SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Thu Apr 17, 2014 7:15 pm Post subject: Really? Lost most of my CVJ bolts |
So, I was just under my van trying to track down a wee bit of a coolant leak when I notice that 4 of the 6 inner CVJ retaining bolts on the drivers side are missing and at least 1 of the bolts on the passenger side is backing out.
The CVJs were new when I bought the van 3 years ago and we do most of our camping way down bumpy dirt roads. So, I can see how they would back out if they weren't installed/torqued correctly.
When I get replacements, what is the torque spec and should some sort of loc-tite be used? Any special tricks of the trade to be aware of? It seems simple enough but I ask because obviously at some point a "pro" goofed it up. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Merian Samba Member
Posted: Thu Apr 17, 2014 7:25 pm Post subject: |
You MUST clean the bolt threads of all oil with brake cleaner and then use it on a Q-tip or something to clean the female threads also.
You MUST use NEW, not old, Schnorr washers each time. I tested this on a Porsche once just to see if reuse was ok - it wasn't.
IF VW used moon plates, then use those.
Some use Loctite, I have never needed to because I follow the above.
Inspect the wrenching fixture and threads on the bolts (cap screws) carefully - use a magnifier if you want - and if ok, they can be reused. If replaced, be sure a fastener strength spc. is... ah.. respected.
Check the Bentley for the torque spec. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
SCM Samba Member
Posted: Thu Apr 17, 2014 8:35 pm Post subject: |
If those work on Vanagons I'll be all over them.
As for checking the Bentley for torque specs - it sure seems like those SHOULD be on page 42.7 but they aren't. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Thu Apr 17, 2014 8:38 pm Post subject: |
Look on 42.2 |
SCM Samba Member
Posted: Thu Apr 17, 2014 8:50 pm Post subject: |
syncrodoka wrote: |
Look on 42.2 |
Usually when I can't find something it's my wife who says "did you really look for it?"
Thanks! _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
boof1306 Samba Member
Joined: July 10, 2010 Posts: 304 Location: MELBOURNE AUSTRALIA
Posted: Thu Apr 17, 2014 9:18 pm Post subject: |
Funny, my wife says "did you have a man look". The really annoying thing is she is usually right.
Back to cvj's. They may have not been tensioned correctly but I think the big thing to learn here is not to leave cvj or bolts unchecked for three years. I check grease mine every 6 to 12 months depending on usage. Greg |
Merian Samba Member
Posted: Thu Apr 17, 2014 9:50 pm Post subject: |
re: locking bolts
The torque from the engine is transmitted via the faces of the two assemblies being in tight contact, NOT by the bolts. The tension in the bolts hold the faces tightly together.
If the locking bolts do not keep them tensioned then they will experience shear and will break. So be sure those locking bolts keep the bolts tight and not just act like safety wiring to keep the bolts from backing out all the way. |
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2096 Location: Boulder CO
Posted: Thu Apr 17, 2014 9:59 pm Post subject: |
Jegs locking CV bolt kit is bomber. |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Thu Apr 17, 2014 11:32 pm Post subject: |
No offense, you obviously did not know any better but you really should check your cv joint bolts more often than every 3 years. I do a quick check every oil change because I am paranoid. Every 10,000 miles would probably suffice.
I do not do any of the things people have said you have to do…no q tips, no special locks, no loctite, nothing.
I just tighten the crap out of each one and count as I go so I do not miss one.
I jack the van up so I can wedge a 2 by 4 in between the tire and the ground and move the wheel for each bolt so i can get perfect alignment and maximum leverage. If you have a helper you can probably do the same thing using the brakes instead.
In all the time I have had my van one bolt became slightly loose and I may have forgotten to tighten it, who knows?.
I suspect the shop did not tighten them enough.
Neil2 |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Thu Apr 17, 2014 11:49 pm Post subject: |
Of the ones that remain, check for bent bolts; also try to ensure none of the holes got ovaled... I had to replace a stub axle once for this. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1001 Location: Oakland CA
Posted: Fri Apr 18, 2014 1:38 am Post subject: |
Try Nord Lock washers. And yes, I've had cv joints professionally replaced, by the best shop in the SF Bay area and had the bolts come loose. Seems like rechecking is best option.
I purchased the Nord Lock washers for the next time the bolts need to come out...
Here is a good video showing he Nord Lock
[/url] _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Posted: Fri Apr 18, 2014 1:59 am Post subject: |
Great sounding product but aren't they saying that you can't use them with anything stronger than grade 8 bolts. Cv bolts are all above 10.9. Any mechanical engineers out there to confirm this. |
Posted: Fri Apr 18, 2014 4:13 am Post subject: |
boof1306 wrote: |
Grade 8 is the term for inch size bolts. It is the same as Property Class 10.9 for metric bolts. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
cvbill Samba Member
Joined: May 24, 2007 Posts: 208 Location: Carmel Valley, CA
Posted: Fri Apr 18, 2014 6:30 am Post subject: |
John W always told me to make sure the mating surfaces of the CV and the axle flanges are grease free. Hard to do as they are full of grease and you try to maneuver them in place. If not, you may be torqueing down on a layer of grease, which will continue to ooze after you're done with the bolts. He said retorque after a couple hundred miles.
To me, cv trouble comes with off-roading
Let's go break something at SyncroFest!! _________________ Ideology trumps Reality - no exceptions |
Posted: Fri Apr 18, 2014 8:16 am Post subject: |
If I understand the NordLock correctly, they recommend lubruication on the bolt, like has been said, its a greasy situation working with repacked CVs. _________________ 1987 Syncro Westfalia, stock (bought 1994)
SCM Samba Member
Posted: Fri Apr 18, 2014 8:17 am Post subject: |
furrylittleotter wrote: |
Well then, that's every 4 or 5 years for me.
Oh, the joys of of living within a few hundred miles of TONS of great camping and in a place where it's winter for 6 months a year (I don't drive the van in the winter).
Point taken though. It's amazing to me how every other vehicle that's been in my household has been a "just drive it" type of thing while the Westy really is more like a cranky, attention mongering, child. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Fri Apr 18, 2014 8:18 am Post subject: |
I have always torqued my CV bolts to 36 ft lbs, using the original arc shaped plate under each set of bolts. I don't bother with the bolts or holes being totally degreased, no loctite. I check the torque after 100 miles and then am good to go until the next time I need to change a boot (or a transmission... ). YMMV, others have different methods that work equally well... _________________ Dave O
The Western Syncro build
SCM Samba Member
Posted: Fri Apr 18, 2014 8:25 am Post subject: |
dobryan wrote: |
I have always torqued my CV bolts to 36 ft lbs, using the original arc shaped plate under each set of bolts. ... (or a transmission... ). |
Thanks for all the input guys! Now that I've been thinking and researching about it I suspect what happened was that the bolts weren't torqued properly when my (previous) mechanic dropped the trans to replace a bad rear main seal. I'm also missing the arc shaped plates so they either forgot that or they were missing prior to me owning the van.
Thanks for the invite to SyncroFest. I'm honored to know my 2wd is having problems that typically plaque it's 4wd brethren. You should see the 'wheelin and other abuse that the Jetta was subjected to when it was our main camping vehicle. I should probably check some bolts on that... _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Fri Apr 18, 2014 8:27 am Post subject: |
cvbill wrote: |
He said retorque after a couple hundred miles. |
So now your avatar makes more sense, you just roll your van up on its side to check your CV's. See you at Syncrofest, and keep at least 3 wheels on the ground at all times. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
