dr. no Samba Member
Joined: August 06, 2004 Posts: 578 Location: Santa Fe
Posted: Tue Mar 25, 2014 10:02 pm Post subject: Diesel overheating with normal temp gauge... |
After the recent rebuild saga (http://www.thesamba.com/vw/forum/viewtopic.php?t=585693), i was back on the road... briefly. (1.6td, JX engine meant for German Vanagons)
Intermezzo included having the wrong size rings and bearings delivered by otherwise reputable local and national suppliers (something for a different, whining post). I got quite good at whipping the oilpan off and on...
Then setting the timing etc went well and it ran! Quite nicely, smooth, more power up and down the driveway (it's half a mile to the mailbox) and beyond. Tonight I took it further, about six miles downhill, no problems that a little idle adjustment/smoke screw shouldn't fix. Then, halfway home: loosing power, normal coolant temp and EGT. Pulled over, would not idle and shut off. I noticed steam coming out the vent, and went to look... boiling coolant. The alternator/pump belt was tight enough and the pump pulley turns when turning over.
I haven't disassembled yet, but, assuming the sender is working (and it went to it's normal place, just below the LED), overheating covertly should mean the water pump isn't pumping. How else? No hose leaks or other leaks. Also, not coming out through the reserve tank, although plenty of pressure, so probably a bad cap on the pressure tank. Bad head gasket or any other internal leaks, if the pump were pumping, would deliver hot coolant to the sender, right?
How to prevent covert overheating? I think that a burst hose did this to my original head in the first place, so I'm tired of it. Oil temp gauge as a backup? _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant--wonderful!
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
bluefirefly Samba Member
Joined: March 16, 2011 Posts: 438 Location: Calgary, Ab
Posted: Wed Mar 26, 2014 4:45 am Post subject: |
Is it possible you still have air in the cooling system and your coolant pump isn't "moving" anything?
Sorry, only guessing as I never worked on a TD before.... _________________ 86 Syncro Tintop G60
work in progress ...as always! |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Wed Mar 26, 2014 5:54 am Post subject: |
the sender only records the temperature at the point in the system.
if there's no water but only steam there it'll show ~212*f, very happily in the middle of the gauge.
I'd say you likely have air in the system or an incorrect coolant flow path. _________________
Abscate wrote: |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Wed Mar 26, 2014 6:02 am Post subject: |
does the radiator get warm?
is it cold on the top (air) and hot on the bottom?
is it all cold? then either pump is dead (unlikely, i think they make lots of noise when they die) or perhaps the thermostat (not opening).
another option is you have a leak and the system is not holding pressure. do the hoses feel firm (like bike tire inflated firm - or rather, half that).
not a bad idea to buy one of those laser/IR thermometers then you can point it at stuff and see if it is the right temp. but the hand test should work on the rad. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
dr. no Samba Member
Posted: Wed Mar 26, 2014 8:11 am Post subject: |
Thanks! More brains are better than one.
The lack of water may be the issue, but I doubt it. I didn't mention: at the bottom of the hill I had topped off the pressure tank (a pint or less). This is about what I expected, from prior flushes. The fan had kicked on (normal for climbing the hill) so there was warm water getting to the front. It also turned off soon, so there wasn't much staying there.
As I said, it was holding air/water/steam, no leaks. Also, no water in oil, or oil in water.
I'm leaning toward a head gasket leak, or failed pump. It was of the stamped sheetmetal fin type, not cast metal or plastic. It happened rather quickly, with no overheating on the gauge. _________________ Scott
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'77 Bay
'71 Bay
'74 Things (2)
'91 Fox |
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Wed Mar 26, 2014 8:52 am Post subject: |
Causes for over heating in TD engines,
1. Air trapped in cooling system.
2. Pressure tank cap's pressure is not working.
3. Radiator fan not working, fuses, rheostat or relay
4. Head gasket loose or bruned.
5. Wrong timing with timing belt.
6.Wrong fuel Pump pressure.
First check,
Open the cap, start the engine & see if coolant is coming back(with out air) through the small pipe connected to the tank. If yes, then coolant pump & circulation is perfect .
Second check,
Keep the engine running for few minutes until temp reading reaches mid way. Now, fan should switch on, If not check fuses, rheostat or relay.
next, change the cap for the new one. |
Posted: Wed Mar 26, 2014 9:04 am Post subject: |
you opened the pressure tank and added a pint to top it off.. but what about the coolant level in the radiator? did you bleed/purge air?
it's quite possible you were still quite under full on coolant..
dr. no wrote: |
I'm leaning toward a head gasket leak, or failed pump. It was of the stamped sheetmetal fin type, not cast metal or plastic. It happened rather quickly, with no overheating on the gauge. |
Abscate wrote: |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17110 Location: Retired South Florida
Posted: Wed Mar 26, 2014 10:16 am Post subject: |
From memory, it takes about 3 gallons to fill an empty system. How much coolant did you put in? Next, two tips when filling the cooling system on a diesel. One, remove the discharge hose from the head and fill the engine to the brim with your coolant mix. The thermostat will not open if the engine has not coolant in it. I always drill a 1/16th to 1/8th inch hole in the thermostat to help the engine from getting air bound.
I would also add, my diesel takes miles to get to temperature with a properly working cooling system. For yours to overheat in such a short distance, it sounds like the engine had no coolant in it.
Someone also mentioned the cooling house routing. It is possible you have mixed up the main hoses too and from the front. Coolant flows into the bottom of the radiator and out the top. This is opposite of most vehicles. If your last engine blew a head gasket, you may still have a problem. _________________ ☮️ |
dr. no Samba Member
Posted: Wed Mar 26, 2014 10:30 pm Post subject: |
First look:
--No leaks
--I could not tighten head nuts any more (I did not quite get the full last quarter turn after warm-up, too hard!)
--timing belt is intact, turns over by hand without bad noises, static timing remains where I set it (1.00)
--turns over with key but sounds like something rubbing -- belts look ok and oil pressure light goes out while cranking, stays out for longer (than I was used to with old pump) after stopping
--caught and ran for a minute, but then the battery gave up.
It's looking like there was perhaps not enough coolant, though I put in over two gallons, the radiator was warm enough for the low-speed fan to come on. When this had a gas engine, I always had to purge many times from the radiator bleed. Since conversion, I have only needed to run it a little, top off and repeat a couple of times. The diesel hose configuration works (ed) better.
Why would it make any significant difference which way the water goes through the radiator in a pressurized system? It's not a thermosiphon, there is always a pressure gradient. The only difference I see is that filling from the bottom would help obviate the need for bleeding at the radiator, as air would be purged back to the tank (or perhaps to the pump to cavitate).
And for distance to warm up, we live at almost 8000 feet, almost 1000 higher than town (Santa Fe). When I say "hill" it's more than the altitude difference between Houston and Dallas... _________________ Scott
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'77 Bay
'71 Bay
'74 Things (2)
'91 Fox |
Posted: Thu Mar 27, 2014 6:30 am Post subject: |
Quote: |
Why would it make any significant difference which way the water goes through the radiator in a pressurized system? |
It just does in a vanagon.
In a diesel the thermostat preforms two functions. When cold the thermostat closes the main circulation path and opens the bypass, the hose between the head and the waterpump. This allows coolant to flow as soon as the engine starts and lets it warm up to temp quickly. As the engine comes up to temp, the thermostat closes the bypass and open the main path to and from the radiator.
The position of the thermostat in the pump housing is also critical. You need to ensure that the tangs that hold the thermostattogether are aligned with the block and the water pump case. Other wise they will block the flow of the coolant through the water pump some affecting performance. _________________ ☮️ |
Posted: Thu Mar 27, 2014 7:20 am Post subject: |
on my van one of the hoses was pinched under the spare tire in the clamshell. i'm not sure how common that is, but i suspect it didn't help matters.
the water routing makes sense - hot water moves up. there is a large amount of water to move around in a vanagon. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
