Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Sun Mar 23, 2014 11:45 pm Post subject: Trick For Removing Foam From "C" Pillars |
My Fastback has that yellow foam in the rear pillars.
Anybody have a trick for getting it out?
It's a tight fit in there!
Somebody here has to have a sweet trick I coulda never thought of... _________________ Bus Motor Build
What’s That Noise?!? |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Mon Mar 24, 2014 2:48 am Post subject: |
coat hanger wire, air gun. _________________ The best of VW engine development!
https://www.youtube.com/watch?v=BROWqjuTM0g
71 Aussie notchback, the money pit
92 VP vacationer, old faithful never die
95 VR executive, Restored beyond factory
92 VP S Pack, bought it new old |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Mon Mar 24, 2014 4:16 am Post subject: |
yep I have used coat-hanger wire...next time I might try a blow torch or acetone/thinners (not at the same time!!) |
Jason37 Samba Member
Posted: Mon Mar 24, 2014 6:22 am Post subject: |
I would cut an access hole and blast. That stuff retains moisture so there s bound to be rust in there. |
Yabbadubbadoo Samba Member
Posted: Mon Mar 24, 2014 6:48 am Post subject: |
Someone said the magic word. _________________ Sydney, Australia.
66 Type 3 Fastback |
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Mon Mar 24, 2014 7:48 am Post subject: |
I use that stuff in other parts of my life. carb cleaner will soften it or dissolve it but that might make it worse. _________________ 70 fastback automatic 06 invader |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Mar 24, 2014 8:43 am Post subject: |
A torch will burn out the foam and any/all the paint you probably want removed anyway. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Mon Mar 24, 2014 11:40 pm Post subject: |
OK, trying to understand...
How do you use a coat hanger wire to remove the foam?
Make a twisted "egg-beater" thingie and put it in a drill?
Was really scared to use fire.
I could see that stuff being hard to put out once it gets going.
It might burn hot and warp the metal?
Make a goopy, stinky mess?
An issue with fire, that is also my main fear with using chemicals, is this:
When the car was new, it got a phosphate dip, right?
And capillary action carried it into all of the seams.
There it sits, (at least some of it) protecting hidden metal.
When you use paint remover, you have to tape up any seams,
because if you get any in there, you will never get it back out,
and it will ruin paint.
That's also why dipping cars in a stripper bath is considered a bad idea by some people.
It will also remove/damage the phosphate, and cause water to easily enter and attack at the seams, from the inside out.
So, that's why i was scared to use chemicals or fire;
because it might remove some of the rust protection the factory put in.
How's about using a frayed old speedo cable?
Anyone ever try that one?
I'm going to try a couple of these, and put it up here or in my build thread. _________________ Bus Motor Build
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
ClockRoach Samba Member
Posted: Tue Mar 25, 2014 6:59 am Post subject: |
Once you get the old foam out, is it worth trying to replace it with something new? I'm wondering about noise and water infiltration. _________________ 1971 Squareback daily driver, "Ada" |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Tue Mar 25, 2014 8:03 am Post subject: |
I just left in my wife's 70 Fastback, as it doesn't have the vent slots in the "C" posts. I haven't seen any rust bubbles or anything like that, and the car got painted back in 1990. Now, IF it were a 71 and later, I'd definitely remove it, as it'll get wet and cause rust (the reason I cut the roof off my 71 Square). But the earlier cars don't really suffer from this sort of problem. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Tue Mar 25, 2014 8:09 am Post subject: |
Looks like the C-pillar foam is pretty far forward in the fastbacks-- forward of the bulkhead piece? Not sure what that hole is for... sunroof drain maybe?
You can see the foam's "shadow" here after they peeled the roof off my '71:
vlad01 Samba Member
Posted: Tue Mar 25, 2014 3:34 pm Post subject: |
do notchback 71+ have this foam?
I have seen them in fasty and square but their pillars are much fatter, never cut open a notch in that area to find out. _________________ The best of VW engine development!
Nate M. Samba Member
Joined: August 11, 2003 Posts: 1306 Location: Anacortes, WA U.S.A.
Posted: Tue Mar 25, 2014 3:57 pm Post subject: |
Whatever you do, do NOT burn it out. . . That will introduce it's own set of problems.
Once you get the OEM stuff out with a coat hanger or frayed clutch cable, you will want something in that void to block the noise from getting into the car's passenger area. I would recommend using a zip-lock freezer bag and expanding foam (in the freezer bag). This will effectively block the noise while keeping moisture from being a problem and you'll be able to remove it if need be. _________________ Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!! |
vlad01 Samba Member
Posted: Tue Mar 25, 2014 4:43 pm Post subject: |
noise is good. i would leave them out. _________________ The best of VW engine development!
vlad01 Samba Member
Posted: Tue Mar 25, 2014 8:20 pm Post subject: |
Bobnotch wrote: |
vlad01 wrote: |
do notchback 71+ have this foam? |
Yes. |
Fantastic! _________________ The best of VW engine development!
