NAES Samba Member
Joined: September 10, 2003 Posts: 2120 Location: AREA-52 Southern Killafornia
Posted: Sat Apr 12, 2014 8:00 pm Post subject: Should I use Italian or Spanish Weber 40 IDF? |
I've got a pair of each that need to be gone through. I wanted to hear some opinions on which set I should spend my time on. Both throttle shafts feel good. No play and travel is smooth through range of motion. I haven't done a thing to them so I don't know how they are jetted or what really is going on inside at all.
These are going on a 1776 DP. Stock heads. Engle 110 cam. Stock flywheel and German clutch. Pushing a lowered bus with a straight axle.
Thanks all for the help, NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Sat Apr 12, 2014 8:32 pm Post subject: |
Do your Italian ones have vacuum ports? Mine didn't. If you are going to use an SVDA, the Spanish ones should have vacuum ports.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Sat Apr 12, 2014 8:46 pm Post subject: |
I'll second the vacuum port carbs. I bought an aircooled.net SVDA that was set up for dual Webers (I have HPMX) and the combo is excellent for driveability. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
NAES Samba Member
Posted: Sun Apr 13, 2014 2:17 pm Post subject: |
Cool. Thanks guys. not looking like either has vac ports so I'll be taking them completely apart and seeing what I'm working with and go from there.
I appreciate the help, NAES _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
