RichNJohn Samba Member
Joined: April 07, 2017 Posts: 91 Location: Palm Springs, CA
Posted: Sat Apr 21, 2018 6:57 am Post subject: Re: The Stupid Question Thread |
mukluk wrote: |
RichNJohn wrote: |
All the info I can find about removing and installing the engine and transaxle indicates how to do each separately. Can the engine and transaxle be removed/installed as a unit and is so would that be a preferred way to do it? |
Think about this for a moment: if removing the engine and transaxle as a unit was the preferred method, then why is there no procedure for it in the shop manual?
As to whether it's possible, you would have to do one of two things: either remove the rear apron, or strip the engine down to a long block first (and even then some tweaking of the rear apron may be needed to get the engine clear). |
Yeah, I figured it was a stupid question, just wanted to satisfy my curiosity which is why I posted it here. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Sat Apr 21, 2018 7:44 pm Post subject: Re: The Stupid Question Thread |
Patrick_S wrote: |
A question. Which type of grease should I use on the gland nut bearing in the flywheel? I have the engine out of the car now and I read this is a good moment to add some fresh grease. Just regular lithium grease? |
Universal grease or lithium grease is fine for lubing the pilot bearing. Use enough to lube the needle bearings but not so much that it might sling out and contaminate the clutch disk -- a dab on your pinky is usually enough unless it's exceptionally dry. _________________ 1960 Ragtop w/Semaphores "Inga" |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Sun Apr 22, 2018 4:54 am Post subject: Re: The Stupid Question Thread |
Are standard tow bars good for both k/l beams and ball joint beams. ? _________________ "Albatross"! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Sun Apr 22, 2018 6:12 am Post subject: Re: The Stupid Question Thread |
calvinater wrote: |
Are standard tow bars good for both k/l beams and ball joint beams. ? |
Yes! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Apr 22, 2018 9:17 am Post subject: Re: The Stupid Question Thread |
Thanks. Hows the stroker coming along? _________________ "Albatross"! |
Posted: Sun Apr 22, 2018 10:56 am Post subject: Re: The Stupid Question Thread |
calvinater wrote: |
Thanks. Hows the stroker coming along? |
Slow but picking up speed. I have installed a CoolRydes stiffy bar setup.
I need to install a clutch arm return spring. So far that has proved to be fun.
And when I pulled the 1679. I found a hole in the left axle boot. Got a replacement on order from ACN. Along with a few misc. additional parts.
I'll likely fire it in the next two weeks. That is if I get off my lazy ass and get it done.
Have a great day. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sun Apr 22, 2018 2:12 pm Post subject: Re: The Stupid Question Thread |
That spring for the clutch arm was not too bad. A couple of threads on here had some good tips.. Finding the correct spring was the hard part. _________________ "Albatross"! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9959 Location: Huntington Beach, CA
Posted: Sun Apr 22, 2018 2:54 pm Post subject: Re: The Stupid Question Thread |
RichNJohn wrote: |
mukluk wrote: |
RichNJohn wrote: |
As far as I know, it is impossible in a stock configuration. As the axles on a swing axle sit to far forward of the horn ends. Same with the flanges of an IRS tranny. Maybe if you removed the flanges from the tranny first. But that a pain in the ass part to have to reinstall! I even have the official VW tool for installing the flange and it is still a pain in the ass! Easier to take them out separately! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
Ron G Samba Member
Joined: September 05, 2013 Posts: 228 Location: Albuquerque, NM
Posted: Mon Apr 23, 2018 9:10 am Post subject: Re: The Stupid Question Thread |
Fixed
GaryH611 Samba Member
Joined: November 05, 2011 Posts: 6 Location: Long Island, NY
Posted: Tue Apr 24, 2018 12:49 pm Post subject: A Stupid Question |
I have a 71 Super Beetle Convertible; someone at a car show said my speedometer is incorrect because it shows speeds up to 100 mph. He claims the 71 goes up only to 90 mph,,,, anyone verify this for me? |
kpf Samba Member
Joined: March 01, 2017 Posts: 852 Location: California, US
Posted: Tue Apr 24, 2018 1:40 pm Post subject: Re: A Stupid Question |
GaryH611 wrote: |
I believe that is correct. My '71 Super has a 90mph speedometer and the owner's manual shows the same.
Regards,
Kris _________________ 1971 Super Beetle |
Ron G Samba Member
Posted: Tue Apr 24, 2018 4:21 pm Post subject: Re: A Stupid Question |
GaryH611 wrote: |
I have a 71 super and it is 90mph |
anthax Samba Member
Joined: October 21, 2016 Posts: 283 Location: Hälsingland, Sweden
Posted: Thu Apr 26, 2018 8:41 am Post subject: Re: The Stupid Question Thread |
Stupid question:
What doors fit between models?
My 1302-71 might be needing better doors, what should I be searching for?
Any 68-73 doors? |
mukluk Samba Member
Posted: Thu Apr 26, 2018 10:40 am Post subject: Re: The Stupid Question Thread |
anthax wrote: |
Stupid question:
Any 68-73 doors? |
All Beetle sedan doors from 1968 up through the end of production should fit, though you may run into variances in trim hole location on anything newer than '77. _________________ 1960 Ragtop w/Semaphores "Inga" |
anthax Samba Member
Posted: Thu Apr 26, 2018 11:48 am Post subject: Re: The Stupid Question Thread |
mukluk wrote: |
anthax wrote: |
Stupid question:
Any 68-73 doors? |
All Beetle sedan doors from 1968 up through the end of production should fit, though you may run into variances in trim hole location on anything newer than '77. |
Thank you! |
HeyWatchThis Samba Member
Posted: Sun Apr 29, 2018 9:02 pm Post subject: Re: The Stupid Question Thread |
Just setting things straight for myself before I start ordering parts and tearing stuff apart...
I have an early '68 bug, ball joint front, swing axle rear.
On the front beam, the original bushing/bearing parts in the tubes are (inside to out, neglecting torsion bars):
- Micarta bushing
- Needle bearing
- Rubber cap/seal
- Control arm
Is that correct?
If I want to replace the original hardware with polyurethane bushings, is it as simple as just knocking out the old hardware, leaving the torsion bars alone, grease up the poly bushings, and re-assemble everything? I've been looking for information online and not finding much. Also seen some talk of reaming out the tubes and I'm not sure if it's something I need to worry about.
Just replaced ball joints (should have waited and done it all at once..), looking to do tie rods, control arm bushings, and shocks sometime this summer.
Thanks for any insight. |
vamram Samba Member
Posted: Sat May 05, 2018 4:53 pm Post subject: Re: The Stupid Question Thread |
Do I have to drain the engine oil to replace the front oil pressure relief spring on an AS41 dual port case? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
mukluk Samba Member
Posted: Sat May 05, 2018 6:48 pm Post subject: Re: The Stupid Question Thread |
vamram wrote: |
Do I have to drain the engine oil to replace the front oil pressure relief spring on an AS41 dual port case? |
Depends on what your tolerance is for getting covered in oil while swapping out the spring. You don't have to per se, but you'll probably wish you had. _________________ 1960 Ragtop w/Semaphores "Inga" |
sb001 Samba Member
Posted: Thu May 10, 2018 3:11 pm Post subject: Re: The Stupid Question Thread |
Can I use moonshine to clean out my carburetor? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Thu May 10, 2018 3:21 pm Post subject: Re: The Stupid Question Thread |
sb001 wrote: |
Can I use moonshine to clean out my carburetor? |
IIRC alcohol can damage some carb finishes and some seals. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
