage paint. Pinstirping can be done freehand by a very skilled person, few can pull off a straight line. Usually the stripes are taped off (special pinstriping mask tape can be bought) the tape is best pulled off after the paint sets but before it fully hardens. Any painter worth the time should know what to do as duplicating factory pinstriping is common. Also pinstriping tape is easy to do but up close doesn't look as classy. |
Posted: Sun Mar 09, 2014 8:51 am Post subject: |
Thanks for that. I am using Glasurit line 22 paint for the bus. I assume the striping should be done after the entire bus has been color sanded and buffed.
I thought the self-leveling qualities of the Glasurit line 22 would work well with pinstriping.
