1978 Westy Full Restoration with Matching Custom Trailer
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
scirocco_crazy
scirocco_crazy is offline
PostPosted: Sun Aug 14, 2016 8:21 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
how about some air conditioning talk? this unit is a 6000 btu model with a super high seer rating. the fit is very snug but I wanted the end result to look factory installed. when the unit is running its really quiet and belts out some serious cold air. I used the exact dimension of the piece of glass I removed so that a factory window seal will work of it ever needs to be removed. What do you think?
[img]
[/img]
[img]
[/img]
Current build
http://www.thesamba.com/vw/forum/viewtopic.php?t=589790&highlight=westy
Previous build
http://www.thesamba.com/vw/forum/viewtopic.php?t=516038&postdays=0&postorder=asc&start=0
scirocco_crazy
PostPosted: Sun Aug 14, 2016 8:23 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
To Keep water from coming in during a rain I will have a magnet panel that will attach to the scoop portion
Current build
Previous build
scirocco_crazy
PostPosted: Sun Aug 14, 2016 8:33 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
now that the a/c unit is installed I went on to building a device to catch the condensation produced during operation. This will be installed at the base of the mounting plate. The photos will show what I am yacking about.
I will install it tomorrow.
[img]
[/img]
Current build
Previous build
newstarr
newstarr is offline
PostPosted: Sun Aug 14, 2016 9:26 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
This is so amazing!!!! You are making me want to take a welding class!!!
scirocco_crazy
PostPosted: Mon Aug 15, 2016 5:51 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Thank you, It has taken me years to learn how to do it. and yes I still mess up from time to time
Current build
Previous build
scirocco_crazy
PostPosted: Mon Aug 15, 2016 6:03 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
suspension update, due to a trailer tow need I felt that Koni's on the rear wouldnt work with a heavy load so I put in air shocks so that they can be leveled depending on the load. I put a schrader valve port under the rear seat that can be hooked up to a small compressor. Up front I did opt for a pair of koni shocks, while I had the front on jack stands I dropped out the front beam and welded in a wagenswest beefcake adjusters to lower her down. After that I finished it off with new ball joints, rotors, brake lines, and calipers thanks to The Bus Depot. The new large diameter sway bars (front and Rear) help out the ride. I also installed the lowering plates in the rear from Nate at Wagenswest. By the way his products are some of the best I have ever used.
Current build
Previous build
Last edited by scirocco_crazy on Thu Aug 25, 2016 12:30 am; edited 1 time in total
scirocco_crazy
PostPosted: Thu Aug 18, 2016 12:26 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Here is a quick video of the almost finished air conditioning and refrigerator install. enjoy
Current build
Previous build
chabanais
chabanais is offline
PostPosted: Thu Aug 18, 2016 2:40 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Clean install!
"I spud therefore I yam."
Hikelite
Hikelite is offline
PostPosted: Fri Aug 19, 2016 10:21 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
What a great build.
I hope my wife doesn't stumble upon this, or I'll have to figure out how to add AC to our bus :p
So I take it you don't plan to do a lot of off road type camping since you lowered it, huh?
Love the whole build. The only thing I can't wrap my head around is a lowered Westy. I guess there are plenty of places to camp that don't need high clearance. *shrug* to his own. It does LOOK great! Just confusing to my eyes. lol
Hope you're health is still improving. Thanks for sharing your project. Beautiful work.
~Kevin
My 1968 Campmobile She is drivable again!
scirocco_crazy
PostPosted: Sun Aug 21, 2016 9:05 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Hikelite wrote:
What a great build.
One of the best things about the Wagenswest kits are the fact give an afternoon you can return it to stock height. Best of both worlds
Current build
Previous build
scirocco_crazy
PostPosted: Sun Aug 21, 2016 9:07 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Tonight I installed what I hope will be a great addition to the bus. Its the Empi Heavy duty rear sway bar. Pretty straight forward install.
[img]
[/img]
Current build
Previous build
scirocco_crazy
PostPosted: Thu Sep 01, 2016 4:06 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
I put together a video illustrating the build from day 1 to the finish. I had music to go with it but due to youtube copyright concerns they muted it. No worries. Enjoy
Current build
Previous build
BusPriest
BusPriest is offline
PostPosted: Thu Sep 01, 2016 6:30 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Can the A/c run off the house battery?
1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest.
Tcash
Tcash is offline
PostPosted: Thu Sep 01, 2016 9:34 am    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
Nice video. I added to:
Youtube Videos
Thank you
Tcash
brettsvw
brettsvw is offline
PostPosted: Sun Aug 13, 2017 8:48 am    Post subject: Reply with quote
scirocco_crazy wrote:
Fella's, here it is. I must say I love it!
[img]
[img]
[/img]
[/img]
Trailer is fantastic. Love the fact you can see the torsion housing covers.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
MorkC68
MorkC68 is offline
PostPosted: Sun Aug 13, 2017 1:18 pm    Post subject: Re: 1978 Westy Full Restoration with Matching Custom Trailer Reply with quote
excellent build thread, that's one stunning westy you have Very Happy
Gusbus; 1973 Kombi
Major; 1977 Westfalia Campmobile
My blog: https://twolatebays.wordpress.com/
Page 9 of 9
