kpf Samba Member
Joined: March 01, 2017 Posts: 852 Location: California, US
Posted: Thu May 10, 2018 3:32 pm Post subject: Re: The Stupid Question Thread |
sb001 wrote: |
How can you tell if your seats are the original VW factory covers? Would they have had VW tags on them somewhere?
Late reply, but I wanted to point out that the original basket-weave vinyl in late-model VWs was perforated. It had little holes between the "weave." Here is a pic from the gallery (posted by baldessariclan):
Regards,
Kris _________________ 1971 Super Beetle |
vamram Samba Member
Posted: Fri May 11, 2018 3:58 am Post subject: Re: The Stupid Question Thread |
Not sure if this is the right place for this question, but why is my clutch dusty w/rust? This is a car I often use as a daily driver. On the positive side, I'm guessing it partially means the crankcase seal is holding well.
_________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Just us buses Samba Member
Joined: April 27, 2004 Posts: 195 Location: Where the nuthatch winters
Posted: Fri May 11, 2018 6:29 am Post subject: Re: The Stupid Question Thread |
Pretty normal IMO. If it bothers you, wipe it off well; I wouldn't oil it or anything. _________________ It doesn't matter where you start, it all comes together; it all falls apart. |
Jms2980 Samba Member
Joined: April 01, 2018 Posts: 34 Location: Madison, WI
Posted: Fri May 11, 2018 12:53 pm Post subject: Re: The Stupid Question Thread |
So I decided to post this question here, because I believe it fits the category but while working on my 72 Super Beetle, came across something that has me stumped. I removed the shift rod and stick shift assemblies to replace the coupler and shift rod bushing. Also cleaning up the stick shift and am replacing the stock shift ball with a leather wrapped aftermarket shifter. Removed the stock shifter and the stick shift is filled with gear lube? Anyone know why? Best I can figure from Google etc. is some PO thought they could fill the transmission through the shifter? Only other theory I could come up with was to fill the shifter with gear lube to give it more weight - maybe improve the overall "feel" of shifting - but I figure that would be a pretty big stretch.
James |
Ron G Samba Member
Joined: September 05, 2013 Posts: 228 Location: Albuquerque, NM
Posted: Fri May 11, 2018 1:31 pm Post subject: Re: The Stupid Question Thread |
Never underestimate people, my brother-in-law put 8 quarts of transmission fluid in the oil filler for the engine on his van then took it for a drive around the block but because it was smoking so bad he didn’t know why and then he said it just stopped moving, and believe it or not he’s an engineer. I’m thinking they thought that it would shift easier with that filled with oil just a guess. |
mukluk Samba Member
Posted: Fri May 11, 2018 1:56 pm Post subject: Re: The Stupid Question Thread |
vamram wrote: |
It's rusty because the components are bare, unprotected steel and you live in an area where there is moisture in the air. They started to rust the moment they were exposed to the air and will do so even with the engine fully installed since the bellhousing area is not completely sealed from the environment. If it bothers you, you can clean or convert the rust and paint all the non-friction surfaces. _________________ 1960 Ragtop w/Semaphores "Inga" |
vamram Samba Member
Posted: Fri May 11, 2018 2:20 pm Post subject: Re: The Stupid Question Thread |
Oh it doesn't bother me, I just hadn't seen that in any of my previous Bugs, here near DC or in Miami - both plenty humid! I'll probably hit it with some brush on prep and etch or other rust converter. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
mukluk Samba Member
Posted: Fri May 11, 2018 3:15 pm Post subject: Re: The Stupid Question Thread |
If your previous Bugs didn't have rusty clutches, it's pretty well guaranteed they were either painted or had some sort of coating on them to keep moisture off. The rust in and of itself will eventually form a protective layer and prevent further corrosion, barring an excessively wet or corrosive environment; the only area I've ever been concerned with was the pressure plate springs as corrosion on them can lead to weakening or premature failure. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat May 12, 2018 5:19 am Post subject: Re: The Stupid Question Thread |
The socket at the front of the shift rod where the ball on the shiftstick goes is commonly packed with grease. Even Bentley recommends it to keep rattles down. _________________ It doesn't matter where you start, it all comes together; it all falls apart. |
vamram Samba Member
Posted: Sat May 12, 2018 6:45 am Post subject: Re: The Stupid Question Thread |
mukluk wrote: |
The rust in and of itself will eventually form a protective layer and prevent further corrosion, barring an excessively wet or corrosive environment; |
Rust to prevent rust....first I've heard of it, but I'll go w/it, after all it shifts super smoothly, no reason to think anything's wrong. But then you add this!
mukluk wrote: |
the only area I've ever been concerned with was the pressure plate springs as corrosion on them can lead to weakening or premature failure. |
Should I remove the clutch plate to check the condition of the disk? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Ron G Samba Member
Posted: Sat May 12, 2018 9:15 am Post subject: Re: The Stupid Question Thread |
JMO, if it was mine I pull all that off and put new you got the motor out might as well do it,, clutch pressure plate throw out bearing. It all pretty much looks like surface rust but if you’re worried I would change it. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat May 12, 2018 9:23 am Post subject: Re: The Stupid Question Thread |
vamram wrote: |
Looks like it got real hot. Why? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Ron G Samba Member
Posted: Sat May 12, 2018 9:26 am Post subject: Re: The Stupid Question Thread |
And the pressure plate looks like it’s worn out pretty good from the throwout bearing, |
vamram Samba Member
Posted: Sat May 12, 2018 9:30 am Post subject: Re: The Stupid Question Thread |
Hmmm...I think any heating pre-dates my ownership. I pulled the engine back when I bought the Bug in 9/2016 and this is how it was. I've never had overheating issues since buying it though. Sounds like two recommendations for replacing it....
I'm planning to clean and keep the TO, though. It's an original German Sachs. Unless the bearing is pitted or discolored, in which case I will replace it as well. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Ron G Samba Member
Posted: Sat May 12, 2018 9:32 am Post subject: Re: The Stupid Question Thread |
It’s cheap insurance so you don’t have to pull your motor out again, |
vamram Samba Member
Posted: Sat May 12, 2018 11:27 am Post subject: Re: The Stupid Question Thread |
Ron G wrote: |
So as to not pollute the Stupid Question Thread, I'm following up on my clutch question in My '74 Super Project thread in my signature line. I removed it and posted close up pics there. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
greggy Samba Member
Posted: Wed May 16, 2018 2:46 am Post subject: Re: The Stupid Question Thread |
Does the ground wire from the generator go to the voltage regulator? |
Ron G Samba Member
Posted: Wed May 16, 2018 9:17 am Post subject: Re: The Stupid Question Thread |
Just put it to a ground |
sb001 Samba Member
Posted: Wed May 16, 2018 1:13 pm Post subject: Re: The Stupid Question Thread |
greggy wrote: |
The REAL answer to your question is yes. It grounds out on one of the voltage regulator mounting screws. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
mukluk Samba Member
Posted: Wed May 16, 2018 6:24 pm Post subject: Re: The Stupid Question Thread |
greggy wrote: |
Does it go from the generator to the regulator? Yes, if one is present. More importantly, does it have to go from the gen to the VR? Well, kind of.
Both the generator and voltage regulator need to be grounded to the negative terminal of the battery -- this is done indirectly through chassis grounds and bonding straps. Since the two components need to work in concert with each other to put out the correct voltage for the charging system to work properly, it was deemed prudent to have a direct ground wire installed from the generator to the regulator on 12v cars (6v cars had the regulator mounted directly to the generator), but that direct ground wire didn't appear until some time around 1968/1969 which was a full year and a half into 12v Beetle production with the remote mounted regulator under the rear seat. So a production run of somewhere in the neighbourhood of one to one and a half million Beetles went out the door with fully functioning charging systems sans the direct ground wire from generator to regulator.
In short (bad electrical pun), it's a good idea to have the ground wire between them installed to better ensure reliable proper operation, but they'll work just dandy without the wire so long as they are provided with good grounds to the chassis. _________________ 1960 Ragtop w/Semaphores "Inga" |
