cvallone Samba Member
Joined: May 13, 2007 Posts: 875 Location: Congers New York
Posted: Thu Apr 03, 2014 9:44 am Post subject: Speedi Sleeves for Vintage VW 25-36hp Flywheels |
Has anyone ever used a speedi sleeve for their VW flywheels that Porsche suppliers offer? These can help stop the notorious back nut oil leak that seeps past the rear main seal.
Are the early 356s flywheels the same as a beetles?
Please let me know, it seems like it would really help the old flywheels that we cannot buy repoped.
Chris _________________ My restos www.classicvwbugs.com
Restoring Beetles back to their historical beauty. |
Center Pin Samba Member
Joined: August 07, 2012 Posts: 74 Location: Langley BC
Posted: Thu Apr 03, 2014 12:37 pm Post subject: |
I've used them in many application, but not on a VW. They are great! often the finished surface is better than OEM of the shaft. You can buy them from any industrial bearing supplier. |
Last Triumph Samba Member
Joined: October 10, 2006 Posts: 914 Location: Wirral, United Kingdom
Posted: Thu Apr 03, 2014 1:23 pm Post subject: |
The Porsche and the early VW crank are the same diameter. |
Posted: Thu Apr 03, 2014 3:39 pm Post subject: |
Can anyone recommend a supplier? I see stoddard sells them for like 50 bucks. Is anyone else cheaper?
Posted: Thu Apr 03, 2014 4:14 pm Post subject: |
cvallone wrote: |
Chris |
Any bearing supplier that carries SKF Bearings will have them or get them. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Apr 04, 2014 7:49 am Post subject: |
I have used them and found them on ebay for about $10- -$15 _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Fri Apr 04, 2014 9:29 am Post subject: |
60ragtop wrote: |
I have used them and found them on ebay for about $10- -$15 |
Ok, what do I search for on eBay? I have done a search for these and many come up, just not sure what specifically to punch in to narrow down the list.
I do not want to buy the incorrect size.
Please let me know,
Posted: Fri Apr 04, 2014 1:10 pm Post subject: |
I just used the speedi sleeve # and did a search for that. I'll look and see if I kept the # in my folder. I found the # at the local flaps who still know how to use paper catalogs for reference _________________ Rick
tasb wrote: |
sb001 wrote: |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Fri Apr 04, 2014 2:30 pm Post subject: |
60ragtop wrote: |
I found the # at the local flaps who still know how to use paper catalogs for reference |
So, from a grey haired fella, is what you're saying. 'Cause the kids certainly don't know how to work a paper catalogue. _________________ sent from a phone using poor grammar and spelling |
Posted: Fri Apr 04, 2014 4:15 pm Post subject: |
60ragtop wrote: |
I just used the speedi sleeve # and did a search for that. I'll look and see if I kept the # in my folder. I found the # at the local flaps who still know how to use paper catalogs for reference |
Ok let me know when you find it.
Posted: Sat Apr 05, 2014 9:07 am Post subject: |
Nope not from a grey hair, actually younger than me
Chris, I couldn't find the number but I'll keep looking and talk with the youngster to see if he can find it again.
Or see if you can get the Stoddard number then you can get the size perimeters and search that way. _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Sat Apr 05, 2014 2:15 pm Post subject: |
60ragtop wrote: |
Or see if you can get the Stoddard number then you can get the size perimeters and search that way. |
That would be awesome, thank you. What do some guys do to repair the flyweel grooves? I would think build up the groove then machine it down, correct? _________________ My restos www.classicvwbugs.com
58Blue Samba Member
Joined: June 30, 2010 Posts: 114 Location: Ontario, Canada
Davemccabrio Samba Member
Posted: Mon Apr 07, 2014 2:22 pm Post subject: |
this is the one I used, CR 99235
specs 2.359- 2.365
Application 1949-1960 VW flywheel _________________ Rick
tasb wrote: |
sb001 wrote: |
GüteAndTite Early Convertible Güru
Joined: June 16, 2005 Posts: 2144 Location: Low So Cal
Posted: Tue Apr 08, 2014 6:43 pm Post subject: |
SKF Speedi-Sleeve
SKF Speedi-Sleeve This thin-walled sleeve [0,28 mm (0.011 in.)], developed by SKF, is simply pushed in position over the worn area, providing a counterface surface that is optimized for radial shaft seals.
There is no shaft disassembly or machining involved and costly downtime is minimized. Since the same sized seal as the original can be used, there is no need to search for other seals, or keep a stock of different sizes.
No special equipment is required since the installation tool is supplied with the sleeve. A mallet and a pair of pliers are all that is needed for the installation.
Features
The new generation SKF Speedi-Sleeve uses a proprietary stainless steel material and manufacturing process, resulting in an optimized seal counterface surface that minimizes wear on both sleeve and sealing lip. The proprietary material provides increased strength and excellent ductility properties of the sleeve. Imperceptible lubricant pockets enable the lubricant to reside on the sleeve and thereby prevent dry running of the sealing lip that otherwise can create excessive wear. The contact surface is wear resistant and machined to minimize directionality (0° ±0,05) with a finish of Ra 0,25 to 0,5 µm (10 to 20 µin.). This is, in fact, a better counterface surface than can often be achieved on a shaft.
SKF Speedi-Sleeve has a removable flange to simplify installation (fig 1). The flange can most often be left intact, but in applications where the flange will interfere with other system components, it should be removed so as not to cause friction heat and wear debris. The flange should also be removed in applications where it may reduce the supply of lubricant to the seal. This would reduce the cooling effect of the lubricant, resulting in elevated underlip temperatures and premature aging of the seal material.
tasb wrote: |
sb001 wrote: |
leowagen Samba Member
Joined: October 16, 2018 Posts: 171 Location: Argentina
Posted: Sun Apr 18, 2021 11:20 am Post subject: |
60ragtop wrote: |
specs 2.359- 2.365
Application 1949-1960 VW flywheel |
Hello! Sorry for refloating such an old thread... I just got the same speedi-sleeve (99235) and have a question about it. How did you trim it dow after you installed it? it is much longer than the flywheel neck...
Thanks a lot and stay safe! _________________ Frankenwagen: full 1957 pan, under late 60s Brazilian body |
