Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Nov 04, 2022 11:44 am Post subject: Re: The Stupid Question Thread |
zgomo wrote: |
Dumb question for y'all. How important are the transmission mounts? Mine are clearly dry rotted, but I really (emphasis on really) do not want to pull the trans. |
For the two rear mounts, the transmission does NOT need to be pulled to replace those, just remove the engine and raise the transmission a couple of inches. On my VWs, the big nuts use a 27mm socket.
For the front mount - and mine was still in decent shape after 46 years - some state that the transmission can just be pulled rearward to replace it. From your photo below - and congrats on wearing safety glasses - you have IRS so you'd need the 8M triple square wrench if you do remove the entire transmission.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
zgomo Samba Member
Joined: December 03, 2021 Posts: 102 Location: Las Vegas
Posted: Fri Nov 04, 2022 12:44 pm Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
zgomo wrote: |
Thanks guys. I'll see about replacing the rears, the front one is in somewhat better condition. |
Gor77 Samba Member
Posted: Mon Nov 14, 2022 6:47 am Post subject: Re: The Stupid Question Thread |
hi all.
I have a stupid question about the alternator
Does my alternator require a voltage regulator.
alternator without nameplates and inscriptions
engine 1969
slayer61 Samba Member
Posted: Mon Nov 14, 2022 8:14 am Post subject: Re: The Stupid Question Thread |
No Sir. You have an internal regulator. Excite the stator with the male tab sticking up and charge the battery with the stud connection. _________________
Cusser wrote: |
... Most folks are idiots when it deals with electrical !!! |
67rustavenger wrote: |
3/4 race cam? What's missing, one of the lobes? |
Paul
'68 Manx clone... Sears??
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
44 HPMX
EMPI GTV 2 STG II wedge ports
CB Magna spark
1 5/8 merged collector w/ hater stinger |
yungnewb Samba Member
Joined: October 10, 2022 Posts: 11 Location: Mesa, AZ
Posted: Wed Nov 30, 2022 9:43 pm Post subject: Re: The Stupid Question Thread |
i have a 94 mexi-beetle with a SA transmission that is leaking at the side plate. can i loosen the side plate while in the car and seal it with permatex or a similar sealant/gasket maker? if so what sealant/gasket maker? if not what should i do? |
vamram Samba Member
Posted: Fri Dec 02, 2022 11:27 am Post subject: Re: The Stupid Question Thread |
Has anyone ever installed an *electric* air conditioner in a Super Beetle? Rather than one like the Gilmore system? I'm thinking of the systems that use an electric compressor and only require a 90 amp alternator, so no need to modify the shroud and add brackets for a mechanical/belt-driven compressor in the engine compartment.
Kind of like this: https://www.amazon.com/Universal-Electric-Conditioner-Compressor-Motorhome/dp/B09GP9RNYZ
https://www.amazon.com/Universal-System-Electric-A...&psc=1 _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Purple Martin Samba Member
Posted: Fri Dec 02, 2022 1:00 pm Post subject: Re: The Stupid Question Thread |
Stupid question: what is this? Some kind of sensor just below & in front of the dizzy. There is no wire attached, should there be?
_________________ 1959 1600 bug
1975 2L bay camper |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Fri Dec 02, 2022 1:42 pm Post subject: Re: The Stupid Question Thread |
Purple Martin wrote: |
That's your oil pressure sender, and yes there should be a wire attached. It will go to the oil pressure warning light on the speedo. _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
Posted: Fri Dec 02, 2022 3:04 pm Post subject: Re: The Stupid Question Thread |
Thanks! I'll fix that. _________________ 1959 1600 bug
Posted: Fri Dec 02, 2022 3:06 pm Post subject: Re: The Stupid Question Thread |
Next stupid question: what is this broken black rubber round thing, located on the top-right-front of the case?
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Fri Dec 02, 2022 4:29 pm Post subject: Re: The Stupid Question Thread |
Remnants of the Top Dead Center sensor that was part of the diagnostic system used in the early-mid 70s. _________________ Andy T.
Posted: Fri Dec 02, 2022 5:27 pm Post subject: Re: The Stupid Question Thread |
glutamodo wrote: |
Remnants of the Top Dead Center sensor that was part of the diagnostic system used in the early-mid 70s. |
Thanks, with your help I found more info about it here: https://ratwell.com/technical/TDCMarker.html _________________ 1959 1600 bug
vamram Samba Member
Posted: Sat Dec 10, 2022 12:44 pm Post subject: Re: The Stupid Question Thread |
I'm installing a Thunderbird header on my '74 Super. Is there any value to using header wrap or header armor on a header?
Or it this just inviting rust...? This will be on a heavily driven, all-weather driving Super. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Dec 10, 2022 1:50 pm Post subject: Re: The Stupid Question Thread |
vamram wrote: |
Or it this just inviting rust...? This will be on a heavily driven, all-weather driving Super. |
Ceramic coat it. And you can wrap it.
Painted, leave it bare.
Better yet. Sand it down and paint it with VHT High heat header paint. Make sure to follow the curing instructions. It makes a difference.
The burning question is. Where'd ya find that relic? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
vamram Samba Member
Posted: Sat Dec 10, 2022 4:07 pm Post subject: Re: The Stupid Question Thread |
Heh heh, I found it here in the classifieds! I think the seller still has an ad up. I already cleaned it up and painted it w/VHD so am just going to stick w/that. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
vamram Samba Member
Posted: Sun Dec 11, 2022 9:19 am Post subject: Re: The Stupid Question Thread |
Another dumb question about the header - I missed that the hole for the top exhaust stud is too deep for normal head studs. I'm not having a lot of luck finding a stud that's long enough, figure I need at least 65mm in length for it to make it through the header so I can catch the nut.
Or can I remove the stud and replace it w/a bolt like this one?
https://www.amazon.com/Screw-Threaded-Socket-Finis...3&th=1
Click to view image
Save the Supers!! |
Posted: Sun Dec 11, 2022 9:37 am Post subject: Re: The Stupid Question Thread |
Victor,
You keep serving up softballs to hit out of the park.
Get the same bolt at Ace Hardware, and cut off the hex head.
Install your new stud in the head and call it a day.
Using a bolt for the header is risking stripping the threads out of the head in the future. _________________ I have learned over the years.
Buy Once, Cry Once!
vamram Samba Member
Posted: Sun Dec 11, 2022 9:46 am Post subject: Re: The Stupid Question Thread |
Lol, I'll keep throwing softballs if you keep hittin' 'em! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sun Dec 11, 2022 10:47 am Post subject: Re: The Stupid Question Thread |
vamram wrote: |
Lol, I'll keep throwing softballs if you keep hittin' 'em! |
Buy Once, Cry Once!
BCE56 Samba Member
Posted: Sun Dec 25, 2022 12:36 pm Post subject: Re: The Stupid Question Thread |
I am trying to diagnose/rectify abrupt clutch engagement near top of pedal travel.
To date have replaced nosecone, trans mounts, clutch and T/O bearing.
Also have installed a *refurbished* German pedal assy. The old assy was a rewelded mess.
Added a spacer to Bowden tube. Readjusted pedal freeplay to 1/2".
Transaxle: AH, appears unmolested and sound.
What are the differences between these clutch pedal shafts?
113 721 305A ('46-'63)
113 721 305B ('64-'72)
111 721 305B ('73-'79)
Are they interchangeable?
If (inadvertently) mismatched, how would clutch engagement be affected? _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
