Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Fri Mar 10, 2017 10:24 am Post subject: Re: The Stupid Question Thread |
Patty B. wrote: |
This boot that fits on the oil breather tube on the bottom of the car--is it suppose to be closed, sealed, on the pointy end or slit like a whistle mouth piece? Isn't it suppose to vent? I never had one before putting one on last fall and I was surprised to see it without a slit, the pictures appears to have one but it could be a highlight?
You have to put the slit in yourself, right along the bottom seam. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
Posted: Fri Mar 10, 2017 3:13 pm Post subject: Re: The Stupid Question Thread |
Thanks!! They should really mention that somewhere. |
unclewede Samba Member
Posted: Mon Mar 13, 2017 1:22 pm Post subject: Re: The Stupid Question Thread |
77 standard with sunroof: At the chicken foot I have a tube going to the defrost, one going to the fresh air box, and a 3rd that runs up the frame outside the windshield. Where does THAT one go??? |
Posted: Wed Mar 15, 2017 12:22 pm Post subject: Re: The Stupid Question Thread |
OK, that one goes to the side of the windshield for defrosting that corner. It seemed deceptively farther up the frame it would end, the bend is rather sharp right there. |
Posted: Wed Mar 29, 2017 9:35 am Post subject: Re: The Stupid Question Thread |
So, IF I had both connectors connected to a source, and IF I had complete connectivity across the rear window, how would I turn on the defrost back there? |
jinx758 Samba Member
Posted: Wed Mar 29, 2017 10:14 am Post subject: Re: The Stupid Question Thread |
I think it must be part of the entire defrost system. One of the levers between the seats controls heat on/off & the other one is defrost ... maybe front AND rear.
I'm guessing. Someone with more knowledge may chime in. Makes sense to me, though.
Good luck ... jinx _________________ " It's not valuable unless you learn something from an experience. " Henry Ford
It's not unlike the same difference
You can't push a rope
VALVES (cold)
POINTS
TIMING
CARB (fully warmed engine)
SCRAPE ALL GROUNDS
My Craigslist rescued 100 footer :
1971 Standard Bug
1776cc dual port
034 distributor
38mm EGAS Carburetor |
LucKaS Samba Member
Joined: December 25, 2015 Posts: 170 Location: Alabama
Posted: Sat Apr 01, 2017 8:12 pm Post subject: Re: The Stupid Question Thread |
Here's my stupid question.
With a either a stock or lightly modified 1600 dp, would a 5 speed trans with close-ish 3rd and 4th be a good idea -or bad idea- for quicker acceleration to highway speeds? _________________ If only all of life's little problems could be solved with a little PB Blaster and a hammer. |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Sun Apr 02, 2017 7:06 am Post subject: Re: The Stupid Question Thread |
There are only 3 VERY expensive 5 speed options:
1. Porsche 5 spd
2. Gene Berg 5 spd
3. Subaru 5 spd
All three are are custom installs. You'll need to have a lot of mechanical/fabricating skills or a lot of money.
Unfortunately, there's no easy/cheap solution. |
vamram Samba Member
Posted: Thu Apr 06, 2017 1:12 pm Post subject: Re: The Stupid Question Thread |
Ok, I started a thread about this, but no replies, maybe it's more of a stupid question, so I figured I'd post it here...
Can the struts, spindles and control arms of a '74 Super be installed on a '72 Super? The tie rods, steering box, damper and centerlink are exactly the same...
Thanks!
Victor _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Thu Apr 06, 2017 5:55 pm Post subject: Re: The Stupid Question Thread |
[quote="vamram"
Thanks!
Victor[/quote]
Victor, I read your thread and thought to myself. Why does he not just take one off and try it on the car that he wants to put them onto?
See where I'm going with this? I can't answer your specific question, as I have never owned an SB. But when wanting to try changing things from one year to another. I test fit to see if it works.
Case in point, I have two 67's. I wanted to swap that Cad plated gen pulley from the rusty car under the cover in the driveway to the DD one in place of the POS chrome one. Guess what? It didn't fit because the gen shaft on the pulley end was different from one engine to the other. But I didn't have to spend a dime to find out.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
vamram Samba Member
Posted: Fri Apr 07, 2017 8:29 am Post subject: Re: The Stupid Question Thread |
Rutsavenger, I thought of doing that...but it's a lot more work than swapping pulleys! I'd have to take apart the front end on both cars basically just to see if it would work! I think I'll wait to see if one of the guys who's done it responds in the thread w/either pics of such a swap or a complete list of parts that get swapped. I haven't been able to completely pull that together based on the replies. Course, looking at the answers on my phone probably isn't the best way to do it.
Thanks!
Click to view image
Save the Supers!! |
Posted: Fri Apr 07, 2017 8:46 am Post subject: Re: The Stupid Question Thread |
Yea. There are couple of good answers in your original thread regarding the strut swap. I was just trying to think out of the box a little.
Buy Once, Cry Once!
Bhain Samba Member
Joined: November 15, 2016 Posts: 48 Location: Newport WA
Posted: Fri Apr 07, 2017 4:12 pm Post subject: Re: The Stupid Question Thread |
I have a stupid question, are there any aftermarket VW parts venders that are not complete crap? I have worked on cars since I was a kid and have seen quite a bit of junk, but gee wiz some of this stuff is not worth the box it came in. In re wiring a beetle this month, I got a defective headlight relay, flasher switch and turn signal lever switch assembly that was a joke. I don't mind paying extra for good stuff, but where is it? Oh, and just to add insult to injury, I just received an ignition switch that was "assembly required" as it was in about 6 pieces. _________________ 1976 Baja 1600 dp single carb.
wcfvw69 Samba Purist
Posted: Fri Apr 07, 2017 5:03 pm Post subject: Re: The Stupid Question Thread |
Bhain wrote: |
I have a stupid question, are there any aftermarket VW parts venders that are not complete crap? I have worked on cars since I was a kid and have seen quite a bit of junk, but gee wiz some of this stuff is not worth the box it came in. In re wiring a beetle this month, I got a defective headlight relay, flasher switch and turn signal lever switch assembly that was a joke. I don't mind paying extra for good stuff, but where is it? |
It's called NOS (new old stock) VW parts. Cruise the classifieds here and ebay. Nothing will ever be as good as the original VW made parts. _________________ Contact me at [email protected]
The Samba member since 2004.
Dan Hiebert Samba Member
Joined: July 14, 2016 Posts: 169 Location: Northern Maine
Posted: Fri Apr 07, 2017 5:12 pm Post subject: Re: The Stupid Question Thread |
unclewede wrote: |
My '70 has a toggle switch under the dash just to the left of the ash tray for the rear window defroster...my defroster doesn't work, tho. From perusing this forum I gather that is a common problem. |
Posted: Tue Apr 11, 2017 5:29 pm Post subject: Re: The Stupid Question Thread |
Not a stupid question, but a not so proud moment in troubleshooting. Running through the State inspection checklist before taking the '70 in and the left front turn signal wouldn't work right. One of the filaments in the double filament bulb would light when I turned the lights on, and the same filament would blink when I turned the signal on. Same filament would blink with the lights off, signal on. Must be the bulb, put a spare bulb in, same thing. Must be the unit or the circuit. Checked and cleaned connections, not fixed. Took signal out, cleaned everything, put it back, not fixed. Left it for a couple days, checked again today hoping that the ACVW elves had taken pity on me and fixed it while I wasn't looking. No such luck, although I'm pretty sure I heard them snickering from the rafters. Took the signal off again, checked the wires because PO had cut and spliced them, rather than disconnecting them. Unknown why, but it is what it is. Wiring is good. On a whim, I rummaged about for a double filament bulb I vaguely recall seeing when I was looking for something else a while back that I know is new, but still at least 10 years old. You may see where this is going. Left front turn signal works now. Probably excusable since I did try another bulb first, but I have to admit, the spare I tried first was at least 20 years old, and I don't even remember if I bought it new, or threw it in my electrical stuff box after taking it out of something else. Oh, well. Live and learn, and take a trip to town to get new spare bulbs. |
kirk1015 Samba Member
Joined: June 15, 2015 Posts: 281 Location: New Jersey
Posted: Wed Apr 12, 2017 4:20 pm Post subject: Re: The Stupid Question Thread |
Could I use a Carburetor Return Spring on my heater box arm?
I seem to have lost one of the springs. _________________ Jim Douglas....I am Not. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Apr 13, 2017 11:04 am Post subject: Re: The Stupid Question Thread |
kirk1015 wrote: |
I seem to have lost one of the springs. |
You can if it will fit. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
drunkpig Samba Member
Joined: February 15, 2013 Posts: 12 Location: Canyon, Texas
Posted: Thu Apr 20, 2017 3:09 pm Post subject: Re: The Stupid Question Thread |
How many fuel tank retaining plates are there on a 73 SB? Bentley says there's 4. And I've seen all four of them on 72 and older bugs, but for the life of me I can only find 2 on my 73.
I mean, after all, this is the stupid question thread, isn't it? |
Posted: Thu Apr 20, 2017 3:11 pm Post subject: Re: The Stupid Question Thread |
drunkpig wrote: |
I have a 74 Super Beetle, and it has 4. You are probably missing two. _________________ Jim Douglas....I am Not. |
