Total Bummer Forever Samba Member
Joined: March 30, 2014 Posts: 52 Location: San Jose CA
Posted: Mon Apr 07, 2014 5:28 am Post subject: Advice on cleaning up the engine bay |
I have new carbs and ignition coming to me and i figure while I'm going to be in there working anyway, what are some of the best ways to clean up the engine bay and maybe even make a little extra room in there? Also, if you have pictures of your engine to show for reference i would really appreciate it! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Apr 07, 2014 5:38 am Post subject: |
It's pretty hard to make more room with dual carbs.
New tar board is the easiest way to clean it up. You can remove unneeded wiring and hoses.
_________________ Glenn
Member #1009
#BlueSquare |
Dale M. Samba Member
Posted: Mon Apr 07, 2014 5:55 am Post subject: |
For oily greasy crud.... GUNK ENGINE BRIGHT... And pressure washer ( of garden hose with good nozzle)...
Final cleanup with soap and water, and good rattle can of paint.... Black hides a lot....
Posted: Mon Apr 07, 2014 6:15 am Post subject: |
Thanks guys!
So what I've gathered so far is that using a 36hp fan shroud without heater vents frees up some space and also using an electric fuel pump and routing my lines outside the engine bay while mounting my coil where my pump used to be is another option (although I prefer to stick with my mechanical pump if at all possible). Where are a few good places I could put my coil or fuel lines and filters? I've looked up a lot of photos of other people's engine bays but without explanation for where and how some items are located it's somewhat difficult to see the "how". |
Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Mon Apr 07, 2014 6:33 am Post subject: engine bay cleanup |
Get the CB rotary fuel pump and mount it under your vtank with a cut off valve.The pump has a filter in it and yer done. Coil can be mounted on the shroud or on the inner fender with a longer lead wire.Get some of the flexible wire loom and bundle all the wires in it and put it out of the way , making sure all crimped ends are soldered and heat shrink Lots of saved headaches down the road on that one. A clean and tidy engine bay is easy to work/diagnose problems in . _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Art Thraen Samba Member
Posted: Tue Apr 08, 2014 12:42 am Post subject: |
clean
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Tue Apr 08, 2014 3:29 pm Post subject: |
My 1679cc. 36 horse shroud, no heat, coil relocated behind the shroud, electric fuel pump, cross bar painted black to blend in with the shroud, wires tied/clamped to keep them under control, and the tar board replaced.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3293 Location: Rapid City, SD
Posted: Tue Apr 08, 2014 4:17 pm Post subject: |
Less is more. Move the coil, hide the wires, and clean it good. Running an electric pump really cleans up a lot of the clutter too. The smaller center mount linkages seem to hide better than a crossbar too.
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Apr 08, 2014 4:56 pm Post subject: |
Do Ghia's count? 2276 with 48 IDA's
_________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Tue Apr 08, 2014 5:11 pm Post subject: |
I wanted to loose the heater also _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Wed Apr 09, 2014 5:16 am Post subject: |
man! all of these look super nice! vwracerdave that tin is out of control! |
one4house Samba Member
Joined: July 18, 2009 Posts: 1121 Location: Sherman Texas
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Wed Apr 09, 2014 6:54 am Post subject: |
I sandblasted everything while the engine was out, then hit it with a quick coat of rattle can primer and then a coat or two of rattle can, bbq high temp flat black..
The Sync Link, plug wire clips, and spiral wrap wire stuff really help keep everything under control and out of the way too..
_________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
rockurob Samba Member
Joined: August 23, 2009 Posts: 358 Location: Okla City, Oklahoma
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Apr 09, 2014 7:09 am Post subject: |
I really think that the most common denominator here is organization of all wires and hoses. Have stuff clamped or tied so it doesn't flop all over, and give yourself enough extra length to work with. Having wires and hoses pulled tight is terrible, but having a mile of extra length loose is asking to get jammed in linkage, the belt, or melted. You don't need fresh paint to be organized and tidy. |
kme9418 Samba Member
Joined: January 30, 2003 Posts: 277 Location: San Antonio, TX
Posted: Wed Apr 09, 2014 7:42 am Post subject: |
Line-X and reroute the wiring behind the motor _________________ KME9418
1969 VW Beetle |
Hotrodvw Samba Member
Posted: Wed Apr 09, 2014 1:03 pm Post subject: |
I went from this:
To this:
IMO, ditching the oem tar board crap and simply painting the bay is the cleanest way to get it done. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Wed Apr 09, 2014 2:26 pm Post subject: |
I just finished building the complete 2276 longblock with all new case, parts, Mallory ignition, and a new Rancho Pro Comp transaxle. Only has 50 miles and 3 full 1/4 mile passes. Yellow tin was off the old 1835 that was in there.
Tin is painted with cheap Rustolium and a $50 china paint gun. With a toothbrush dipped in different colors of paint you stand back 3'-4' and swing the toothbrush and fling the paint onto the tins. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu May 01, 2014 2:37 pm Post subject: |
Ok so this is my progress so far:
I don't think it's too shabby! Any ideas or advice? |
