bluebus86 Banned
Posted: Fri Apr 04, 2014 12:20 pm Post subject: tire chain size |
Hi: I got an 86 vanagon and have Hankook RA08 195R14 tires on stock steel rims. I understand these are larger tires than stock.
I need to fit tire chains on the van. the tire chain refereance charts do not list a 195R14 tire. the listing has a number rather than "R" in the tire sizing (example 195 75 14)
how do I translate the 195R14 tire size to one of the numbered sizes???
see attached tire size/chain chart....http://g-ecx.images-amazon.com/images/G/01/automotive/detail-page/SCC_Tire_Guide_2013_Passenger_Light_Truck.pdf
thanks!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Fri Apr 04, 2014 12:30 pm Post subject: |
The '75' in your example is the aspect ratio -- that would be approximately '80' for a metric tire like you mention.
I believe the 'R' simply indicates that the tire is a radial.
So... chains for a 195 80 14 would likely be what you seek. |
bluebus86 Banned
Posted: Fri Apr 04, 2014 12:33 pm Post subject: |
ok, so your saying they left out the number 80 in the tire size designation on the ones I have on my van.
That is not cool, but at least I know what it is equivalent too now, thanks!!!!
golly I have looked all over TireRack and other places and none of the online tire calculators even allow you to enter the R, and with no aspect ratio to enter, the calculators don't function.
So I need to look for chains that fit a 195-80-14 tire.
PS the chain/tire guide that I attached in the above posts does NOT offer a 195-80-14 tire chain size, the list ends at 195-75-14!!!!
crap!!! want to go to Yosemite Saturday, and cant figure what size chains I need. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Fri Apr 04, 2014 1:01 pm Post subject: |
bluebus86 wrote: |
The chain for a 195 75 14 will fit your tires. Tire chains are always quite a bit longer than they need to be so you can cut them to the correct length for your vehicle.
I would remove one of your wheels at home and install one chain on it and take out as much slack as you can. Then cut off the extra links, BUT you should leave 3 extra links on each side so you can install them more easily.
When installing for real use you will want to install as snug as you can, then take the vehicle up to 25 MPH, then gradually slow to a stop on the side of the road and take up any extra links, the large rubber band will pull any/all slack to the outside of the wheel so you will only have to adjust the outside. At this point there should be minimal slack in the chains and you will have no worries about them coming loose or banging any part of your van You might find that you have to remove another link or 2 when you get home, once the "tails" are more than 4 links they could start to hit the body or suspension...
Hope this helps! _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
chimivee Samba Member
Joined: September 23, 2009 Posts: 741 Location: Orange, CA
Posted: Fri Apr 04, 2014 3:20 pm Post subject: |
bluebus86 wrote: |
crap!!! want to go to Yosemite Saturday, and cant figure what size chains I need. |
What part of "California" are you in? I have some chains that fit the stock tires if you're near OC. _________________ -James
86 Syncro Westy, etc |
dcaver01 Samba Member
Joined: February 23, 2009 Posts: 103 Location: Los Angeles
Posted: Sun Jan 03, 2016 6:55 pm Post subject: Re: tire chain size |
Piggy backing on this thread.
I have the Yokohama 185R14 Tires, Model Y356 C.
Need to pick up some chains, can't figure out what the aspect ratio would be for these. Looks like it would be 55, 60 or 65. Not sure why Yokohama doesn't include this number.
Can anyone advise on which size is correct? Also if you have this tire and recommend a specific chain that would be welcomed also.
First time purchasing/using tire chains.
Thanks! |
outcaststudios Samba Member
Joined: February 09, 2015 Posts: 1732 Location: Maine
Posted: Sun Jan 03, 2016 7:20 pm Post subject: Re: tire chain size |
measure the distance from the edge of the tire to the top of the rim and convert it to mm's and that will be your aspect ratio. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791 |
Posted: Sun Jan 03, 2016 7:51 pm Post subject: Re: tire chain size |
Thanks for the reply.
Wouldn't that just give me the section height of the tire? Aspect is width divided by height, right?
I'd love to just get the official number so I can be sure I'm spending my money on the right tire chains. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Sun Jan 03, 2016 7:56 pm Post subject: Re: tire chain size |
That size doesn't have an aspect ratio as part of the size description. 82 or 80 is the closest.
195/75/14 tires are fairly close to that size tire overall.
Mark
dcaver01 wrote: |
Thanks! |
Posted: Sun Jan 03, 2016 8:04 pm Post subject: Re: tire chain size |
dcaver01 wrote: |
the section height is given a number that is a percentage of the width. thus the ratio of height to width. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Posted: Sun Jan 03, 2016 8:10 pm Post subject: Re: tire chain size |
outcaststudios wrote: |
dcaver01 wrote: |
the section height is given a number that is a percentage of the width. thus the ratio of height to width. |
example if your tire is five inches wide and its side wall is 3 inches from the rim then the ratio would be: 125/75/60 since 75 is 60 percent of 125. _________________ '88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
Posted: Sun Jan 03, 2016 8:45 pm Post subject: Re: tire chain size |
Thanks yea, I measured, not sure how accurate it is as I'm using a ruler on a surface that isn't flat.
Came up with 140/120/85
I'll let you know if the snow chains fit these specs. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sun Jan 03, 2016 8:54 pm Post subject: Re: tire chain size |
That's a tough call to measure the sidewall, due to variations in rim lip, and the vagueness of where to measure the height. I like Mark's reply to pick your tire chains - use 75 and since chains are designed for a variety and some extra, they will fit even though the actual size is 80 or 82.
As mentioned, a little prep of the chains and installing them once where it is warm and dry is a great call. You can be sure neither of those two variables will accompany your first real installation! It will be cold, wet, and possibly dark. In addition, it may be stressful due to a storm, and there may be other vehicles blasting past you at uncomfortable speeds and tossing slush on you.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sun Jan 03, 2016 11:25 pm Post subject: Re: tire chain size |
You can't determine the design section width very well as the actual section width is dependent on the width of the rim the tire is installed on. You pretty much need to go by the tire size charts.
Always test fit your chains before heading out into the wilds. |
Posted: Mon Jan 04, 2016 11:35 am Post subject: Re: tire chain size |
Thanks for the feedback guys, I'll definitely do a dry run before heading up into the snowy mountains this weekend.
I'm looking at getting this model from peerless: http://www.peerlesschain.com/tire-chain-finder/traction/tirechains/713
Says it fits 185-14, appears to fit a wide range of tires so maybe this is the way to go. I'll let you know how it goes. If you don't hear back, assume I got stuck in a snow drift. |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1391 Location: Taos NM
Posted: Mon Jan 04, 2016 11:38 am Post subject: Re: tire chain size |
dcaver01 wrote: |
You should really check out the snow chain review that Vanis did a few weeks ago.
Those chains went on really easily and I sent him into a pretty snowpacked dirt road and he did just fine.
60 bucks at walmart. |
Posted: Mon Jan 04, 2016 3:13 pm Post subject: Re: tire chain size |
Thanks Tobias, I checked out the review and those do seem like a solid option. Went ahead and ordered. |
