RustyJ Samba Member
Joined: July 26, 2018 Posts: 3 Location: North Carolina
Posted: Mon Jul 30, 2018 11:58 am Post subject: Re: The Stupid Question Thread |
Thank you |
vamram Samba Member
Posted: Fri Aug 03, 2018 7:39 am Post subject: Re: The Stupid Question Thread |
I recently installed a new clutch on my '74 Super - TO bearing, pressure plate, spring plate, and cable. It's adjusted properly and is super easy to work. I have a really good feel for the car and can easily shift thru the gears by barely pressing down on the clutch pedal, maybe an inch and a half or three at most.
My question is, what's the proper way to engage the clutch? Do you have to go all the way down to the floor? Or is the shallow push I use OK or am I unknowingly "riding" the clutch? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
kpf Samba Member
Joined: March 01, 2017 Posts: 850 Location: California, US
Posted: Fri Aug 03, 2018 9:34 am Post subject: Re: The Stupid Question Thread |
vamram wrote: |
My question is, what's the proper way to engage the clutch? Do you have to go all the way down to the floor? Or is the shallow push I use OK or am I unknowingly "riding" the clutch? |
With good timing, it is possible to shift without using the clutch at all. The more your timing is off, the more wear you'll put on your synchros. What you're doing is half way between: More risk of synchro wear but not as much as if you were not using the clutch at all. The owner's manual recommends always pushing the clutch pedal all the way, and this is the best way to minimize synchro wear.
Regards,
Kris _________________ 1971 Super Beetle |
vamram Samba Member
Posted: Fri Aug 03, 2018 9:37 am Post subject: Re: The Stupid Question Thread |
Thanks! Time to re-read the owner's manual and keep that pedal going to the floor. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
SiRJoZ Samba Member
Posted: Fri Aug 10, 2018 11:40 pm Post subject: Re: The Stupid Question Thread |
I needed a new headlight switch for my 1970 bug. I ordered one but instead of three 30 terminals, it has two 30 and one X. Will this work? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sat Aug 11, 2018 7:25 am Post subject: Re: The Stupid Question Thread |
SiRJoZ wrote: |
1. Wire it up and try it out in the trunk, before you mount it in the VW.
2. Or return it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
SiRJoZ Samba Member
Posted: Sat Aug 11, 2018 8:38 am Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
SiRJoZ wrote: |
2. Or return it. |
Yeah I was hoping to avoid returning it. Jbugs was on backorder so I ordered it from partsgeek. (Last time I do that.)
I’m afraid to test it out. The factory wiring diagram shows three 30 connections. One to the ignition, one to the fuse block, and then another to the voltage regulator. The switch I received has all of the exact same connections, except instead of three 30’s, it has two 30’s and an “X”.
I also have an alternator with the internal VR so I’m not entirely sure if that changes things or not. Without a VR I’m not sure where that connection to my switch should go.
The irritating part is that I only have time to work on her on the weekends, and none of the places I deal with are open LOL.
What I’m hoping is that someone here knows something about this. Maybe I’ll get lucky and hear “yeah after 197x they stopped making the switch that way, and now the X connection is for blah blah blah....”
Why do we torture ourselves so eagerly? |
Cusser Samba Member
Posted: Sat Aug 11, 2018 11:08 am Post subject: Re: The Stupid Question Thread |
SiRJoZ wrote: |
The factory wiring diagram shows three 30 connections. One to the ignition, one to the fuse block, and then another to the voltage regulator. The switch I received has all of the exact same connections, except instead of three 30’s, it has two 30’s and an “X”. |
I'll assume that VW was working fine, charged the battery, etc. before the headlight switch went out.
What I'd do is connect the same three wires to #30 terminals, use a connector like one of these
And leave X terminal blank. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
SiRJoZ Samba Member
Posted: Sat Aug 11, 2018 11:46 am Post subject: Re: The Stupid Question Thread |
Yeah everything was good before...at least as it relates to that switch.
I’ll give your suggestion a shot. I have a couple of those splitters so I’ll let ya know what happens. |
Cusser Samba Member
Posted: Sat Aug 11, 2018 12:16 pm Post subject: Re: The Stupid Question Thread |
We used to have good VW shops i Phoenix, a chain called BAP Auto. About 3 decades ago, I needed a new headlight switch for my 1971 Super Convertible, so I just took the bad switch with me to local BAP store.
Guess what - there was no listing at all for the part I had in my hand !!! This was before computers and Google, so I looked at the headlight switches they had there for 1970 and 1971 years, and picked the one I thought was closest, and that I could wire up correctly. It has worked fine since.
Remember, 1971 was first year that ignition needed to be switched on for the headlights to light; so maybe this, and that it was a convertible might've been the reason..... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
SiRJoZ Samba Member
Posted: Sat Aug 11, 2018 12:38 pm Post subject: Re: The Stupid Question Thread |
Yeah the one remaining thing I’m nervous about is the fact that I don’t have an external voltage regulator. I need to find a 1970 wiring diagram that is drawn out with an alternator instead of the generator setup. |
Cusser Samba Member
SiRJoZ Samba Member
Posted: Sat Aug 11, 2018 6:09 pm Post subject: Re: The Stupid Question Thread |
Yeah I came across that one about 20 min after I posted that last comment. However, I really do appreciate the assistance. This is gonna be my daughters first car. So I’m very eager to get everything perfect. Everything that I come across that isn’t, gets replaced. So I’m buried in the steering column at the moment LOL!
Thank you. It’s mice having some place to ask questions like this. |
SiRJoZ Samba Member
Posted: Mon Aug 13, 2018 6:17 pm Post subject: Re: The Stupid Question Thread |
So doubling up on one of the 30 terminals didn’t work.
I read in one of these threads that a guy used a jumper but now I can’t find it.
Attaching a picture here. The switch one the right is obviously the old one, and the left is the new. Help?
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9950 Location: Huntington Beach, CA
Posted: Mon Aug 13, 2018 6:46 pm Post subject: Re: The Stupid Question Thread |
SiRJoZ wrote: |
Use one or two of these. VW used to make 4 way ones also.
Wolfsburg West has them for $2.50 I think.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111937079 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
SiRJoZ Samba Member
Posted: Tue Aug 14, 2018 9:35 am Post subject: Re: The Stupid Question Thread |
So I found a good thread by searching for “jumper” here in our forum.
Jumped X to one of the 30’s. Everything works perfectly now.
Appointment for registration at 3pm today. Might have her on the road by tomorrow morning! |
SiRJoZ Samba Member
Posted: Tue Aug 14, 2018 6:51 pm Post subject: Re: The Stupid Question Thread |
Or not. It appears my alternator is not charging the battery. |
Cusser Samba Member
Posted: Wed Aug 15, 2018 7:28 am Post subject: Re: The Stupid Question Thread |
Does your charge warning light actually light up when you turn the key to ignition but don't start the engine? That needs to happen with an alternator. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
SiRJoZ Samba Member
Posted: Wed Aug 15, 2018 5:19 pm Post subject: Re: The Stupid Question Thread |
Yeah I get the light when I turn the ignition on. And it goes off after I start the car. |
SiRJoZ Samba Member
Posted: Wed Aug 15, 2018 5:27 pm Post subject: Re: The Stupid Question Thread |
Looks like it’s charging now. Just kinda weak. I’m at about 12.2 not running. If I fire it up I’m at 13.5 with lights on. 13.7 with them off.
My brake lights come on when I have the ignition on also. Guess I better investigate that. Might be related lol |
