lowdowndub Samba Member
Posted: Mon Dec 22, 2003 9:18 am Post subject: Rear Tire Clearance on a Lowered Bus |
I had my bus lowered last spring, about 3 to 4 inches front a rear.
I took it to Les Schwab's one day to have the tires rotated and they couldn't get tires off the rear.(Not enough clearence between the wheel well and tires). So I figured that I have the wrong shocks in the rear and they aren't letting the tires drop down enough when the bus is jacked up.(The shocks work great otherwise). So I jacked it up, and released the bottom shock bolts. I still could bearly get the tires off.
Does anyone else have this problem. I'm running 195/70R14s for tires.
If I ever get a flat, i'm screwed. Please help!
-LDD |
GeoffP Samba Member
Joined: July 14, 2002 Posts: 400 Location: Blaine WA / Vancouver
Posted: Mon Dec 22, 2003 3:35 pm Post subject: |
One thing we used to do with the very low buses was to let the air out of the tire so one side is flat, jack up the bus and rotate the tire over until the flat spot is on top the slide it out. This should work in your case, just make sure you do it somewhere with a air line so you can fill them up once swaped. |
Bottomend Grease
Joined: September 20, 2003 Posts: 1500 Location: Smell Aye! via Nude Hamster!
Posted: Tue Dec 23, 2003 1:58 am Post subject: |
I had the same problem. couldnt get the wheels on or off. I've ended up taking off the lowering stuff. Looked great but it was SOOO stiff! Hows your ride? |
Posted: Tue Dec 23, 2003 9:05 am Post subject: |
My bus definitly rides a lot stiffer, but it's not bad. I've taken it into the mountains and on road trips and it's been OK. Mainly have to watchout for speed bump and pot holes. I don't mind because it looks bad ass!
-LDD |
breadloafdeluxe Samba Member
Joined: February 12, 2002 Posts: 418 Location: Birthplace o Tx. Brazoria Co.
Posted: Wed Dec 24, 2003 1:24 pm Post subject: |
I have my bus lowered in the back 2 splines and a Bus Boys ajustable beam on the front. I'm running Empi 5 spokes w/adapters.Tires are the new Continental 175-55-15s (same size as 135s) I do have a little wigglin and cussing to get the rears on and off, but I would'nt say I'm screwed with a flat. I'm looking into getting a set of air shocks for the back as the torsion arm is resting the frame stop at the top of the travel, Wavepimp got a set at AutoZone I need to check out. _________________ Give a man a fish and he knows where to get fish.Teach a man to fish and you loose a customer. |
Billet_Bus Samba Member
Posted: Wed Dec 24, 2003 7:11 pm Post subject: |
im using 175-55-15s on the front of my 64 and they arent even close to the same size as 135. They are 1.5" wider and 1" shorter in diameter.
Also im using 195-50s in the rear and i dont have any probs taken them off. Maybe its cuase i dont have my engine yet, positive camber sucks
Also dont ask for more then 2" of movement from airshocks unless you pumpin 200psi and you might get 3"s _________________ www.Full-Race.com
Anything else is just half fast.
CTD Fabrication |
Posted: Sat Dec 27, 2003 6:35 am Post subject: |
I was only stating what the ad said for the tires at Old Volk.com. They want $149.95 each for them and I got them locally for $52.oo! _________________ Give a man a fish and he knows where to get fish.Teach a man to fish and you loose a customer. |
Posted: Sat Dec 27, 2003 9:05 am Post subject: |
damn, nice price. Were they used?
I paid $201 for 2 mounted and balanced from discount, not a bad deal for the quality tire.
Heh, do your tires say they "save gas" too? Damn frence write some weird stuff on their sidewalls _________________ www.Full-Race.com
CTD Fabrication |
Posted: Sat Dec 27, 2003 2:05 pm Post subject: |
Saves Fuel & Reduces CO2 Emission! Mounted ballanced a set of 4 $216.oo plus tx. I thought of buying a couple o pair and selling them on the Samba. _________________ Give a man a fish and he knows where to get fish.Teach a man to fish and you loose a customer. |
