Small Car Performance, DIY Front A/C Installation
Page: Previous  1, 2, 3 ... 12, 13, 14 ... 35, 36, 37  Next
within the law
within the law is offline
PostPosted: Sat Jun 24, 2017 9:38 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
SC install almost completed 5 days ?!... think it could have been 3 easy if the SC instructions weren't soooooo poor.... below are photos of the wire that needs to be tied into compressor clutch signal wire for those w/ digifant systems...it signals the idle stabilization unit ... w/g from left engine bay... (p 31 pro training)
JudoJeff
JudoJeff is offline
PostPosted: Mon Jun 26, 2017 5:17 am    Post subject: shake down cruise Reply with quote
My first long road trip with the new air conditioning was great! So cold, dare I say it, I was tempted to blend heat in! (Blasphemy! Take him to the whipping post!)
Very happy with the in dash system.
Any thoughts on the rear system? Feedback does help my thought process....
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout)
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Jun 26, 2017 11:47 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Wow, I'm jealous, mine's on a long project van, I wish I could experience that as well right now. How gratifying it must be Cool
Congrats!
kourt
kourt is offline
PostPosted: Mon Jun 26, 2017 5:09 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Even with my Stage 2 fan being dead, the van delivered cold air on a 95 degree day.
Culprits: corroded grounds, burned wiring in the fuse box at position 1.
Solutions: new ground trees from GW, new 30A fuse bypass for fuse position 1.
Someday someone is going to inherit this van and wonder what the hell I did. Better label everything.
kourt
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Jun 26, 2017 7:15 pm    Post subject: Re: Condenser questions Reply with quote
r39o wrote:
My kit is on the way from Small Car.
It seems most people are sourcing their condenser from Nostalgic Air.
I think, as I recall, it is the 16 X 22 Superflow R-134a Condenser Part #54-1622 that gets used.
https://nostalgicac.com/condensers/unpainted-condenser/16-x-22-superflow-r-134a-condenser.html
I believe others have fit 16x24 but I do not see that one on the site.
I want front and rear air working in my Multivan.
With the idea that for such a system bigger is better for the condenser.
Any suggestions / experiences / sources / sizes / fitment issues for a dual air system?
Anybody?
within the law
PostPosted: Wed Jun 28, 2017 4:42 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
dash unit buttoned up .... had new lines made w/ #8 & #10 fittings ac shop but they won't connect to compressor (sanden 7499 or 9264 ac compressor ) purchased at buyautoparts.com ..... as well as all local parts shop selling same unit w/ same size rear threads ( that ac shop couldn't find anything to match ?) .... anyhow i've now got my 8 & 10 fittings in the engine bay & need appropriate compressor ..... suggestions folks ?
JudoJeff
JudoJeff is offline
PostPosted: Sat Jul 01, 2017 7:12 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
These are standardized fittings, not sure why your compressor won't fit them. You have female #8 and #10 hose connections? Maybe you picked up an oddball overseas unit? Can you switch out the ports on the compressor? Find an adapter?
So go to the parts store and walk the unit out to the vehicle to see if they fit. Don't have a better idea.....
izzydog
izzydog is offline
PostPosted: Fri Jul 07, 2017 6:02 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
I've been watching this thread and plotting my SC install for a few months and now it's time to get it going. I have a few questions:
-- Hoses/fittings: I'll to do the hoses myself. Anyone try EZ Clips? Or should I just get the Mastercool crimper?
-- Are Vintage Air's Superflow condensers any better than a "normal" parallel condenser? The Global Air 16x22 condenser (CN-PF1622) can be had for $55/free ship from Amazon. Nostalgic has a Superflow for $89 + ship.
Thanks.
JudoJeff
JudoJeff is offline
PostPosted: Fri Jul 07, 2017 6:05 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Ez clip very easy with smaller hoses.
izzydog
izzydog is offline
PostPosted: Fri Jul 07, 2017 6:26 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Do you mean the #6 hose or the #6 & #8? If so, what about the #10?
Any issues with leaking from the EZ clip fittings you made?
JudoJeff
JudoJeff is offline
PostPosted: Fri Jul 07, 2017 9:10 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
EZ-clip uses GH-134 hoses, designed for the system. All sizes, #6,8, or 10 are much smaller than any other hoses. They feed through the van much easier and have a better bend radius . If you can buy them on Ebay, you'll save $$$.
The parallel condenser I can't address, don't know about the Superflow one. Vintage Air makes high quality products. You need to size the condenser to the Compressor; too big of a compressor can overwhelm the condenser; too small and it can't keep up. You compare the cubic inches in each unit, I think, (not sure) the ratio is about 25% larger condenser. I can look it up if you really want to know. Vintage Air will also give you excellent recommendations, and they're smarter than I am....
izzydog
izzydog is offline
PostPosted: Sat Jul 08, 2017 12:23 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Thanks - I'll check on the condenser size via the compressor. Always assumed that you got the largest one that will fit.
kourt
kourt is offline
PostPosted: Sat Jul 08, 2017 3:14 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Update on this: my stage 2 fan relay (position 5) was bad. It was a Meyle general relay from GoWesty. I have another Meyle in there now, but I imagine I'll put a VW relay in there soon. I also found a replacement fuse panel for $20. Popped the halves open, cleaned with compressed air, then cleaned with DeOxit, dried, and reassembled. No more melted fuse slots. I also cleaned the van's ground trees. Stage 2 fan is running again. All is well.
kourt
kourt wrote:
... my stage 2 fan function died yesterday.
I look at the fuse box, position 1. The 30A fuse is melted, along with some accompanying wiring. I replaced the fuse, but the fan still does not work.
I'm opening the fuse box tonight and will report back. I am thinking the grounds need cleaning, or the relay (VW type 53) is bad. More later.
izzydog
izzydog is offline
PostPosted: Mon Jul 10, 2017 1:58 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Do I need to add shrouds to the area between the radiator and condenser to keep the fan from sucking air from around the condenser instead of through it?
JudoJeff
JudoJeff is offline
PostPosted: Mon Jul 10, 2017 2:02 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
I have the normal VW-Go West air deflectors on mine, but didn't "seal" between the radiator and condenser . Don't let the condenser touch the radiator, though.
vwcrazyfamily
vwcrazyfamily is offline
PostPosted: Mon Jul 10, 2017 9:49 pm    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Hello and thank you to all those that who have posted their work. I will be installing the SC kit over the next few weekends. Quick question, did everyone power the system directly from the battery or was anyone able to utilize the power feed to fuse S15 on a pre 1986? Fuse #15 is the 25A feed for the old AC system. If using fuse 15 have you had any issues? Thanks for the help
JudoJeff
JudoJeff is offline
PostPosted: Tue Jul 11, 2017 3:39 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
It has to be key-on power, so fuse15 sounds fine. I didn't think of that!
vwcrazyfamily
PostPosted: Tue Jul 11, 2017 7:15 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
Hi Jeff thanks for the quick reply. The SC kit requires two power connections one keyed (violet wire) and the red 30A circuit breaker. I was hoping to avoid running the red wire back to the battery and just connect it to the 4mm red wire that feeds the old evap rely. My concern is if the 4mm size wire is capable of 30A. 4mm wire is about 6 AWG wire and from what I have read it should be ok, but looking for real world verification to be sure.
JudoJeff
JudoJeff is offline
PostPosted: Tue Jul 11, 2017 8:29 am    Post subject: Re: Small Car Performance, DIY Front A/C Installation Reply with quote
You're right, I forgot about that. I connected up to the battery with #6 wire.
JudoJeff
JudoJeff is offline
PostPosted: Sun Aug 13, 2017 1:53 pm    Post subject: New Radio location Reply with quote
My radio was in front of the shifter, but the new in dash A/C is slightly more forward and I wasn't going into 1st or 3rd maybe one out of ten times.
I listen to audio books while driving so a single mech radio wasn't good enough for my needs. I found a marine radio case on Ebay for $29, and mounted it on the dash.
Now I have the old mount to sell here, it really is rather rare!
Page 13 of 37
