Solian2002 Samba Member
Joined: July 06, 2018 Posts: 3 Location: Long Beach Wa
Posted: Fri Jul 06, 2018 8:39 pm Post subject: Re: The Stupid Question Thread |
So... My pic 30/31 is dead (held together by JB weld and a dime over there inspection vent). My engine is bored out too 1900 cc from the 1500cc original stock engine. My 68 still had the original oil bath air filter which I'm not getting rid of. Can I swap out the carb for a 34 pic and still use the oil bath air filter? Looking to keep it stock looking. She's a 68 standard Beetle.
Does any one also know where I could get the air-conditioning unit? Someone stole mine from my car. Wish I was joking. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Jul 07, 2018 7:29 am Post subject: Re: The Stupid Question Thread |
Solian2002 wrote: |
So... My pic 30/31 is dead (held together by JB weld and a dime over there inspection vent). My engine is bored out too 1900 cc from the 1500cc original stock engine. My 68 still had the original oil bath air filter which I'm not getting rid of. Can I swap out the carb for a 34 pic and still use the oil bath air filter? Looking to keep it stock looking. She's a 68 standard Beetle. |
If you have a dual-port intake manifold (like your 30/31 used an adapter plate), then you could go to a 34PICT3. You'd want a distributor that goes with that.
Solian2002 wrote: |
Gilmore in Las Vegas or ICE AC in San Diego _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
wcfvw69 Samba Purist
Posted: Sat Jul 07, 2018 7:34 am Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
Solian2002 wrote: |
Solian2002 wrote: |
Gilmore in Las Vegas or ICE AC in San Diego |
Cusser is exactly on point. If you have a dual port engine and manifold, don't put a 34-3 matched to an 009 or SVA distributor. Get the correct distributor for your VW. If your VW is an autostick, you need to get that distributor as well. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Jul 07, 2018 8:05 am Post subject: Re: The Stupid Question Thread |
wcfvw69 wrote: |
Cusser wrote: |
Solian2002 wrote: |
Solian2002 wrote: |
Cusser is exactly on point. If you have a dual port engine and manifold, don't put a 34-3 matched to an 009 or SVA distributor. Get the correct distributor for your VW. If your VW is an autostick, you need to get that distributor as well. |
Thank you guys. I'll let my man know. |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Sat Jul 07, 2018 11:52 am Post subject: Re: The Stupid Question Thread |
wcfvw69 wrote: |
Cusser wrote: |
Solian2002 wrote: |
Solian2002 wrote: |
Why do you say not to use an 009 with a 34-3? _________________ '74 - front disks/lots more work to do |
Posted: Sat Jul 07, 2018 3:24 pm Post subject: Re: The Stupid Question Thread |
Off idle hesitations and huge flat spots on the mechanical only 009. The engines run night and day better with a restored DVDA or SVDA on them. _________________ Contact me at [email protected]
Xevin Samba Member
Posted: Sun Jul 08, 2018 9:52 pm Post subject: Re: The Stupid Question Thread |
Is there a difference between a 74 Bug (Which I have) and a 73 Bug tail light lens. Just the tail light cover/lens. The rear end of my bug was replaced with 73 fenders and bumper. Need to find a Hella left rear lens to match the right side, which looks perfect. Want to make sure there is not some weird combatibilty issue. Gotta be the same from 73 to 79, right? Any preferred retailers on the internet (Or other) you all recommend for Hella tail light lenses. Thank you.
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
AlmostHeavenWV_VW Samba Member
Posted: Mon Jul 09, 2018 6:38 am Post subject: Re: The Stupid Question Thread |
Xevin wrote: |
Bug tail light lenses are the same from 73+ model years.
Hella light lenses are available from CIP1 and AirCooled.net last I looked.
However......
Those new Hella lenses available are the 'Mexican' variant which are Left/Right lenses (not side specific).
Essentially, the Mexican ones only use 3 light bulbs (turn signal/ combo running tail and brake light (via a 1157 dual filament bulb), and the reverse light.) So they look the same and can be used for both sides.
Check it out:
https://www.thesamba.com/vw/classifieds/detail.php?id=84077
https://vwparts.aircooled.net/Tail-Light-Assembly-HELLA-Left-or-Right-1973-79-p/133-945-0978a.htm
Whereas, the German variant uses 4 bulbs and the lenses look different for each side (turn signal, tail light (1156 single filament bulb), brake light (1156 bulb again), reverse light.
If you look closely at your lenses, you'll notice that they are mirrors of each other.
See here:
https://www.jbugs.com/product/133945223A.html (left)
https://www.jbugs.com/product/133945224A.html (right)
CIP1 does have 'German equivalent' quality left and right side specific lenses available, just as an option.
If you choose to go Hella German lenses though, you'll probably have to dig through the classifieds or ebay to score a NOS German Hella to match side specific Hella lenses.
Keep on Busin......err,I mean.....Buggin! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Xevin Samba Member
Posted: Mon Jul 09, 2018 7:36 am Post subject: Re: The Stupid Question Thread |
Great info AlmostHeaven. Thank you very much. I will pull apart and investigate just what I have going on before I hunt one down. I suspect the right Hella light might be Mexican buy the good shape it’s in. Thanks for preventing me buying a part that kinda matches _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Mon Jul 09, 2018 7:45 am Post subject: Re: The Stupid Question Thread |
Okay, my turn:
When I look down into the access hatch/hole for the shift coupler- getting down low and looking directly back towards the rear of the car, I seem to have a gap between the metal below the shift rod/coupler. Maybe 1/4" most of the length of the rear of that little compartment.
This hole would be below the 'nose cone' and all that, so not a bad nose cone or anything such as that.
(sorry I don't have a picture, really cant get the flash to illuminate it very well- either you just see a band of light from outside or only can see the shift rod in a blaze of camera flash, can't really get a good representative picture of the situation)
I assume that's not normal, but I would just like to verify it isn't suppose to be like that before I attempt to seal it up.
If it's not suppose to be like that (I assume so) is there a specific seal or gasket for that place or just maybe some bent sheet metal/broken spot weld that has allowed the gap to appear? _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Cusser Samba Member
Posted: Mon Jul 09, 2018 8:24 am Post subject: Re: The Stupid Question Thread |
This seal??? New on left, 48-year-old original on the right.
If your transmission is installed you'd need to slit and fit over the front end of transmission. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jul 09, 2018 9:25 am Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
If your transmission is installed you'd need to slit and fit over the front end of transmission. |
No, it's below the nose cone and seal.
I believe I may have a broken weld at the rear of that access compartment with the shift coupler. I kept searching the gallery and finally think I figured it out:
I think maybe the seam/weld right below the circle hole (where the nose cone etc. would be when transmission is installed) is where my gap is.
(not my pic)
....if that is where I need to seal, that's gonna be fun with the transmission in and body on _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Gman73 Samba Member
Joined: April 25, 2018 Posts: 76 Location: Spotsylvania, VA
Posted: Mon Jul 09, 2018 5:20 pm Post subject: Re: The Stupid Question Thread |
is there really supposed to be a crank sensor here or was it just used from the factory? any help would be great.
Posted: Wed Jul 11, 2018 7:46 am Post subject: Re: The Stupid Question Thread |
Is there any way to pull and press in ball joints without the special tool that apparently isn’t made anymore?
If not, does anyone have a picture of what it looks like? I see Glenn’s posts all over the place about it, but they are old enough the pictures no longer show up. Also, any idea what the tool costs vs what the costs is typically to get the presses in by a shop? _________________ '74 - front disks/lots more work to do |
The Dubbernaut Samba Member
Joined: June 01, 2011 Posts: 163 Location: Kennewick, Wa
Posted: Fri Jul 13, 2018 4:47 pm Post subject: Re: The Stupid Question Thread |
What would be the minimum amount of items one would need to remove from a 1969 beetle, to then install a dune buggy body for summer driving?
I have a 69 all the way down to the pan, ready for paint and a significant rebuild from the ground up. My though is to run the beetle for winter, and when the weather turns, store the body in my shop and swap it for a buggy body in the summer. Ive looked around for anything like this but its mainly swaps from bug to buggy, and nothing really like what Im trying to do.
Would there be any body modifications I could make before putting the pan together completely which would make the swaps easier? So far, with a beetle, my experience has been total disassembly. I hadn't thought of this "brilliant idea" when I was tearing down the bug so I gutted the interior and pulled the body off with ease. _________________ 2012 Tiguan 4motion
2 Corrado's
3 Beetle's
76 Bus
2 Baja's
66 Pigalle Squareback
80 Rabbit
80 Rabbit Pickup
and still collecting! |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Fri Jul 13, 2018 5:01 pm Post subject: Re: The Stupid Question Thread |
Mine has the hood, four fenders, front apron cut out, rear deck, cut the rear apron, and the running boards all removed. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Fri Jul 13, 2018 5:02 pm Post subject: Re: The Stupid Question Thread |
Gman73 wrote: |
That's for the original VW diagnostic system. Today it doesn't do anything. You can remove it of leave it. The choice is yours.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu Jul 19, 2018 9:52 pm Post subject: Re: The Stupid Question Thread |
Does anyoen have any idea what seats they used in the 1600SP? They look like a pretty good compromise between a more vintage look and not sliding all over the place
http://www.sebeetles.com/sp_bug/
EDIT: Second dumb question. Can I power wash my front end while still leaving the beam on teh car without damaging anything? The gunk built up on the trailing arms is so intense I can even get to the nuts and zerk fittings and im not sure I can control a wire wheel enough to actually clean it all off. _________________ '74 - front disks/lots more work to do |
RustyJ Samba Member
Joined: July 26, 2018 Posts: 3 Location: North Carolina
Posted: Fri Jul 27, 2018 3:12 am Post subject: Re: The Stupid Question Thread |
Looking for answers about a 1970 Beetle convertible. All numbers matching but yet no fuel filler on right front quarter panel but a 1967 tank. Any help would be appreciated. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Fri Jul 27, 2018 5:57 am Post subject: Re: The Stupid Question Thread |
most likely explanation, car has been modified either to some PO's personal taste or due to accident repair. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
