johnny chingas Samba Member
Posted: Mon Mar 17, 2014 9:06 pm Post subject: Solex 28pict-1 gas leak? |
Well I have the common fuel leak at the throttle shaft bushings on my 28pict-1 carb. I have been reading up on this and apparently there are only a few things that could be causing this leak. I went out and bought a fuel pressure gauge today and I'm running at 4psi, I'm going to buy some gaskets tomorrow and try to bring the fuel pressure down to 2.8-3, if that doesn't do the trick I have read a lot about "check the needle and seat / adding a bigger shime" what exactly is this referring too any pictures I'm clueless on this, what is a needle and seat and shime? I'm trying to eliminate a few things before I have to pull the trigger and sent out the carb to volksbiz for a overhaul!! Can some one help me out with detailed pictures!! _________________ My favorite color is rust! |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Mar 18, 2014 7:03 am Post subject: |
shims not shime _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
