NachoCar Samba Member
Posted: Tue Jan 03, 2023 1:58 pm Post subject: Re: The Stupid Question Thread |
I need:
case align bored and crankshaft ground to match
Is there a service or term for such service of installing main bearings and torqueing to spec in an attempt to ensure machine work is correct?
Know what I mean? |
Posted: Tue Jan 10, 2023 9:52 am Post subject: Re: The Stupid Question Thread |
I'm wearing this thread out....
can you bolt a stock camshaft gear to an Engle crankshaft?
Thank you. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2225 Location: HdG, MD & NJ
Posted: Tue Jan 10, 2023 11:00 am Post subject: Re: The Stupid Question Thread |
Yes _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
vamram Samba Member
Posted: Mon Jan 16, 2023 5:02 pm Post subject: Re: The Stupid Question Thread |
I have a couple.
1. I know intuitively and from having been told and read it endless times that "lugging" the engine is bad. But what exactly does lugging it do, mechanically speaking...???
2. I just installed a Bocar 34-3 from my stash, kitted, runs great, responsive to tuning. However, it starts hard regardless of the outside temps. Not horribly so, but I'm used to the car starting on the first spark of the ignition w/the carb it replaced (a different story for a different thread). One observation is that the Bocar requires about 4.5 turns out of the volume screw to achieve a steady idle speed. Could the hard start be due to the volume screw's passage having been damaged by overtightening so that fuel trickles by while sitting...?
Thanks!
V _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
OldSchoolVW's Samba Member
Posted: Mon Jan 16, 2023 8:44 pm Post subject: Re: The Stupid Question Thread |
With regard to lugging the engine ...
Running an air cooled engine at low rpms while under load reduces the air flow causing the engine to run hotter. Likewise, oil pressure would drop with lower rpms ... not a good thing for any engine (hence the red oil pressure warning light). It seems that excessive heat and a lack of lubrication can make plenty of bad things happen. _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 814 Location: San Juan Islands
Posted: Fri Jan 27, 2023 2:56 pm Post subject: Re: The Stupid Question Thread |
Does the Bocar 34-3 have a accel pump? Couple of pumps when cold should do the trick.
Or like you said, is there fuel leaking by almost flooding the engine? Does the Bocar 34-3 have a fuel cut off? That might be bad? _________________ When I set my timing, why do I flush, then take a pee? |
1969vertbug Samba Member
Joined: November 11, 2021 Posts: 35 Location: Toronto, Canada
Posted: Fri Feb 03, 2023 3:17 pm Post subject: Re: The Stupid Question Thread |
So I've been redoing the front end on my 69 beetle convertible, and I took the ball joints in to my local shop to press. When I got them back, he said one of them spun on the way in, so it is a little more than an 1/8 of an inch off the mark. He said if I got a new one he'd press it in for free, but that it should not matter. I guess the question I have for you is, does it matter if the ball joint is a bit off the mark, or will it still do its job? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Feb 03, 2023 4:21 pm Post subject: Re: The Stupid Question Thread |
1969vertbug wrote: |
Was this a new BJ that the shop incorrectly pressed in? Or just the old one after some clean up?
Either way, if it was new, the shop should replace it, at no charge to you.
If it was an old one, maybe you could share the cost of the replacement with the shop. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Feb 04, 2023 2:04 pm Post subject: Re: The Stupid Question Thread |
67rustavenger wrote: |
If it was an old one, maybe you could share the cost of the replacement with the shop. |
You're probably right. He did offer to cover the labor, and he's been really good to me over 20 years, so I'm not going to fight over $30.
Second stupid question of the week:
If you're in Canada, anyone know where I can get a one foot length of 5/8 or 15mm fuel hose (1969 beetle vent hose from tank to T fitting?
I seem to only be able to find 10-25ft lengths, and that seems like a lot of hose to waste for such a short length. |
mpls_ham Samba Member
Joined: November 21, 2013 Posts: 78 Location: Northern Black Hills
Posted: Sun Feb 05, 2023 9:25 am Post subject: Fresh air fan access |
I need to access my fresh air fan (sounds like a gerbil in a wheel) the cover under the hood seems to be glued as well as screwed in. Is this standard procedure or did I have an anal PO? _________________ 1970 Westfalia - Evangeline
1973 Beetle Convertable |
vamram Samba Member
Posted: Sun Feb 05, 2023 9:35 am Post subject: Re: The Stupid Question Thread |
The goop they used to close it from factory is super sticky. You need some muscle and leverage to remove it. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Wed Feb 08, 2023 2:45 pm Post subject: Re: The Stupid Question Thread |
I got a new 3/4 empi sway bar from cip1.ca for my beetle convertible. Do I need to paint it before I install it or is it supposed to/can it go in raw? |
mukluk Samba Member
Posted: Wed Feb 08, 2023 2:55 pm Post subject: Re: The Stupid Question Thread |
Depends how averse you are to it rusting. It doesn't need to be painted in order to install it, but likewise it needn't be left unprotected to rust.
In all fairness it does seem to come plated, but in my opinion plating often tends not to hold up as well as paint. _________________ 1960 Ragtop w/Semaphores "Inga"
Posted: Wed Feb 08, 2023 2:57 pm Post subject: Re: The Stupid Question Thread |
mukluk wrote: |
Depends how averse you are to it rusting. It doesn't need to be painted in order to install it, but likewise it needn't be left unprotected to rust. |
Sounds like I should paint it. Got it. Thanks for the quick reply! |
charles6969 Samba Member
Posted: Sun Feb 19, 2023 12:43 pm Post subject: Re: The Stupid Question Thread |
what's the loudest exhaust that will fit in the stock aprons |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9970 Location: Huntington Beach, CA
Posted: Sun Feb 19, 2023 1:49 pm Post subject: Re: The Stupid Question Thread |
charles6969 wrote: |
An open merged header with no muffler! _________________ Jimbo
TDCTDI wrote: |
BCE56 Samba Member
Posted: Mon Feb 20, 2023 5:45 pm Post subject: Re: The Stupid Question Thread |
BCE56 wrote: |
I am trying to diagnose/rectify abrupt clutch engagement near top of pedal travel.
To date have replaced nosecone, trans mounts, clutch and T/O bearing.
Also have installed a *refurbished* German pedal assy. The old assy was a rewelded mess.
Added a spacer to Bowden tube. Readjusted pedal freeplay to 1/2".
Transaxle: AH, appears unmolested and sound.
What are the differences between these clutch pedal shafts?
113 721 305A ('46-'63)
113 721 305B ('64-'72)
111 721 305B ('73-'79)
Are they interchangeable?
If (inadvertently) mismatched, how would clutch engagement be affected? |
LATER:
I find clutch pedal shaft hook arms come in short and long varieties.
And clutch levers at bellhousing in two lengths also.
It would seem that a mismatch between lever travel at both ends of the clutch cable would adversely affect clutch engagement.
How can I determine which lever is on my trans? _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
Posted: Mon Mar 13, 2023 2:51 pm Post subject: Re: The Stupid Question Thread |
Hi all,
Should there be any kind of grease/lubricant on the rear drum spindle (I don't even know if that's the name for it, but the thing sticking out in the pic above). I know the teeth don't move against each other, but I feel any metal on metal should be lubed, shouldn't it? (If not, I'm in the right thread at least...) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
Posted: Mon Mar 13, 2023 3:11 pm Post subject: Re: The Stupid Question Thread |
It is not necessary to use a fine film of grease on the splines.
What is IMPORTANT is to tighten the rear axle nuts to 250 ft lbs or more and use a brand-new giant cotter pin to retain the axle nut.
Use a Torque Tool, borrow a 250 ft lb torque wrench from O'Reilly, whatever !!!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Mar 13, 2023 4:57 pm Post subject: Re: The Stupid Question Thread |
Cusser wrote: |
Use a Torque Tool, borrow a 250 ft lb torque wrench from O'Reilly, whatever !!!! |
Thanks for the quick response, Cusser! I'll be sure to do that. |
