Go Westy Hitch Question
nacradriver
nacradriver is offline
PostPosted: Sun Mar 16, 2014 12:11 pm    Post subject: Go Westy Hitch Question Reply with quote
Anyone installed the GoWesty bolt on VANO-HITCH... Got around to doing mine this morning and the support that comes off the engine support bar doesn't seem to want to line up with the hitch... Any recommendations that can help me get this job done today?
Image here:
http://www.gowesty.com/ec_view_details.php?id=2582&category_id=275&category_parent_id=
My last hitch didn't have this part and I am wondering if I even need it...
Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985
goffoz
goffoz is offline
PostPosted: Sun Mar 16, 2014 5:02 pm    Post subject: Re: Go Westy Hitch Question Reply with quote
I've fixed 2 of these for friends, they don't line up out of the box, you can slot the holes or better, you can bend the brace just a little..a press and "V" blocks makes it look factory.email GW and let them know...they can be very helpful.
Its all about the tow weight, small trailer, should be fine with out it
... bike rack, maybe a strap to the top of the hatch, for security
0to60in6min
0to60in6min is offline
PostPosted: Sun Mar 16, 2014 5:47 pm    Post subject: Reply with quote
I have the VC Vano hitch on my Carat... installed with no problem... very easy to install..
please note they gave extra parts for Syncro... and you're not supposed to use it on a 2WD van
Altoona
Altoona is offline
PostPosted: Sun Mar 16, 2014 8:00 pm    Post subject: Reply with quote
Leave all connections loose and then tighten it all down when the fasteners are started.
tomkat73
tomkat73 is offline
PostPosted: Sun Mar 16, 2014 10:44 pm    Post subject: Reply with quote
Yeah....what Altoona said worked on my Syncro Westy.
Hardest part for me was getting the engine support bar nuts/bolts started....really, REALLY tight space to work in. 1" spacer under receiver compensates for lower Syncro engine mount/higher Syncro stance. I have the stock '90 "Fiberglass" bumpers.
Please heed GW's warning about 'older' 2" receiver Bike racks and accessories. I made the mistake of inserting a 1 1/4" adapter sleeve into the GW 2" receiver in order to use an existing 1 1/4" draw bar. Will now need to drop the hitch to pound the adapter out of the receiver (if possible) and remount the hitch. Ugh!
Good thing I have a 1 1/4" fold down bike rack....though I'd prefer to use my 2" swing away....
Tom
90 Bordeaux (Wine Wagon) Syncro Westy
87 Flash Silver (Silver Slug) Syncro Westy (1996-2011)
86 Bronze Beige Metallic Westy (Tourist Delivery - 1996)
dixoncj
dixoncj is offline
PostPosted: Mon Mar 17, 2014 7:42 am    Post subject: Reply with quote
I have this hitch on my Westy.
The above is what you need to do.
If you're hauling bikes or a heavy load, you definitely need that bar. If you're hauling a lightweight trailer, maybe not.
The bar can add some vibrations to your car because it transmits some vibe from the engine to your frame. I'm also nervous about the bar if I get rear-ended because it's gonna trash my motor mount. But it's a tradeoff - and I always haul bikes on my hitch, so I definitely use the bar.
Kolobok
Kolobok is offline
PostPosted: Mon Mar 17, 2014 8:55 am    Post subject: Reply with quote
Using mine for a platform bike rack. No problems installing, just leave everything loose, like stated above, and maybe put some pressure on the mount to get the holes lined up, and voila! Haven't had to re-tighten mine at all. Solid, solid hitch.
'84 GL Passenger - SOLD Sad
Westified
Westified is offline
PostPosted: Mon Mar 17, 2014 9:01 am    Post subject: Reply with quote
I have this hitch. I had to leave all bolts loose at first then tighten. I did experience vibration throughout the vehicle when I used the bar to the motor mount. I subsequently removed this bar.
1984 Westy Wolfsburg, owned since 1987.
dixoncj
dixoncj is offline
PostPosted: Mon Mar 17, 2014 9:04 am    Post subject: Reply with quote
I've been thinking that to cancel some vibrations, I might take a pair of skateboard truck bushings and some washers and a longer bolt. Put one bushing between the bar and the hitch and one - held in by a washer, between the bolt and the bar. This would isolate the bar - to a degree - almost like a motor mount bushing. If I do, I'll report back.
furrylittleotter
furrylittleotter is offline
PostPosted: Mon Mar 17, 2014 9:31 am    Post subject: Reply with quote
tomkat73 wrote:
Will now need to drop the hitch to pound the adapter out of the receiver (if possible) and remount the hitch. Ugh!.
Try a slide hammer instead.
Neil2
Westified
PostPosted: Mon Mar 17, 2014 9:33 am    Post subject: Reply with quote
I was thinking of using some rubber washers. Let us know if your option works.
tomkat73
tomkat73 is offline
PostPosted: Mon Mar 17, 2014 10:47 am    Post subject: Reply with quote
Neil2
FLO - Brilliant! I'm an idiot....:0)
Tom
furrylittleotter
PostPosted: Mon Mar 17, 2014 11:14 am    Post subject: Reply with quote
We all have our moments... Wink
campism
campism is offline
PostPosted: Mon Mar 17, 2014 1:39 pm    Post subject: Reply with quote
If the hitch insert is stuck into the receiver part, can't you just hook the ball/adaptor part to something stationary and drive away from it, pulling the insert out? The object may need to be seriously stationary.
'87 Westy in Wolfram Grey Metallic
dobryan
dobryan is offline
PostPosted: Mon Mar 17, 2014 3:17 pm    Post subject: Reply with quote
Yep, kinda like this....
Dave O
Join the Vanagon Rescue Squad on the VanAlert app.
http://vanalert.com/
Building a bus for travel in Europe
