andrewschumi Samba Member
Posted: Thu Apr 01, 2021 7:53 am Post subject: Re: The Stupid Question Thread |
Hi guys,
I have a twisted throttle shaft from a German solex 31pict3
Is a shaft from a German 34pict3 suitable replacement?
Here is the damaged shaft
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Fri Apr 02, 2021 8:59 pm Post subject: Re: The Stupid Question Thread |
As long as the dimensions are the same, I don't see why not.
Just gotta transfer over the parts bolted onto the end of the shaft.
How'd it get all twisted? _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Posted: Sat Apr 03, 2021 12:15 am Post subject: Re: The Stupid Question Thread |
Four years sitting in a garage!
WD40 didn't help much. I have it soaked in oil for a day. I hope it will get unstuck. |
Posted: Sat Apr 03, 2021 2:27 am Post subject: Re: The Stupid Question Thread |
Ouch, that was really stuck!
If you have the means to do it, boiling it in oil (or water, surprisingly) may help free it up. _________________ Two Bugs-
EVfun Samba Member
Posted: Sat Apr 10, 2021 2:52 pm Post subject: Re: The Stupid Question Thread |
Why is Copper the metal in many thread anti-seize products? I know it works but was hoping to understand why it works. Almost every other metal in common use sacrificially corrodes over copper. Then we use it on exhaust hardware that is steel and often Zinc plated steel!
I replaced the pea shooters this morning and I used it on those 6mm bolts on the clamps. _________________
Wildthings wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Sat Apr 10, 2021 3:35 pm Post subject: Re: The Stupid Question Thread |
EVfun wrote: |
I replaced the pea shooters this morning and I used it on those 6mm bolts on the clamps. |
This sounds like a question that Ray Greenwood could field.
Problem is. I don't think he checks the "stupid question" thread.
I use the copper anti-seize stuff too. It's messy, but I have not had any issues with frozen exhaust nuts. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
AirHead1966 Samba Member
Joined: October 17, 2019 Posts: 568 Location: Triad Area NC
Posted: Sat Apr 10, 2021 3:45 pm Post subject: Re: The Stupid Question Thread |
EVfun wrote: |
The purpose of using anti-seize compound is to coat the threads with something that would prevent corrosion and adhesion between the thread and the fastener. Copper works for that purpose. The steel threads get coated with copper and don't corrode and fuse together. |
EVfun Samba Member
Posted: Sat Apr 10, 2021 5:30 pm Post subject: Re: The Stupid Question Thread |
AirHead1966 wrote: |
That cuts to the heart of my question... Why does copper prevent corrosion? Between any 2 metals you have a battery. We put Zinc on Iron because that Zinc plating sacrifices itself to prevent the Iron from rusting. The Zinc is more electronegative. Zinc anodes are used on ships to sacrifice that over the steel hull. Yet, we use Copper in anti-seize. It is more positive than many metals we use and so tends to be the one that does not corrode, even while increasing the tendency of metals it touches to corrode.
I agree with you that it works. I use it too -- but using copper for this seems (to me) counterintuitive. _________________
Wildthings wrote: |
Posted: Sat Apr 10, 2021 7:14 pm Post subject: Re: The Stupid Question Thread |
EVfun wrote: |
We put Zinc on Iron because that Zinc plating sacrifices itself to prevent the Iron from rusting. The Zinc is more electronegative. Zinc anodes are used on ships to sacrifice that over the steel hull. Yet, we use Copper in anti-seize. It is more positive than many metals we use and so tends to be the one that does not corrode, even while increasing the tendency of metals it touches to corrode. |
I think copper is preferred because it can withstand higher temperatures while maintaining its antiseize property. Copper antiseize is effective until up to 1800 C degrees where as zinc antiseize is effective until 750 degrees C. |
bergfan Samba Member
Joined: March 07, 2007 Posts: 151 Location: NewZealand
Posted: Sat Apr 10, 2021 10:52 pm Post subject: Re: The Stupid Question Thread |
And to make it more interesting, there is a silver anti - seize for stainless fasteners to stop the threads from galling |
kirk1015 Samba Member
Joined: June 15, 2015 Posts: 281 Location: New Jersey
Posted: Tue Apr 13, 2021 8:32 am Post subject: Re: The Stupid Question Thread |
I have an off brand "Yellow" coil in my car now. Acel is the brand name I believe.
Also have a blue coil in my basement that I have yet to install. There is nothing wrong with the one I have. I want to change it because of looks. Trying to get back to the original look as possible.
I searched the classifieds and found this one.
Anyone ever used this one and should it be ok for my stock 1600DP Super?
https://www.thesamba.com/vw/classifieds/detail.php?id=2404790 _________________ Jim Douglas....I am Not. |
Posted: Wed Apr 14, 2021 11:54 pm Post subject: Re: The Stupid Question Thread |
I there any way of swapping out the push rod tube seals without removing the cyl. Heads |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Thu Apr 15, 2021 7:28 am Post subject: Re: The Stupid Question Thread |
bergfan wrote: |
Two ways:
1. Tap the cylinder heads away an inch - keeping the cylinders in place on the case - and install new pushrod seals (stretch the tubes a little).
2. Install spring-loaded pushrod tubes. Get a high quality set, metal, not plastic. Easier. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Toasty Samba Member
Posted: Sat Apr 17, 2021 11:50 pm Post subject: Re: The Stupid Question Thread |
are wires supposed to run behind the firwall insulation? Asking for a ......well you know. |
Cusser Samba Member
Posted: Sun Apr 18, 2021 6:52 am Post subject: Re: The Stupid Question Thread |
Toasty wrote: |
Wires for the tail light assemblies and license plate light? Yes, under the tar boards. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
kpf Samba Member
Joined: March 01, 2017 Posts: 852 Location: California, US
Posted: Sun Apr 18, 2021 7:58 am Post subject: Re: The Stupid Question Thread |
kirk1015 wrote: |
https://www.thesamba.com/vw/classifieds/detail.php?id=2404790 |
Thank you for pointing that out. I didn’t know about that coil.
Another option would be to simply paint yours black. Use satin or maybe matte black. _________________ 1971 Super Beetle |
RockabillyFrankyDaisuke Samba Member
Posted: Fri Apr 23, 2021 8:05 am Post subject: Re: The Stupid Question Thread |
Hi everyone I have a 69 & well I really like close up pictures of a oem under the front bonnet wiring to the gauge + center knobs. Thanks gentleman |
mclumber1 Samba Member
Joined: June 22, 2008 Posts: 313 Location: Henderson, NV
Posted: Sun Apr 25, 2021 5:23 pm Post subject: Re: The Stupid Question Thread |
So I have a new (reproduction) steering wheel/horn button and a new turn signal cancelling ring. I see how they are supposed to attach together using 3 screws, but I can't figure out what that screw size should be. Unfortunately, the steering wheel and the cancelling ring didn't come with these screws. Does anyone know what size screws I need? _________________ 1968 Beetle |
GumboSlice Samba Member
Posted: Sun Apr 25, 2021 6:47 pm Post subject: Re: The Stupid Question Thread |
Whenever I'm turning over the pulley by hand it sticks pretty hard at a certain point in the rotation. Maybe 3/4 of the way to TDC. I can figure out exactly where it is if need be.
Should it be this way?
I'm turning the alternator. Sometimes it slips as well. |
Posted: Sun Apr 25, 2021 8:15 pm Post subject: Re: The Stupid Question Thread |
mclumber1 wrote: |
So I have a new (reproduction) steering wheel/horn button and a new turn signal cancelling ring. I see how they are supposed to attach together using 3 screws, but I can't figure out what that screw size should be. Unfortunately, the steering wheel and the cancelling ring didn't come with these screws. Does anyone know what size screws I need? |
3.5mm fine-pitch thread, maybe 1.00? (that's if I grabbed the right screw)
GumboSlice wrote: |
Does the tight spot go away if you remove the plugs?
If not, that doesn't sound good, as there shouldn't be significant binding going on. _________________ Two Bugs-
