vw moses Samba Member
Joined: April 17, 2012 Posts: 213 Location: independance,louisiana
Posted: Wed Apr 09, 2014 4:35 pm Post subject: got miss-put bigger idle&main jets;won't cruise steadlyl |
got hpmx 40 carbs-went w/55 idle&130 mains--timed at 28deg.@3000--the motor pulls like never before,very powerful, But when i try to cruise,back-fire from carb. constant poping?only likes being floored--what gives?? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
63 one of a kind beetle. 57 dash,double rear window--sweet! |
75smith Samba Member
Posted: Wed Apr 09, 2014 5:19 pm Post subject: |
running lean, either airleak(probably not if it idles well), main jet is too small or air corrector jet is to big
considering we don't know the engine size thats the best I can do, try jumping up a size on the main,
I'm assuming when you say cruise, your around 55-65mph, ~2750+ 250 rpms _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
Posted: Wed Apr 09, 2014 5:37 pm Post subject: |
No, It wont go 30mph with out fighting,pop-pop-pop-only cooperates when i step harder on the gas-I got 130 main(HPMX40)came w/115-reccomend 125main according to hpmx recomendations? could the plugs be too hot or too cold? i chose the mediums from cb-It does run faster and never felt so much power!, But the low ends sucks--I must have drag strip equip. now--not street cruiser, very fustrating! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Wed Apr 09, 2014 6:12 pm Post subject: |
Clean out your idle jets.
Check for vacuum leaks at manifolds. |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Wed Apr 09, 2014 6:45 pm Post subject: |
Call me. You should have my number in a PM. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Wed Apr 09, 2014 7:20 pm Post subject: |
ok-went outside and started it up--idled fine--sprayed manifold base and carb. gasket w/b12 carb. cleaner- no change-idle jets cristal clean. what would make it backfire thru carbs? when i hold the gas steady, traveling??what could do it? totally stumped!HELP! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Wed Apr 09, 2014 7:35 pm Post subject: |
vw moses wrote: |
ok-went outside and started it up--idled fine--sprayed manifold base and carb. gasket w/b12 carb. cleaner- no change-idle jets cristal clean. what would make it backfire thru carbs? when i hold the gas steady, traveling??what could do it? totally stumped!HELP! |
1699 engine?
what is the air jet, venturi size?
you need to pay attention to what the rpm range is when it is stuttering, unless it happens at all rpms levels light throttle?
backfiring through the carb is typically a lean condition, backfiring through the exhaust is typically a rich condition
double check the timing too, nothing like accidentally setting the timing wrong _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
MURZI Samba Member
Posted: Wed Apr 09, 2014 7:50 pm Post subject: |
Did you sync the carbs with a snail?
Did you adjust your idle mixture screws?
How is the side to side play in the linkage ..sloppy, tight?
What is your initial timing?
Do you have 1 and 2 plug wires reversed?
What carb is popping back? Both? _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Wed Apr 09, 2014 8:48 pm Post subject: |
No I didn't put the air gauge, But i got the throttle arms both about the same contact--screwed each idle screw in until drop in RPM,then backed out slowely until back-up to ideling-timing is 28deg.@3000-at idle 8-10bf tdc.Its got to be---jet still-too small to allow the motor to peform w/my larger-intake valve(40x35),big cam,exhaust-dist.---Should i ream the main jet up next size, Then test drive? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Posted: Wed Apr 09, 2014 9:32 pm Post subject: |
32mm venturis? For 28mm venturis, your jets are way too big IMO.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Wed Apr 09, 2014 9:42 pm Post subject: |
Ouch! thats a thought-im under the impression--lean symptoms--but i never mention it appears the motor very hot; drove to gas station to top off w/gas (preium) The smell was hot -sorta like "too much burnt"also when i got home i looked at my valve vent tubes there was some smoke coming out not a lot but smoke,might be normal? So I don't know,i appreciate any&all the help! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Thu Apr 10, 2014 11:24 am Post subject: |
Did you clean the carbs thoroughly and make sure and check the float height-drop prior to install? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Thu Apr 10, 2014 4:41 pm Post subject: |
i pulled the carbs off removed the idle jets sprayed carb. cleaner into hole then blew into with air-compressor&bubbles came out gasket top part took off cover and fliped over gasket tightened good-put back the idle&main jets that came with em. put back on started--poping all over again!changed plugs-1 wasblack,1 white,1shiny greay,1electrode almost touching center put in new plugs--still pops at idle! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
MURZI Samba Member
Posted: Thu Apr 10, 2014 5:34 pm Post subject: |
Loosen each idle jet one at a time until you hear the pop stop. That hole is your culprit.
Did you loosen the idle air bypass screws and then tighten them all the way up?? The little screws with jam nuts on them next to the idle mixture screws?? _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Apr 10, 2014 9:03 pm Post subject: |
I did snug the idle jet screws-- should they be lightly seated? is there a blockage if too tight? but i'll try tomorrow-i,m blown away by this delema! i didn't touch the air screws(PROFESINAL TUNERS ONLY)factory setting.Its possiable i over tighened the seats, but i'll check it out. what do you make of the plug colors? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Posted: Thu Apr 10, 2014 9:24 pm Post subject: |
vw moses wrote: |
i didn't touch the air screws(PROFESINAL TUNERS ONLY)factory setting. |
I've had factory set floats not set right, so don't assume something is fine
did you completely disassemble and clean before putting them on?
might want to read through some of the carburetor tuning topics here
http://www.aircooled.net/vw-technical-articles/
then try doing a couple searches on carburetor tuning, sounds like you might actually be missing a step in the actual set up _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
MURZI Samba Member
Posted: Thu Apr 10, 2014 9:39 pm Post subject: |
The point is this. By gently unscrewing a idle jet holder you are taking the idle jet off seat allowing it to bypass and richen the circuit. By doing this one by one you will find the idle circuit that is plugged. The restriction could be in the jet or in the passage itself. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Thu Apr 10, 2014 9:47 pm Post subject: |
yes i set the floats according to weber carb. book (10mm up & 30mm down) thanks for the link; so far i'm concerned about idle jet because it coughs at Idle+reving,i'll study the procedure in carb. link. Thanks! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
Posted: Thu Apr 10, 2014 10:03 pm Post subject: |
OK-- When i had them apart i blasted the brass hole on top w/ idle jets removed with b-12 & air compressor.I think i'll put the 55idle jets back in because the stock idle jet is 52?? are you familar with the brass vent tube addition for the idle jet air feed tube? _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
