carcrazed Samba Member
Posted: Fri Mar 14, 2014 7:55 pm Post subject: Painting Kadron Intakes and Metal or Paper Gaskets? |
Yes..kind of a 2-part question. I just got my Kadron carbs back from Low Bugget all rebuilt. I stripped all the old paint off of the steel intakes....so...is it ok to leave them just the way they are or is it better to paint them with some engine paint? I wasn't sure if they would be prone to get some surface rust without some protection.
2nd question is which gasket would be better for the dual port head to intake? the metal crush gasket or paper? I had paper on there before and had hell getting ithem off when I removed the intake. I have never used the metal gaskets and wonder if they would work better. My engine is a 1776 with dual port heads (stock 1600cc size valves). Thanks in advance! _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Mar 14, 2014 8:10 pm Post subject: |
use the thicker cardboard gaskets, my experience with metal gaskets for Kadrons was not good. No problems after getting the tip to switch to the cardboard.. |
aircoolnut Samba Member
Joined: July 23, 2006 Posts: 157 Location: Spanaway, WA
Posted: Fri Mar 14, 2014 9:21 pm Post subject: |
Use the paper, It will seal much much better. Just give them a thin coating of anti-seize and they'll come right up when you need to remove them again. Don't use grease, it'll just bake on and you'll be scraping them off. |
Posted: Sat Mar 15, 2014 6:06 am Post subject: |
Thanks....paper gaskets it is! Any suggestions on painting the steel intakes or can I leave the just like they are without getting any surface rust on them? _________________ 1965 Herbie Replica. 1776cc dual Kads.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Mar 15, 2014 6:10 am Post subject: |
Raw steel rusts...
If you want the raw look ...and no rust . Satin Clear over them. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sat Mar 15, 2014 7:19 am Post subject: |
Excellent. Thanks. _________________ 1965 Herbie Replica. 1776cc dual Kads.
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Mar 15, 2014 1:15 pm Post subject: |
For sure use some good, thick paper gaskets. Those manifolds are welded up steel and prone to warping so be careful not to over tighten them either.
If you want them to look like original, paint them with some black wrinkle paint, best if it's the high temp variety made for engines. If you're going to use the stock linkage, paint that with the wrinkle paint too. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
Posted: Sat Mar 15, 2014 6:08 pm Post subject: |
just got done painting them with high temp engine paint. Thanks for all the advice! _________________ 1965 Herbie Replica. 1776cc dual Kads.
