VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Sun Jul 11, 2021 10:42 pm Post subject: Re: The Stupid Question Thread |
Technical tab at the top-right of the page, next to the search bar, select wiring from the drop-down menu. Once on the wiring page, select 'Type 1' from the options in the top-middle of the page and scroll down to the 74+ entries in the listing.
I think these should be the right ones, provided your wiring is mostly stock:
_________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Jul 12, 2021 6:45 am Post subject: Re: The Stupid Question Thread |
TechionDigit wrote: |
After a bit of looking around my dash & trunk I found out if I give my fusebox and steering column (the plastic bit that houses the turn signal & wiper assembly) a 'slight' bit of motivation (aka beating it with my palm, it'll turn back on before it'll go out again.
When the low beam goes off, if I just go to high beam then back to low beam it comes back on.. before going out again.
Long story short, there's a loose connection somewhere and I was wondering if someone has a link to the wiring & locations or pictures of what pins & plugs I need to start poking at! |
I would clean up ALL the terminals and fuse ends at the fuse box. Disconnect the battery negative terminal first, do one at a time.
A small wire brush (Dremel) in a Dremel or drill worked good for me. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Ulu Samba Member
Posted: Wed Jul 14, 2021 3:03 pm Post subject: Re: The Stupid Question Thread |
bergfan wrote: |
Aren't they horizontal normally? |
LOL...Well I was asking the stupid question it appears.
I don't have a stock car. It did not occur to me when I looked at the stabilizer that (not only is my suspension topped out) my steering gear is relocated sideways and rotated 9 deg down.
That rotation lowers the inner tie rod ends and the stabilizer bushing.
When I look at a stock car with people in it, the stabilizer lies flat. _________________ SS100 kit kar
1600cc DP |
GutshotGriz Samba Member
Joined: March 01, 2020 Posts: 5 Location: St Pete Beach, FL
Posted: Fri Jul 16, 2021 4:08 pm Post subject: Re: The Stupid Question Thread |
Dropped the engine in my 72 bug and found this plug hanging on the right side of the firewall. Nothing was connected to it. Can anyone tell me what it might be for?
finefettle Samba Member
Joined: October 13, 2006 Posts: 699 Location: Shelburne,Vermont
Posted: Sun Jul 18, 2021 5:52 pm Post subject: Re: The Stupid Question Thread |
Reverse light connection I believe. _________________ 1979 Bug project |
Jessa Dee Samba Member
Posted: Sun Jul 18, 2021 6:13 pm Post subject: Re: The Stupid Question Thread |
Hello guys, I bought a 1977 volkswagen superbeetle. I am hearing some squeaking/grinding noises in my brakes and it bothers me a lot. Does it sound good to replace the brake pads only? or I should also replace the rotors? |
Cusser Samba Member
Posted: Sun Jul 18, 2021 6:30 pm Post subject: Re: The Stupid Question Thread |
Disclaimer: I've never worked on a VW that new.
Jessa Dee wrote: |
On my trucks with front disc brakes or on my VWs with all-drum brakes, I say one cannot make decision on whether to replace or even regrind rotors or drums until I get things apart and inspect. Many disc pads have squealer tabs to indicate to the driver that it's time to check the pad thickness before causing more expensive damage. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
TechionDigit Samba Member
Joined: June 29, 2021 Posts: 74 Location: San Antonio, Texas
Posted: Mon Jul 19, 2021 4:45 pm Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
Disclaimer: I've never worked on a VW that new. |
Looking in the Official Volkswagen Service Manual for 70-79 Beetles, S Beetles & Ghias the brakes never altered over the years so your knowledge is valid.
But yes, it's better to disassemble and inspect your brakes before you start shaving it out and just slapping new parts onto it. _________________ 1974 Texas Yellow Super Beetle
2004 Passat 1.8T Wagon
1994 Sedan Firebeetle |
Cusser Samba Member
Posted: Tue Jul 20, 2021 8:59 am Post subject: Re: The Stupid Question Thread |
Jessa Dee wrote: |
Cusser wrote: |
But yes, it's better to disassemble and inspect your brakes before you start shaving it out and just slapping new parts onto it. |
OK, 1977 Super Beetle has drum brakes in both front and rear. Someone is going to have to remove the drums to take a look; if the drums need "turning", likely will need to find a VW machine shop or so, most auto parts stores cannot turn/re-grind drums that size.
"Special" tools needed for front will be a 6mm allen socket; for the rear drums, a 36mm socket and big breaker bar (or Torque Tool) is needed for the big axle nut (230 ft lbs). Plus 2 new big cotter pins to retain those will be needed; and if replacing rear brake shoes, then retainers will be needed to swap over the parking brake actuating levers.
You may find broken spring(s), may need a new hardware kit. Only removal of drums will tell what is needed to fix properly and safely.
So USA Beetles only have drums and brake shoes; only later Karmann Ghias in USA had rotors and brake pads in the front. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
BCE56 Samba Member
Posted: Sat Jul 24, 2021 4:09 pm Post subject: Re: The Stupid Question Thread |
In the classified section Parts - Type 1/Bug - 1968-up,
I see listings for "early" and "late" parts.
What year model is which? _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
Posted: Sat Jul 24, 2021 6:33 pm Post subject: Re: The Stupid Question Thread |
BCE56 wrote: |
What year model is which? |
I'm not certain myself, but I believe that's to differentiate between super-Beetles (71/72-on?) and standard Beetles (68-70?).
I'm sure somebody else can define it more precisely. _________________ Two Bugs-
Cusser Samba Member
EVfun Samba Member
Posted: Sat Jul 24, 2021 10:28 pm Post subject: Re: The Stupid Question Thread |
BCE56 wrote: |
Since you are in the later model Bug parts section, that reference is most likely about Super Beetle specific parts. The earlier SB's used the same windshield and dash as the regular Bug and had a somewhat different front suspension. Later SB's had the curved windshield large dash, and a number of changes up front. I'm not very knowledgeable on the later Bugs but believe early refers to '71-'72 Super Beetles and late refers to the '73-'79 models. _________________
Wildthings wrote: |
bergfan Samba Member
Joined: March 07, 2007 Posts: 151 Location: NewZealand
Posted: Sat Jul 24, 2021 11:28 pm Post subject: Re: The Stupid Question Thread |
EVfun wrote: |
BCE56 wrote: |
Since you are in the later model Bug parts section, that reference is most likely about Super Beetle specific parts. The earlier SB's used the same windshield and dash as the regular Bug and had a somewhat different front suspension. Later SB's had the curved windshield large dash, and a number of changes up front. I'm not very knowledgeable on the later Bugs but believe early refers to '71-'72 Super Beetles and late refers to the '73-'79 models. |
Here in NZ the early SB was a 1302s and latter was a 1303s with a curved windscreen, all ours had disc brakes on the front |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Fri Jul 30, 2021 9:20 am Post subject: Re: The Stupid Question Thread |
Any decebt spark plugs for a 1600dp that i can get from Amazon (in the us)? Got a bunch of Amazon money i want to use tbh. _________________ '74 - front disks/lots more work to do |
BCE56 Samba Member
Posted: Fri Jul 30, 2021 11:31 am Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
For The Samba, early is up through 1967 and late model is 1968 and newer. |
Thanks.
Looks like '67 and '68 were transitional models with certain year-specific parts. (There appears to be some overlap into 1969 as well.)
My Bug is a '69 with a 1973 (AK) 1600 DP motor. '67 front fenders and front & rear bumpers, 1970 engine cover, installed by P.O. You might call it a Frankenbug.
There is no provision for a fuel door cable. Odd. _________________ =BCE56=
'86 Syncro tintop
J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 613 Location: 253 Then, Now 206.
Posted: Sat Jul 31, 2021 9:57 am Post subject: Re: The Stupid Question Thread |
STUPID Question: Cap and Rotor.
I've got an O9 dist.
The rotor inside seems "loose" and is See the alignment tab is a little chewed up.
Maybe the mechanic (Or me) was too forceful trying to get it in place...
Regardless, Will the Cap and Rotor from Orilies fit?
I just need to test a theory.... and want to replace the Cap and rotor real quick.
Or do I need to hunt down a cap and rotor online? Because I've looked a bit and cand find any real distinction.
Thanks! _________________ 1970 Beetle | Basically Stock 1600 SP |
Cusser Samba Member
Posted: Sat Jul 31, 2021 10:43 am Post subject: Re: The Stupid Question Thread |
J-Gaz. wrote: |
Thanks! |
I've run vintage German 009 distributors in both my VWs for over 4 decades each.
There are numerous Bosch distributors used on VWs that use the same rotor and cap. So would one from O'Reilly Auto fit??? Quite possibly, take yours in and match up.
My information shows rotor 04033 and cap 03010; does O'Reilly show matches to those? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
J-Gaz. Samba Member
Posted: Sat Jul 31, 2021 12:47 pm Post subject: Re: The Stupid Question Thread |
Always appreciate it Cusser.
Not sure, but I'll find out!
Cusser wrote: |
J-Gaz. wrote: |
Thanks! |
My information shows rotor 04033 and cap 03010; does O'Reilly show matches to those? |
EVfun Samba Member
Posted: Sat Jul 31, 2021 1:54 pm Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
J-Gaz. wrote: |
Thanks! |
Cusser pretty well covered it. I would add just one thing. The cap and rotor is the same one used on all Bugs sold in the USA from 1969-1979. _________________
Wildthings wrote: |
