harley-big-dog Samba Member
Posted: Thu Apr 03, 2014 12:13 pm Post subject: Reduction box to spring plate question? |
Hi all,
1st time im having a lash doing my own mechanics so not fully sure of my self.
Im fitting 1 rear axle reduction box as the last one the 3 bolts that fit the reduction box to the spring plate the 3 bolts walked them selves out and damaged the thread in the boxes.
Iv just fitted the outter tube of the reduction boxes over the rear swing axle but the 3 bolt holes on the spring plate dont fit flush with the reduction box bolt holes ie... the bottom bolt holes when lined up with spring plate and reduction box touch together but the other 2 bolt holes go angled out up to 1 1/2 cm to the top bolt hole, which dont sound much but it seems the spring plate will put a lot of pressure on the top 2 bolts and some where has to move over when i bolt them in... hope this all makes sence
Question is... is this all ok and just the norm or could this be causing a problem which may of have caused the problem in the 1st place?
Help and advice would be top stuff. thanks |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Thu Apr 03, 2014 12:30 pm Post subject: |
Hope this helps you at least some... until you've done this swap a number of times, it is best to have at least another person helping you out. In my early days, a transaxle swap was a 2 day 2 man job!
The fine thread of them bolts is prone to stripping if not started correctly or is over-torqued. If stripped, best way to fix it is with a helicoil insert. I've rethreaded with a larger size thread but that requires opening up the holes on the plates and then there will be some "slop" which may cause other issues later.
There's a hundred ways to skin a cat, though he prolly don't like any of 'em! First, try to find the hole that aligns the easyest and with least resistance and make sure to start the thread correctly but do not tighten all the way. Just enough to hold the RGB in place. Then align the next hole and repeat. It is indeed a PITA but can be done with care. Good luck!
BTW, I do not miss that job at all since changing to IRS. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Thu Apr 03, 2014 12:51 pm Post subject: |
Cheers for the info pal, it has been a complete ball ache shows me why iv been paying people in the passed but i must say iv enjoyed quite a bit of it and i want learn... hence giving it a lash myself
iv ordered some new bolts which i should get tomorrow so will have ago with your info but i have seen in the old trusty Splity manual that you should put the bolts in a pacific order, starting with the middle bolt then the bolt close to the dampers then the 2 outer bolts as there are 4 bolts holding the reduction box to the spring plate
Beer time me thinks BURP!!!
Think i may need to swap over to IRS sometime soon as this is the 2nd time its happened
cheers fella |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Thu Apr 03, 2014 1:04 pm Post subject: |
Use a clamp to pull the springplate flush to the RGB housing. You should be able to run the bolts in with your fingers. If you use the wrench to pull the springplate in, you may pull the threads out |
Posted: Thu Apr 03, 2014 1:14 pm Post subject: |
Genius Chris... why didnt i think of that
Cheers dude sounds like a plan for tomorrow mornin |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Thu Apr 03, 2014 1:45 pm Post subject: |
x2 on this method. I also use a big clamp when removing the same bolts also to prevent stripping/stress on the threads.
chrisflstf wrote: |
_________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Thu Apr 03, 2014 2:37 pm Post subject: Re: Reduction box to spring plate question??? |
harley-big-dog wrote: |
... as the last one the 3 bolts that fit the reduction box to the spring plate the 3 bolts walked them selves out and damaged the thread in the boxes... |
Also, didn't see anyone mention this, but there should be lock plates for those 3 bolts to prevent them from walking out, or at least mine had them and believe them to be stock... _________________ -Adam
'59 Mango Bus
'11 Golf TDI 6-speed
'69 Bug |
Posted: Thu Apr 03, 2014 2:49 pm Post subject: |
What are lock plates mate? i cant be doing with them bolts going walkies again.
cheers |
Posted: Thu Apr 03, 2014 3:09 pm Post subject: |
cheers |
Sorry I couldn't find any pics in the gallery, and this is the best pic I could find. I can go take a better pic soon. The plates go on like a washer would, and you bend part of the lock plate on the flat side of the bolt so it won't move...
'59 Mango Bus
'69 Bug |
Posted: Thu Apr 03, 2014 3:12 pm Post subject: |
I just use split lockwashers. But you need to re-torque them after 50 miles or so, as they will come loose. There is a torque sequence also that should be followed |
Posted: Thu Apr 03, 2014 3:19 pm Post subject: |
thanks for that,very good to know, im going to look into these lock plates more,sounds like the way forward... thanks very much for your time & info dude |
Posted: Thu Apr 03, 2014 3:21 pm Post subject: |
chrisflstf wrote: |
... There is a torque sequence also that should be followed |
Yeah, I forgot about that, I tried to find it, but think it was in the Bentley, which is at home, and can't remember it off the top of my head, but think it was rear middle, then front, then top rear and bottom rear??
And one of the manuals (the one available in the tech section) says to tighten those bolts to 72 ft/lbs.
Found it, yup, torque sequence, is middle rear, then front, then the remaining two rear ones...
'59 Mango Bus
'69 Bug |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
joe cool Samba Member
Joined: August 20, 2006 Posts: 1259 Location: Yolo County CA
Posted: Thu Apr 03, 2014 8:52 pm Post subject: |
x2 on Time-Serts. 14 years and 8 SST's and still holding strong. |
Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
Posted: Thu Apr 03, 2014 10:58 pm Post subject: |
There is a standard tap that is close enough in thread pitch and size you can retap the holes. I had to do this in the previous trans I had in my bus. I tapped the holes out deeper and used grade 8 hardware. I got this information from a thread on here about stripped spring plate bolts or timeserts. It was the perfect size that did not require drilling out the holes. I stripped them the same way you did. When I installed another transaxle later on I did as the others suggested and used a clamp to line it up. _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
1978 Westfalia Camper
Transmissions For Dummies |
Posted: Fri Apr 04, 2014 2:12 am Post subject: |
cheers guys... how do i know the torque of the bolts 72 ft/lbs i think one of you mentioned? |
Posted: Fri Apr 04, 2014 5:00 am Post subject: |
Use a torque wrench is best.
Going to a slightly bigger bolt is not so good an option. If you strip the hole out later you just have to go to even a bigger hole. With Time-Sert you just have to remove the insert and install a new one instead. _________________ In Stereo, Where Available! |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Fri Apr 04, 2014 9:03 am Post subject: |
From the Bentley Manual-
"From Chassis No. 1197853, the lock plate- Part No. 211513535 for the spring plate securing screws was replaced by a spring washer- Part No. N122321."
I think that is roughly the start of Bignut trannies, n'est pas?
If you don't have your own copy of the Bentley Manual, well, WTF, over? A guy can't be running to the interwebs whenever he runs into a question in the middle of wrench-time, now, can he (or she, of course)? _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Apr 04, 2014 9:25 am Post subject: |
72 lb ft x 1.355818 = 97.61 Nm |
