Duster76 Samba Member
Joined: February 21, 2014 Posts: 7 Location: Michigan
Posted: Thu Apr 10, 2014 2:44 pm Post subject: |
I'm looking to put 8-10 lbs to it. I thought I read somewhere about changing the emulsion tubes, Jetting, and at higher boost the throttle shafts will leak. I'm unsure since this will be my first vw turbo build |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Thu Apr 10, 2014 6:28 am Post subject: |
Run them the way they are and invest in a good O2 sensor with display and hopefully logging capabilities so you can see where the tune needs work.
If you start out at 7-8 lbs you should be able to run them the way they are. Higher boost levels are where you will see shaft leakage on some.
Kadub ran them for a couple years and I think his max boost was 12 lbs. and showing some seepage. He has gone to the dark side now...........
I ran a single carb blowthrough in my buggy and I could pull my carb, change jets and reinstall in a little over 10 minutes. I would hate to see how long it would take to rejet a set of dual Webers with all that plumbing and trying to remove those carbs...... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Thu Apr 10, 2014 4:01 am Post subject: |
I take it you would like the shafts o-ringed? how much boost you plan on running? Low boost shouldn't be a problem I don't know anyone here in Mi who does this _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Wed Apr 09, 2014 2:40 pm Post subject: Looking for someone in michigan that can turbo prep webers |
As the topic states I'm looking for someone in Michigan that knows how to turboprep a set of Weber IDf's for a blow through turbo. Thanks in advance for your recomendations. I really want to get this buggy done and runnin |
