GreggK Samba Member
Joined: May 17, 2008 Posts: 898 Location: Colorado/Philidelphia
Posted: Sat Dec 02, 2017 7:56 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Hello All,
In the SC instructions on step #10- Heater fitting installation, you are instructed to "properly lubricate" the O-rings. What would the proper lubricant be?
Thanks, GreggK |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Sat Dec 02, 2017 8:17 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Use whatever oil you’re adding to the system, put a dab on your fingers and roll onto the O-ring. For example: Ester 100 _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
GreggK Samba Member
Posted: Sat Dec 02, 2017 6:59 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Hi Jeff,
So how do you determine the type of oil to use. Mind you I have NO experience with A/C.
Thanks for the help, GreggK |
Posted: Sat Dec 02, 2017 10:57 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
You have to put the hours in studying, gets very expensive, very fast. Some oils can not mix with others. Basically stay with what’s already in the system. _________________ ________________________________________
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Fri Dec 15, 2017 12:33 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
So mine is in and working, a sh t load of work and after many tries I can not get the Dash vent door to open consistently, I actually pulled the dash back out and pulled the unit back and sat there and played with the door and removed the stepper motor and watched its operation.
It looks a little out of square inside with the cover off, I tried it about 30 times before re-installing it and it seemed to work every time. Once reinstalled and the last screw was in I took it for a drive and the door opened about 4 times and will only open if you keep jiggling the control lever.
Has anyone else had this issue with the dash not getting airflow? I talked with VA and they were helpful and told me to remove the Stepper motor and cycle the door and re install the stepper motor. I am not looking forward to pulling this again.
Some come on fess up I can't be the only one. A few pictures of my project.
_________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Fri Dec 15, 2017 1:43 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Hey 16cv's-
Just for clarity- your system is a Vintage Air, but not the variant being sold by Small Car, right? _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Fri Dec 15, 2017 6:34 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
16CV's wrote: |
I like the additional fuse location, but I'd prefer to see a waterproof cover over it considering the location.
When you are installing the stepper motor or the little square - is there a chance the mount is going out of square when tightening the screws? _________________ This free advice is worth exactly what you paid for it.
16CVs Samba Member
Posted: Fri Dec 15, 2017 9:37 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Yes, mine is a home brew. The stepper motor just clicks right on and works perfectly once installed so I don't think that's the issue. Its more to do with the actual door. I am hoping it can be programmed out or i'm going to find some way to open that door from the surface when it sticks.
I was thinking about making an ABS cover for the fuse panel but I like the industrial look. I don't think weather will affect them.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
artacoma Samba Member
Joined: January 11, 2014 Posts: 121 Location: Victoria BC Canada
Posted: Fri Dec 15, 2017 10:23 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
I didn't have any issues with the door but one of the switches was faulty and would only work if I pushed in hard while turning , SC charged me $35 for a replacement.
Nice job on the fuse panel , it seems these vans are always a work in progress so easy access is vital. _________________ Cheers
Rik
86 Syncro Tintop
2.5 Subie
86 Doka
2.5 Subie |
16CVs Samba Member
Posted: Fri Dec 15, 2017 12:28 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
I would have gone back to VA for that switch, their cust service is top notch.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Sat Dec 16, 2017 9:08 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
16CV's wrote: |
Stacy |
Hi Stacy!
your installation is clean, you put a lot of work and thoughts on it!
The SC switch is not from VA. Classic of SC to make you pay for defect product replacements.... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
16CVs Samba Member
Posted: Sat Dec 16, 2017 9:36 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
That switch is straight from the VA catalog. SC just had a Facia made, which was well done.
If you look at the VA catalog they have quite a few options for switches including the black slide switch I used.
Thanks for the positive comments, I am happy with the end result, I didn't want some funky plate and screws on the surface and different dash grills.
There are quite a few differences between an SC set up and a basic VA kit.
GreggK Samba Member
Posted: Wed Jan 31, 2018 5:15 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Stacy,
That's a nice looking install you got there. Did you use the Go-Westy A/C condenser? |
16CVs Samba Member
Posted: Thu Feb 01, 2018 12:21 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Yes I used the GW condenser kit. It is well engineered and it fits well. It came with a conversion hose that I did not not need. I askd them if I could buy it without the hose and they said the kit would be more expensive in the long run.
We did 2 systems side by side and we sent the extra hoses back in an attempt to be GREEN. I didn't want anything back and that's a good thing because I didn't get anything back.
I am waiting for a hot day for a road trip to go out and try it. Thanks for the compliment, I thought it through and am happy with the end product.
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sat Feb 10, 2018 10:29 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
I've got the dash sorted, installed and running hot air. One thing I've not read about in this thread is the clocking of the controls. My fan, temp and vent dial controls are not pointing correctly. They need to be calibrated to correspond to the sweep of the graphics.
The controls work fine, but aren't pointing to the right settings. Anyone else have this issue? Anyone know how to fix it? Thanks. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
16CVs Samba Member
Posted: Sun Feb 11, 2018 12:22 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Call Vintage Air, there is a programming protocol they will walk you through. Before calling, be at your car and have the Programming wire exposed(orange or Purple I think) I'd have to look in the Install sheets. Anyway you will need to ground that lead and do a series of setting to program the controllers.
The VA people are knowledgeable and patient. But you will need to be near the unit unless you want to write it all down.
Good luck
rmcd Samba Member
Posted: Sun Feb 11, 2018 9:52 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
16CV's wrote: |
Good luck
Stacy |
I recall something like that in the notes but thought it was for a custom install if I supplied aftermarket switches. Which, technically, in the eyes of VA - maybe the SC is? I’m guessing all SC folks would have this issue.
I will report back. Thanks again. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
GreggK Samba Member
Posted: Wed Mar 21, 2018 6:35 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Hello all,
I'm reading over the trinary switch wiring for my SC in-dash unit. I went back and saw Judo Jeff's post confirming that the one blue wire from the switch goes to Vanagon fan relay #86 and the other blue wire goes to "ground".
On my SC diagram it shows one of the blue wires from the trinary going the Vanagon fan relay #86 and the other blue going to a red wire coming off the 30 amp SC circuit breaker going into the SC compressor relay.
Can any one explain that to me , I'm a bit confused. Thanks GreggK |
Pcforno Samba Member
Joined: October 14, 2014 Posts: 575 Location: Santa Fe, nm
Posted: Fri Mar 23, 2018 9:10 am Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Part of the confusion is from the vintage air diagram. The blue wire goes to a normally open switch on the trinary switch control. When the system pressure gets high enough, the switch closes. You can wire the blue wires therefore on the ground side to interrupt the the ground signal or the positive side to send a signal to the fan.
It also depends on if you have a 2 speed fan or a 3 speed fan. If you previously had AC you have a 3 speed fan. If you have an early model van or a Syncro without AC then you have a 2 speed fan. Otherwise likely you have a 3 speed fan. You can also look at your fan resistor behinf the drivers headlight and see if you have 2 or 3 wires coming off it.
Ideally you want the blue trinary switch wired to medium speed on a 3 way fan, and the compressor wired to low speed on a 3 speed fan, that way there will always be some flow across the radiator while the AC is running.
On my job I had a syncro without AC and had a 2 speed 450 watt fan. I had the blue wire originally wired from 12v+ to trinary switch to the 86 relay on the high powered relay behind the fuse box - it was way too loud and went on too often. So I bought a 3 speed fan resistor from van cafe and wired up 2 additional relays so that the compressor would trigger the low speed circuit whenever AC was on and the trinary switch blue wires would trigger the relay for the medium speed circuit. The high speed circuit on all vans bypass the radiator with a direct relay to the fan itself located behind the fuse box on the Pillar.
Hopefully that helps - basically the blue wire should trigger either your medium or high speed and can be used on the ground side or the supply side. If you’re using it on the 86 relay to high speed as you mentioned then one blue goes to 86 and the other blue goes to ignition controlled power.
But I highly recommend converting to a 3 speed resistor if you don’t have one and witing as described above
Cheers! |
GreggK Samba Member
Posted: Fri Mar 23, 2018 7:05 pm Post subject: Re: Small Car Performance, DIY Front A/C Installation |
Good info there Pcforno. I did get in touch with Mao @ SC and he confirmed to connect trinary blue wire to 12v (red wire from 30amp circuit breaker to SC compressor relay) and to #86 on vanagon fan relay. Are you saying that #86 on vanagon relay is high speed fan speed. I do have a 3speed fan, my van did have factory A/C. Thanks. |
