TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Mon Mar 10, 2014 2:23 pm Post subject: Sliding window tinting |
Question... have any of you removed the window to have it tinted, and have any of you tinted only down to the metal portion?
The reason I ask is I went to a very reliable place to get a quote, and the guy is very proud of his work (does NBA players rides etc). He does not want to tint down to the metal on the inside of the latching window. He would like to have the entire window tinted (bottom red arrow) Plus there is the over lap part of the windows.
Any opinions or pics on how you did yours? How big of a PITA is it to remove the window from the rail and re-install? _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
SyncroChrick Samba Member
Joined: January 10, 2005 Posts: 1010 Location: San Francisco, CA
Posted: Mon Mar 10, 2014 2:37 pm Post subject: |
Maybe this will help:
vw t25 t3 sliding window glass removal
http://youtu.be/80AVBVjD0LQ |
Solrider Samba Member
Joined: April 27, 2011 Posts: 199 Location: Phoenix, AZ
Posted: Mon Mar 10, 2014 2:56 pm Post subject: |
I just had my windows tinted by a guy who has tinted many Vanagons specifically. He did not remove the window, and had to cut around the latches, etc. All of this he pointed out to me prior to install. He said the windows could be removed if I wanted them, but that I would have to do it as he didn't want to take the responsibility of broken glass. In the end, I really didn't care I just wanted the windows tinted in a cost effective manner that looked good. Personally, I think the only person who is even going to notice a difference is you. _________________ Heidi - KF7CKI
85 Vanagon GL 1.6NA - Otto Von Wunderwagen
Gone but not forgotten:
71 Super Beetle - Gretel
92 Jetta GL - Jerry
97 Passat TDI - Penny |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Mon Mar 10, 2014 3:02 pm Post subject: |
X2^^
My tinting guy did the same, then used some sort of touch-up pen to darken around the latches and other areas where he couldn't quite get. He then put some sort of dull-ish black tape on the outside to cover up the overlap where he couldn't reach and it looks great. The tape might eventually peel, but its hung in there fine so far after a hot summer and cold winter, so I'm hopeful. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
yiucycle Samba Member
Posted: Mon Mar 10, 2014 3:43 pm Post subject: |
I remove my sliding window with two big spreader/clamps. Its was pretty nerve wreaking at the beginning but it was pretty fast once i know the right technique. I don't think you can remove the melt piece, even if you can it will rip the tint off once you try to slide the metal piece back in.
Also if you plan to take the sliding window out, make sure make some wood block to fit the channel. I bent one side of the sliding window channel when i was spreading it apart. a wood block will spread the load better.
this is what i use:
http://www.irwin.com/tools/clamps/xp600-one-handed-bar-clamps-spreaders _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
Posted: Mon Mar 10, 2014 4:35 pm Post subject: |
Thank you gentleman... I will go forward with tinting down to the metal (scared poopless to remove frame!) I like the marker idea too...
Thanks for the vid, but he was missing his plastic guides which gave him more room... still a lot of work
Now I just need to remove the rear cabinet and set a time... woot! _________________ Don't harsh my mellow...
1967 Bug- Gone
ehoff Samba Member
Posted: Mon Mar 10, 2014 4:51 pm Post subject: |
The shop that did mine was able to do the rear driver window well without removing the closet. Tricks of the trade I guess. I reccommend removing the latches completely before its done and the outcome will be super clean. Its easy, there is a vid on the gw site for their latch kit. It is also worth completely removing the triangle windows and their latches to avoid radically misaligned hole tracings. I paid 450 for 5% ceramic all around and am impressed with the outcome. |
Posted: Mon Mar 10, 2014 5:26 pm Post subject: |
ehoff wrote: |
Cant do passenger or drivers window... going to remove my cabinet and latches on sliders. 280 is the bill _________________ Don't harsh my mellow...
1967 Bug- Gone
Darren2dream Samba Member
Joined: April 12, 2011 Posts: 162 Location: Redwood City, CA
Posted: Mon Mar 10, 2014 7:21 pm Post subject: |
Mine is tinted the same, down to the metal piece and, a piece of black tape on the outside where the windows overlap... they didn't pop out the windows.
Looks great 2+ years later. They also did the closet window without removing the closet, no problem.
I'd do it all again in a heartbeat but, I've been afraid to slide open my windows ever since...
I went with SunTek CXP for tint. _________________ 84' Wolfsburg Westy GL 1.9 Manual |
Posted: Mon Mar 10, 2014 7:24 pm Post subject: |
Tape it is!
I'm getting some good stuff (allegedly) Owner pointed to his storefront windows that have been tinted for 7 years with direct sun on them and no issues... plus I have seen his work, so I feel good about not having purple windows in a few years *insert crossed fingers here* _________________ Don't harsh my mellow...
1967 Bug- Gone
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Mon Mar 10, 2014 9:17 pm Post subject: |
I planned on plastidipping the frames black, just realized the part that slides... so I will have to paint them black. _________________ Don't harsh my mellow...
1967 Bug- Gone
Last edited by TequilaSunSet on Mon Mar 10, 2014 9:18 pm; edited 1 time in total |
Birdcage Samba Member
Joined: November 06, 2013 Posts: 203 Location: Collins of fort
Posted: Mon Mar 10, 2014 9:18 pm Post subject: |
Put your big boy pants on and Pull the glass out, it's not hard at all.
1.)Break a #2 pencil in half
2.)push the glass up and insert pencil into channel an rest glass on it
3.)use a soft piece of wood-rested on top of channel, gently tap channel down
4.)once channel is loose the glass will pop right out
It looks so much better done right. Takes about 5 min per side.
While your at it u can replace the felt also! |
Posted: Mon Mar 10, 2014 9:19 pm Post subject: |
Birdcage wrote: |
I can get that under my new guides? _________________ Don't harsh my mellow...
1967 Bug- Gone
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Tue Mar 11, 2014 12:45 am Post subject: |
I had my windows tinted while the frames were out for paint. Having the whole glass covered is the way to go.
One guy here did have his window frames anodized black. I wanted to do this but did not have the time to get it done. Westy window frames are already anoded. They would have to strip it off first before reanodizing. This is the only thing I regret not getting done while getting my paint.
See how the alumium color stick out some on my van.
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
Posted: Tue Mar 11, 2014 6:25 am Post subject: |
^^ Thanks for posting... I can't stand having the aluminum frames on my gangrene beast, hopefully at some point I will get that fixed. I plan on blacking out the entire window/body area. So along with the tint it would look cool, but not with the frames as is. _________________ Don't harsh my mellow...
1967 Bug- Gone
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Tue Mar 11, 2014 6:54 am Post subject: |
X2 on what he did. You take one end of the clamp off and reverse it so it is a spreader instead of a clamp. _________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
Posted: Tue Mar 11, 2014 7:04 am Post subject: |
jrobewesty wrote: |
X2 on what he did. You take one end of the clamp off and reverse it so it is a spreader instead of a clamp. |
Well I do have some clamps that will do that, so... next step put on my big boy pants _________________ Don't harsh my mellow...
1967 Bug- Gone
Posted: Tue Mar 11, 2014 12:38 pm Post subject: |
I had my rear windows pulled out to replace the seals and tint, and put in a later model window vent. It went well, but I did remove the thin outer wood piece that is right against the window within the closet. I went limo tint, so you can't really see in there anyway, so have not missed it. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
Posted: Tue Mar 11, 2014 12:45 pm Post subject: |
3 vans, no stinking clamps were ever needed. Maybe just me and my MAN hands. |
