oscarsnapkin Samba Member
Joined: October 22, 2013 Posts: 558 Location: Bucks County, PA
Posted: Fri Mar 21, 2014 2:22 am Post subject: Need some help with my T4 fan shroud |
I'm trying to figure out what I need here for my fan shroud to function properly.
What am I missing here to hold the spring down? Is it simply a flat metal tab that screws into the shroud, or is it something more elaborate? If anyone has a picture of a correct setup I would love to see it.
This side is simply a flat tab that holds the flapper rod?
Will this missing flap affect engine cooling? Any ideas on rigging up a replacement flap? Will I be able to access this once the engine is installed if I wanted to add a flap once I find one?
One final question about the large cooling flaps on the back of the shroud (I forgot to take a picture). When they are in the 'closed' position, they do not completely close, and they leave a small gap between the flap and the shroud. This is normal I assume? Thanks. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind." |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Fri Mar 21, 2014 5:20 am Post subject: Re: Need some help with my T4 fan shroud |
oscarsnapkin wrote: |
What am I missing here to hold the spring down? Is it simply a flat metal tab that screws into the shroud, or is it something more elaborate? If anyone has a picture of a correct setup I would love to see it. |
There's a small metal tab that hold everything in place:
This side is simply a flat tab that holds the flapper rod? |
Will this missing flap affect engine cooling? Any ideas on rigging up a replacement flap? Will I be able to access this once the engine is installed if I wanted to add a flap once I find one? |
The flaps are critical to proper engine cooling. I wouldn't assemble anything without them. Once the engine is in you could still access them but, trust me it's much, much more simpler right now.
One final question about the large cooling flaps on the back of the shroud (I forgot to take a picture). When they are in the 'closed' position, they do not completely close, and they leave a small gap between the flap and the shroud. This is normal I assume? Thanks. |
If memory serves me correct there is a small gap. Also, now's a good time to clean and paint your shroud. _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
Randy in Maine Samba Member
Posted: Fri Mar 21, 2014 7:40 am Post subject: Re: Need some help with my T4 fan shroud |
The little lever that holds the wire looks like it is bent off the the right a bit. I would grab it with a cresent wrench and gently bend it back.
It will not hurt you cooling system one iota to run without these flaps. I would not have them on my bus engine as they have a notorious habit of breaking off and falling into the heat exchangers thus blocking heater air flow. They are a hold over from a Type 4 car which had a gas heater that could be run while the engine was off and were used to prevent the back flow of air from the heater fan through the fan shroud instead of forward into the cab where it was wanted.
The little covers that go over the flaps are very important as you will have both poor heater performance and lessened cooling air flow without them. I seal the heat exchangers and the little covers to the fan shroud with copper silicone to both prevent air loss and to prevent the wear that comes from the relative movement between the parts. |
curtis4085 Samba Member
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Mar 21, 2014 9:31 pm Post subject: |
The small covers that go over the flaps in the lower cooling shroud aren't a deal killer in terms of either cooling capacity or heat loss to the cabin. If you have the covers use them if not don't sweat it.
I've worked on enough T-4 buses with and without them and found the difference in cooling loss/heat loss is...nil...zero.
Ever put your hand over one that didn't have the cover/s with the engine running? You feel almost next to nothing in terms of any loss.
But if you have the parts...use them.
What is 'Critical' is to make sure that the tubes running from the HE's to the auxiliary heater fan are in place. If not make sure they are capped/blocked off otherwise you'll flood the engine compartment with hot air which will get drawn back into the cooling fan.
The auxiliary heater fan has flaps inside that open/close with fan use/non use. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
raymino Samba Member
Joined: August 26, 2009 Posts: 85 Location: Durango, CO
Posted: Mon Mar 24, 2014 1:01 pm Post subject: |
x2 on the Gibbs Brand. It is the stuff! Looks great on tranny case too!
Thanks Randy _________________ '79 Westy Headflow Masters 2.0L FI
'87 GTI 16V Sold!
'06 Jetta 2.5 Package 2
'71 Super Marine Blue |
Posted: Mon Mar 24, 2014 1:54 pm Post subject: |
raymino wrote: |
Thanks Randy |
I have used it on a lot of stuff that needs protection from the elements but can't or don't want like paint...CV joints halfshafts, shifter rods, transaxles, snowblower, tablesaw, jointer, metal fuel rails, and similar stuff. Sort of pricey, but it doesn't take much.
The gun guys I know swear by it. |
Posted: Tue Mar 25, 2014 1:22 pm Post subject: |
Here's a picture that does a better job of asking my question. The curved piece that the yellow arrow is pointing to, is that a separate piece that holds the spring in place, or is it part of a piece of tin? I just can't seem to figure out how he spring is locked into its loaded position. _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
Posted: Tue Mar 25, 2014 1:45 pm Post subject: |
That's where spring end goes _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Posted: Tue Mar 25, 2014 1:59 pm Post subject: |
curtis4085 wrote: |
That's where spring end goes |
That part I understand. I'm trying to figure out what exactly the piece that holds the spring in place is. Is it a part of the tin? Is it its own separate part? _________________ - 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
Posted: Tue Mar 25, 2014 2:04 pm Post subject: |
curtis4085 wrote: |
That part I understand. I'm trying to figure out what exactly the piece that holds the spring in place is. Is it a part of the tin? Is it its own separate part? |
Spring sits on flapper shaft. And that arrow points to the tab on fan shroud is what holds the load. _________________ Special Thanks to:
Posted: Tue Mar 25, 2014 2:09 pm Post subject: |
curtis4085 wrote: |
Your picture looks like it answers te question
https://www.thesamba.com/vw/gallery/pix/916733.jpg
Are you wanting to know what pulls the flapper down? If so that's a cold thermostat. When there is no stat or engine hot the flappers are up. _________________ Special Thanks to:
Evilrift Samba Member
Posted: Sun Apr 06, 2014 2:10 pm Post subject: |
It is uncanny that this is a recent post as I have identical questions. Does anyone know if you need the metal shaft retaining springs? The book says there's two of them but neither my 79 or 78 shrouds have them.. Anyone have a close up? |
Posted: Sun Apr 06, 2014 2:38 pm Post subject: |
Ok, I found a picture in Wilson (150) and will fab a piece up. |
Posted: Sun Apr 06, 2014 2:42 pm Post subject: |
Are you referring to the 2 little clips that hold the black "flap rod" in position?
Those are made of "spring steel" and require those little bushings near the flaps. |
Posted: Sun Apr 06, 2014 3:24 pm Post subject: |
What do you mean little bushings? The plastic pieces that sit in the valley?
I'm also not sure what spring steel is but I have some thin steel that I can cut up, and I assume since its just a safety to stop the rod from coming up and out of the valleys it shouldn't need to be much. |
rustbus Samba Member
Posted: Sun Apr 06, 2014 4:58 pm Post subject: |
if you ever see some of the metal banding they use on shipping pallets, that's pretty stiff steel would be a good match for these little clips. free-as too. _________________ May of '72 Deluxe. 2.0L L-Jet CS & 091 trans conversion
my Bus thread |
Posted: Sun Apr 06, 2014 7:25 pm Post subject: |
Evilrift wrote: |
Yes those ar the bushings. I don't know where you can get them.
Spring steel is not "bendable" amnd will not accept a "bend". It is maybe about 1/8" to 1/4" and a local steel guy could point you to a source. |
