Westified Samba Member
Posted: Fri Apr 18, 2014 2:38 pm Post subject: Fuel Line Fire Sleeves |
I am planning to put fire sleeves on my fuel lines. I have purchased DEI (Design Engineering Inc.) fire sleeves but haven't installed them yet. I saw Insyncro uses Aeroquip Fire Sleeves which are top of the line and made to aircraft specs. I considered these but appear to require metal straps on each end and a special tool to put the straps on. It makes them rather costly and I was concerned they were very thick. The DEI sleeve kit comes with silicone tape to wrap the ends.
Does anyone have any comments, suggestions regarding fire sleeves. Brands, experience using them, etc? Will they help prevent an engine fire? _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
bluebus86 Banned
Posted: Fri Apr 18, 2014 4:07 pm Post subject: |
the fire sleeves are kind of like closing the barn door after the horse got out.
I think the most likely fire source is a leaky fuel system, once the fuel system is punctured, and fire has started, what's the point of protecting the now un-pressurized fuel hoses now that the fire is already going?
Now of course if the fire started from other source than a fuel leak, then the sleeves would be useful. I would guess that a huge percentage of engine fires are fuel leak caused. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
danfromsyr Samba Member
Posted: Fri Apr 18, 2014 7:38 pm Post subject: |
on the worry of electrical fire.
I'd recommend every 83.5-85 van upgrade the ALT wire harness.
nearly every one I've inspected, I've removed because of electrical heat related fatigue to the wires.
these wires cross unfused over both supply & return fuel lines on the backside of the firewall.
I'd say you can easily DIY this harness upgrade, but vancafe has a easy replacement one available. _________________
Abscate wrote: |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32627 Location: Reading Pennsylvania
Posted: Sat Apr 19, 2014 10:44 am Post subject: |
Thanks for the replies. Good point Bluebus86 maybe the fire sleeves are a placebo effect for me. I was hoping it would reduce heat and aging on the fuel lines and maybe contain a small leak. I have also been looking at automatic fire extinguisher systems. I have replaced my fuel lines and firewall fitting. I am planning to also replace the fuel rails and fuel pressure regulator. I carry 4 fire extinguishers.
DJKEEV now you have given me another project. Thanks, it sounds like a good idea. Don't need an electrical fire.
Here is a photo of the fire sleeves I purchased from Speedway Motors on sale.
Posted: Sat Apr 19, 2014 10:48 am Post subject: |
Sorry I should give credit to Danfromsyr for mentioning the Alt wiring Harness and Djkeev for posting a picture. thank you. I am going to inspect mine. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
Posted: Sat Apr 19, 2014 12:20 pm Post subject: |
I think one of the major contributing factors to the severity of Vanagon fires is the fuel return. Once the fire starts and burns through a line the fuel can flow backwards through the return feeding the fire. A spring loaded check valve in the return near the tank was my solution.
I think the sleeves are a good idea as well. |
