jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Apr 13, 2014 11:26 am Post subject: hypothesis: failing fuel pump? |
An odd thing happened yesterday after I did a compression test and checked the timing on the single cab. This is a 1975 pickup with an 1800-cc CB case and newly rebuilt heads from Headflow Masters.
It may be that the futzing I did is purely coincidental to the current problem, however...
When the engine got rebuilt, I got a new electric fuel pump and installed it underneath, more or less above the transaxle, and screwed into the floor. Not having rubber mounts at the time, it is screwed directly to the metal floor, and so made quite a racket with ignition ON. But yesterday, as I fired it up for a test drive, I noticed that the fuel pump was no longer making its racket. The engine started anyway, however, and I did some driving.
But it would stall at odd times, and was sometimes not happy maintaining an idle. It would stall out while cruising along at 40, forcing me to the side of the road. After awhile (5 minutes?) it would start again (with some persistence), and then I could go a ways again, but then it would stall out again. I finally limped home.
Since the fuel pump quit its racket, I figured that perhaps it had failed, but if it had failed, how can I go at all? It seems to me that with a fuel pump failure, I would not get the engine started, much less go anywhere. I am trying to reconcile the data with my failed fuel pump hypothesis, but it does not make sense to me.
Is there a possibility that even without the fuel pump working, fuel can drain from the tank into the line by gravity, and provide enough fuel for brief periods of running? Could the carburetors somehow suck fuel up the line for a bit of time? If so, then I may stick with the failed fuel pump hypothesis.
If there is no way the truck could run with a failed pump, then what else could be causing this behavior? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
suffecool2 Samba Member
Joined: May 15, 2011 Posts: 355 Location: chambersburg, pa
Posted: Sun Apr 13, 2014 11:37 am Post subject: |
When my electric pump failed, it would still run, although very badly. But I didn't try to go anywhere though. Maybe a intermittent clog in the fuel line? _________________ '71 Hightop - rolling resto/customization in process
'87 Golf - tranny's toast, but still runs
'70 bone stock Westy - gone |
Posted: Sun Apr 13, 2014 11:39 am Post subject: |
Since the tank is higher than the engine, gravity may be able to supply enough fuel for the engine to be able to idle and run short distances. |
FreedomBuild Samba Member
Joined: September 21, 2010 Posts: 385 Location: Calgary, Alberta
Posted: Sun Apr 13, 2014 11:53 am Post subject: |
Wildthings wrote: |
This is true. I was going to mention that. What type of pump is it? do you have it powered by a relay? _________________ 1973 Campmobile rustoration in progress..
1700 Type 4 engine
Manual Transmission
Pertronix Mechanical advance distributor
Pertronix Flame Thrower coil
Weber Progressive
Come visit our Facebook page!
http://www.facebook.com/pages/Freedom-the-Campmobile/158775277473211
Click to view image |
jtauxe Samba Member
Posted: Sun Apr 13, 2014 12:54 pm Post subject: |
No relay -- it is just powered off the coil, with an in-line fuse.
I believe it was a Facet pump, 3.5 psi. Failed in just a few months. _________________ John
http://vw.tauxe.net
Randy in Maine Samba Member
Posted: Sun Apr 13, 2014 3:02 pm Post subject: |
jtauxe wrote: |
I believe it was a Facet pump, 3.5 psi. Failed in just a few months. |
Most of them don't last that long. That may be the finest facet pump they ever built. |
jtauxe Samba Member
Posted: Sun Apr 13, 2014 5:01 pm Post subject: |
Is there another brand that you would recommend?
Something that will deliver 3.5 psi... _________________ John
http://vw.tauxe.net
Posted: Sun Apr 13, 2014 6:06 pm Post subject: |
Those are the exact pumps I had issues with until I put my fuel pump relay and Facet pump in. I swear by my Facet, I don't even know its working. So quiet and it pushes plenty of volume.
I guess it's up to you what route you want to take. As the old saying goes you can lead a horse to water but you can't make it drink. _________________ 1973 Campmobile rustoration in progress..
1700 Type 4 engine
Manual Transmission
Weber Progressive
jtauxe Samba Member
Posted: Mon Apr 14, 2014 10:52 am Post subject: |
I like that pump. One reason is that on the '79 Transporter, which was fitted with a carb instead of FI (and I do plan to revert to FI someday), this pump could possibly just drop in where the FI fuel pump lives, for now. That would be handy!
Do you happen to know if the diameter on this is the same as the FI fuel pump? _________________ John
http://vw.tauxe.net
Posted: Mon Apr 14, 2014 11:08 am Post subject: |
I think that the FI pump has a 10mm low pressure line that goes in from the fuel filter and a 7mm high pressure line leaving the pump.
This one uses a 7mm or 5/16" line on each side.
Of course that was about 4 years ago, and I can't remember what I had for breakfast this morning.
I used to say it is not the years but the mileage, but the years might have something to do with it also. |
jtauxe Samba Member
Posted: Mon Apr 14, 2014 12:13 pm Post subject: |
Well, Randy, they say that the memory is the second thing to go.
What I was really interested in is the overall diameter of the "can". That is, would this pump fit into the same clamp that holds the FI pump? Hose diameters I can manage. _________________ John
http://vw.tauxe.net
germansupplyscott Samba Member
Posted: Mon Apr 14, 2014 12:16 pm Post subject: |
jtauxe wrote: |
Do you happen to know if the diameter on this is the same as the FI fuel pump? |
no, it's quite a bit smaller diameter. _________________ SL |
